Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
44 registered members (53' Stude, bernau, BlueOvalFitter, AndyB, Bighorn2500, 9 invisible), 665 guests, and 20 spiders.
Topics290,259
Posts4,987,229
Members68,412
Most Online2,967
Mar 10th, 2019
AT-205 Re-Seal for 1968 VW Bus? #5114140
05/24/19 01:22 AM
05/24/19 01:22 AM
Tennessee, United States
ZraHamilton Offline OP
Would you try AT-205 Re-Seal in a 1968 VW bus for a few-drips-a-day leak? It is supposed to be safe for all rubber seals as it is 100% diethylene glycol monoethyl ether (Carbitol solvent) which is a plasticizer. I've read a lot of positive reviews about how it's actually not snake oil, but I was hesitant to use it in such an old engine. As far as I know, they could be the original seals.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: ZraHamilton] #5114182
05/24/19 05:03 AM
05/24/19 05:03 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Leaking from where?
"Zed's dead baby, Zed's dead."
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: ZraHamilton] #5114319
05/24/19 08:34 AM
05/24/19 08:34 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would not use it on this engine. This is the nature of the best, split cases, pushrod tubes, etc, they drip a little after years. You may end up turning a nuisance into a full blow PITA.
This is a simple engine to remove and overhaul wait till then to update the seals, o rings and gaskets to more modern materials. You can swap pushrod seals easy enough with updated tubes if that is what is leaking, a crank leak is more likely.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: ZraHamilton] #5116451
05/26/19 03:26 PM
05/26/19 03:26 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Before I did my valve covers I tried it. Within 10mins of adding it I got a CEL. low oil pressure, it apparently thinned out the oil too much. The stuff pours like water. I immediately changed out the oil, which sucked because I had less than 500 miles on fresh oil, and the CEL/DTC went away.
Does it work, maybe for some. But for me it was a costly no-go when you include the price of the product and new oil/filter. That's when I just decided to do it right and do the valve covers. I was already beginning to get some oil drips on my alternator and I didn't want to kill that too...
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: Mad_Hatter] #5116465
05/26/19 03:37 PM
05/26/19 03:37 PM
North Carolina
North Carolina
Your air-cooled VW had a CEL?
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: rooflessVW] #5116500
05/26/19 04:37 PM
05/26/19 04:37 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Are you purposely being obtuse or is that a serious question?
In case you missed it, the OP said he's read a lot of positive reviews on the product. So I'm offering up my experience with the product - nothing more, nothing less. I even stated the product may indeed work for some but for me it didn't. And if I were seeking strictly the opinions of 68 VW Bus owners about the product, I'd post the question in a VW owners group or I'd at least state that in my post.
And while I don't have a '68 Bus, I think it's totally relevant to the discussion the effect the product had on my oil. Had I read a testimonial like that prior to purchasing the product, I probably wouldn't have. It was as I stated, a costly mistake.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: ZraHamilton] #5116598
05/26/19 06:31 PM
05/26/19 06:31 PM
North Carolina
North Carolina
The point I'm trying to make is that your experience is largely irrelevant to the OP's engine, unless you used it in a similar engine with a similar assembly method and seal type.
Further, that it thinned your oil to the point that you got a low pressure light suggests that you may have been using an oil that was too thin to begin with or than your engine is worn and would benefit from a thicker oil. Because you drained the 205 out so quickly, you're also rather unable to comment on how well it works to slow a leak, which was the OP's inquiry.
I asked the OP where it was leaking from, because only then can I even begin to speculate on the seal material he hopes to affect with 205. As Trav said, there's not a whole lot you can do to stop leaks on an old air-cooled besides pull it down and re-seal it.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: rooflessVW] #5116660
05/26/19 07:39 PM
05/26/19 07:39 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
The product alters the oil properties, not the engine or assembly method. Employing your logic, nobody should ever solicit feedback on how a fluid additive performs in someone else's car unless they're identical.engines.🤣 (there goes half the posts in this forum)
Wrong again...5w30 every time, all the time per mfgs spec. And I never have had that happen before nor has it ever happened again in the 15k+ miles driven on 5w30 since. The oil pressure is just fine in my car but hey, maybe you know something about my car that I don't.
In any event OP, take my ANECDOTAL experience (oil thinning) for whatever it's worth. I'm sure everything will work out for ya...
Fwiw, I'm not intrinsically opposed to stop leaks; I've used them on other cars I've owed with varying success, like on my 1990 Camry. It kept that car on the road until 2yrs ago when I sold it with over 300k miles on it. One of the best engines Toyota ever made.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: Mad_Hatter] #5126240
06/05/19 05:21 PM
06/05/19 05:21 PM
ottawa
nicholas Offline
nicholas  Offline
ottawa
I did not think such a small ammount of liquid could actually change the viscosity of the host oil enough to trigger a low pressure situation.
I dont think the ATP caused your CEL.
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: nicholas] #5126486
06/05/19 09:13 PM
06/05/19 09:13 PM
Canada
addyguy Offline
addyguy  Offline
Canada
Agreed.
2010 Kia Soul 2U - 2.0L I-4, auto; 143k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: addyguy] #5126602
06/06/19 03:55 AM
06/06/19 03:55 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Agreed.
I also agree.
God Bless Our Troops
Re: AT-205 Re-Seal for 1968 VW Bus? [Re: nicholas] #5129095
06/09/19 08:21 AM
06/09/19 08:21 AM
Trav Offline
Trav  Offline
More likely the strong solvent loosened or liquefied a piece of whatever muck was in the screen and it end up in the oil pressure sending unit hole temporarily giving a false low reading. 2cents
