Not sure if this applies to the Altima, but I just did some more innerwebs searching in regards to the Murano, Pathfinder and Quest.
It looks like fluid level must be checked between 98-113F CVT fluid temp. They don't say to have the engine running, but you can hear it running in some videos, on the lift or not. Fluid should just dribble out. 4qts is the normal drain/fill amount.
