tips to avoid bringing back bed bugs
by WhyMe - 09/17/19 09:46 PM
Fram Ultra worth it over OEM?
by Jimmy_Russells - 09/17/19 09:42 PM
Time for a new phone! Recommendations?
by cwilliamsws6 - 09/17/19 08:58 PM
How Do You Listen to Music ?
by Warstud - 09/17/19 08:57 PM
Runnings Harvest King Dino $1.75/QT
by Zaedock - 09/17/19 08:15 PM
Typical generic TPMS install costs
by Patrick0525 - 09/17/19 05:23 PM
Marvel Ultimate Fuel and Motor Treatment
by 03s - 09/17/19 03:50 PM
Upcoming tire sales?
by supton - 09/17/19 03:44 PM
Welding Rusted Control Arm Mount
by George7941 - 09/17/19 03:42 PM
15w40 in my automatic trans.
by Ursatdx - 09/17/19 03:16 PM
Update on my Stihl BG 86
by 1978elcamino - 09/17/19 03:11 PM
Offset print oil
by Matt_Pill - 09/17/19 03:06 PM
Which 508.00 oil would you choose?
by Vigg - 09/17/19 02:55 PM
Any BMW LL04 recommendations?
by M3m3x5 - 09/17/19 02:18 PM
5W30 Suggestions/Subaru
by Motoretro - 09/17/19 02:18 PM
Recommend Costco tires
by henni - 09/17/19 01:58 PM
Castrol SRF Shortage
by kyoo - 09/17/19 01:26 PM
All aftermarket drums and shoes = junk?
by nthach - 09/17/19 12:38 PM
Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX
by 05UFCaptain - 09/17/19 11:51 AM
scoutmstr, 2_Tall_Mitchell, HRXfan, ShaTR, thetransman
69312 Registered Users
98 registered members (Aichiguy, alchargo, 69GTX, 08z06, 11 invisible), 1,964 guests, and 28 spiders.
Topics294,701
Posts5,064,972
Members69,310
Most Online3,532
Jul 30th, 2019
Our Camry is back! #5114349 05/24/19 09:12 AM
T
tomcat27 Offline OP
T
Last summer my daughter drove our 2001 Camry 50 miles with a stuck thermostat. with poor judgement and bad advice, I pulled the head, had it planed, and re-assembled. yes, it was still blowing exhaust into the cooling system. I finally found some time and installed a reman engine in the car over the last week. It was almost easier to pull the engine than it was to pull the cylinder head. anyway, the car lives! only two problems: one of the core plugs, aka freeze plugs; was leaking. easy to fix. and now the car has a vibration/buzzing noise in either the engine or first half of the transmission. not sure what the cause is. did the remanufacturer fail to balance the rotating assembly? is there something askew with the balance shafts?? The remanufacturer used top quality parts: aisin/Toyota water pump and oil pump, OEM timing belt. not sure on the pistons, bearings, etc.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Our Camry is back! [Re: tomcat27] #5114395 05/24/19 10:12 AM
W
WyrTwister Offline
W
Sounds like you are going to have to seperate the engine & transmission . Manual or automatic ?
Wyr
God bless
Re: Our Camry is back! [Re: tomcat27] #5114409 05/24/19 10:27 AM
CT8 Offline
What is the Camry worth?
2015 F150 2.7
2018 F350 6.2
Re: Our Camry is back! [Re: CT8] #5114424 05/24/19 10:47 AM
T
tomcat27 Offline OP
T
It cost me less than $2k for the engine. The car belonged to mom originally. I don't mind spending more than it is "worth". the rest of the car is in great shape with no rust. what other options are available for $2k?
Re: Our Camry is back! [Re: WyrTwister] #5114427 05/24/19 10:48 AM
T
tomcat27 Offline OP
T
automatic. I could probably pull the engine with my eyes closed at this point.
Re: Our Camry is back! [Re: CT8] #5114444 05/24/19 11:05 AM
B
bubbatime Offline
B
About $500 scrap value. Not worth the time or effort to rebuild the engine, then pull the engine and put a reman engine in. Then have a wierd vibration that requires the engine to come out AGAIN. Should have sold the Camry and moved on to a newer used car. It almost never makes sense to put a new engine into a 18 year old car.
I have a 2010 Acura TSX that's reliable as all get out and could be purchased used for $2500 if I was selling it.
19 Honda CRV 1.5T factory bulk
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
06 GMC Sierra SuperTech 10W30
Re: Our Camry is back! [Re: tomcat27] #5114461 05/24/19 11:19 AM
K
KGMtech Offline
K
I would be checking the motor and transmission mounts. First try loosening the mount bolts, then drive the car forward 3-4 feet, then stop and go in reverse the same distance. This might shift the mounts back to their "preferred" resting position.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Our Camry is back! [Re: bubbatime] #5114464 05/24/19 11:21 AM
I
Imp4 Offline
I
Correct, but OP clearly stated that the vehicle had sentimental value because it belonged to his mother.
Here is the rare instance where it does make sense.
It is no longer a financial decision.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Our Camry is back! [Re: bubbatime] #5114495 05/24/19 11:41 AM
The Critic Offline
That seems very low. I just did a check on craigslist and most of the 2010 TSX's were selling for between $6-$9K. Is your market really that much different?
2011 Toyota Prius 1.8L - 195K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: Our Camry is back! [Re: KGMtech] #5114510 05/24/19 11:50 AM
T
tomcat27 Offline OP
T
good suggestion. will do. I do actually recall that the rear mount was not in the same location, and someone else handled the trans mount. as far as was it "worth it" to fix the car? - I suggested to my wife multiple times that we scrap it. nope. no dice. sigh.
Re: Our Camry is back! [Re: tomcat27] #5114524 05/24/19 12:06 PM
Chris142 Offline
Sounds like the cooling system in the replacement was not well maintained.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Our Camry is back! [Re: tomcat27] #5114559 05/24/19 12:45 PM
E
eljefino Offline
E
The motor mounts are a good idea and also look underneath to see if, say, an exhaust flexpipe stiffened up (with rust) while the car was sitting. Or an exhaust hanger is overextended, rubbing, etc. Take the thing for a spirited drive to redline, may need cobwebs blown out.
Re: Our Camry is back! [Re: eljefino] #5114591 05/24/19 01:16 PM
AZjeff Offline
Or not. The next engine might not have the buzz!
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Our Camry is back! [Re: tomcat27] #5114728 05/24/19 04:35 PM
T
The_Eric Offline
T
Who did the re-man?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Our Camry is back! [Re: The Critic] #5117864 05/28/19 07:00 AM
B
bubbatime Offline
B
My TSX has 250k miles, the kids drew pictures in the paint with a rock. It’s definitely worth less than an average 2010 TSX. That being said, I would drive it to Alaska tomorrow. Very reliable Honda car.
