F1 - 2019 French Grand Prix
by gofast182. 06/20/19 06:17 AM
Yard rollers
by dlundblad. 06/20/19 05:20 AM
EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
The cool people of Bitog
by Marco620. 06/19/19 08:52 PM
How do Adjust Your Seat and Mirrors
by buster. 06/19/19 08:37 PM
AC for hybrid and electric vehicles
by JimPghPA. 06/19/19 08:06 PM
Mobil 1 sold at Walmart vs Summit Racing
by kosoku. 06/19/19 08:02 PM
Troy Bilt TB200
by Floyd1. 06/19/19 07:54 PM
Cutting vinyl planking, Do I need a snapper?
by JLawrence08648. 06/19/19 07:13 PM
1969 Honda N600, Serial #1...
by mattwithcats. 06/19/19 06:02 PM
My Son Turned Me On to a New Cooking Show
by NYEngineer. 06/19/19 05:42 PM
Naphthenic Oils
by MolaKule. 06/19/19 05:06 PM
Mopar 5W-20?
by John344. 06/19/19 04:39 PM
Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
2015 4Runner 4.0L; TGMO 5k miles
by OCDoiler. 06/19/19 04:17 PM
DesertTech, Jamie_E_M, Tambo, Robw, taschnewitz
68438 Registered Users
78 registered members (Astro_Guy, BigCahuna, Bailes1992, bbhero, AZjeff, AlienBug, 7 invisible), 976 guests, and 26 spiders.
Topics290,689
Posts4,991,025
Members68,438
Most Online2,967
Mar 10th, 2019
SKF grease with graphite #5114168
05/24/19 03:42 AM
05/24/19 03:42 AM
Dortmund, Germany
PreludeDenarius Offline OP
Dortmund, Germany
Hi,
I've been using SKF LGEV 2 grease (https://www.skf.com/group/products/...-grease-with-solid-lubricants/index.html) on some car body bolts, to prevent seizing and corrosion. According to specification it has great corrosion and water resistance. But recently I read that graphite can cause galvanic corrosion.
Do you think it is relevant in my case?
I also have VALVOLINE Multipurpose Calcium Grease (https://www.valvoline.com/en-europe/our-products/grease/calcium). Do you think it would be better for this application?
Re: SKF grease with graphite [Re: PreludeDenarius] #5114205
05/24/19 06:22 AM
05/24/19 06:22 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Why aren't you using Neverseize, which is specifically made for this purpose?
Re: SKF grease with graphite [Re: Kestas] #5114247
05/24/19 07:27 AM
05/24/19 07:27 AM
Dortmund, Germany
Dortmund, Germany
Just used what I had. There are anti-sieze copper greases from Valvoline and Liqui Moly, SKF has anti-fretting agent. May be you know which would offer best corrosion protection?
Re: SKF grease with graphite [Re: PreludeDenarius] #5114335
05/24/19 09:03 AM
05/24/19 09:03 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
What are you trying to prevent from corroding? The best way to prevent corrosion is to exclude electrolyte, such as an application of rustproofing compound.
There is no grease, antiseize, or compound applied to threads that would prevent corrosion. Though compound applied to threads will help exclude electrolyte, at least for a while. The dressing of threads is typically to make disassembly easier.
Re: SKF grease with graphite [Re: Kestas] #5114357
05/24/19 09:21 AM
05/24/19 09:21 AM
Dortmund, Germany
Dortmund, Germany
Basically I want to protect threads and bolt from rusting and seizing.
Re: SKF grease with graphite [Re: PreludeDenarius] #5114550
05/24/19 12:33 PM
05/24/19 12:33 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
A long time ago, when my dad bought a new car, I went through every nut and bolt I could reach under the car and treat it with antiseize. This paid off years later when I had to do repairs.
Re: SKF grease with graphite [Re: Kestas] #5115065
05/25/19 12:57 AM
05/25/19 12:57 AM
Dortmund, Germany
Dortmund, Germany
Thanks for the advice, think I'll try this one https://www.valvoline.com/en-europe/our-products/grease/copper-compound
Still, it is interesting if SKF LGEV 2 can cause corrosion, maybe somebody knows?
Re: SKF grease with graphite [Re: PreludeDenarius] #5115086
05/25/19 02:57 AM
05/25/19 02:57 AM
Greece
berlyn Offline
berlyn  Offline
Greece
Hello PreludeDenarius,
in the past I used the same product for the same reason smile I thought I was the only one smile
I consider SKF a company that manufactures very high quality products, but in the lubrication sector many other choices exist in the market. It depends on availability as well.
I also tried to find the LGEV version (higher viscosity -solid lubricants) in order to have one product for the chassis lubrication spots as well. I concluded that a dedicated product for avoiding seizing is better performing, Kestas wrote a very useful post, I would use copper anti-seize paste for steel bolts or a nickel containing one for the high alloy ones (exhaust etc). Loctite-Henkel products are easy to find were I live. Mind the tightening torque every time you use such a product, the product may lower the coefficients of friction so take care not to strip the threads.
Now my experience: the product LGEM has low resistance to the elements, it will not prevent corrosion. This is my experience from my applications, it gets washed away very easily. You can also search among Klüber product range (should be available easily in DE).
The following products are on my list for a trial, both are hi visc ones.
Klüberplex BE 31-222-502
Klüber Staburags NBU 30
Re: SKF grease with graphite [Re: berlyn] #5115126
05/25/19 06:20 AM
05/25/19 06:20 AM
Dortmund, Germany
Dortmund, Germany
Hi Berlyn,
Thanks for the advice!
I try to be pretty gentle cool .
The reason LGEV 2 was interesting to me, is because it looked like the 'nastiest' grease out of SKF range. For example, compared to LGEM, according to SKF website, there are some differences:
LGEV 2:
Extremely high viscosity grease
Lithium/calcium soap (maybe better rust protection?)
Base oil viscosity:
40 °C, mm²/s - 1 020
100 °C, mm²/s - 58
Was tested with sea water
LGEM:
High viscosity grease
Lithium soap
Base oil viscosity:
40 °C, mm²/s - 500
100 °C, mm²/s - 32
Wasn't tested with sea water
I'll check out Klüber and Loctite products as well.
Re: SKF grease with graphite [Re: PreludeDenarius] #5116747
05/26/19 08:51 PM
05/26/19 08:51 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Isn’t graphite commonly used in antiseize?
I have heard of folks using grease as a surrogate antiseize, but getting the real stuff is likely better.
Re: SKF grease with graphite [Re: JHZR2] #5117185
05/27/19 11:08 AM
05/27/19 11:08 AM
Dortmund, Germany
Dortmund, Germany
Hi JHZR2,
Bought Valvoline copper compound
[Linked Image]
According to SDS it has a small percent of graphite in it. I guess it is good for steel, but maybe not all other metals.
Re: SKF grease with graphite [Re: PreludeDenarius] #5117840
05/28/19 06:03 AM
05/28/19 06:03 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Originally Posted by PreludeDenarius
Hi JHZR2,
[Linked Image]
That’s a whole other discussion. Copper and aluminum will react, for example, but people use Cu antiseize in aluminum engines regularly.
I think I read for aluminum wheels on iron brakes, zinc antiseize was the best.
I feel like there should be an anti seize vs material coupling chart but I’ve never found a conprehensive one.
