Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
ARedStart, viper74656, Tar, cast71, bamadog1
69573 Registered Users
53 registered members (billt460, 2015_PSD, AlienBug, Bailes1992, 4WD, 8 invisible), 907 guests, and 15 spiders.
Topics296,029
Posts5,089,587
Members69,573
Most Online3,532
Jul 30th, 2019
2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) #5114120 05/24/19 12:27 AM
O
OS4A Offline OP
O
RAV4 with 29,900 miles. Is a DD and driven very easy. Good mix of trips less than 10 miles and between 11 to 40 miles. 80/20 split local/highway.
Dealer performed first two oil changes. Last one in July 2018.
Paperwork for first change detailed Toyota SN+ 0w-20. Paperwork for second change was vague and ambiguous so assume dealer bulk of unknown origin though 0w-20 was noted. Local mom n pop dealership sold to out-of-state automotive superstore type January 2018...world of difference and red flag.
I changed oil and oil filter May 2019 and sent sample for UOA. Filter was Toyota/Denso and was in decent shape with no noticeable particles to cause concern.
Also installed Fumoto valve, and replaced air filter, cabin filter.
Plan is to pull sample at ~6000 miles and send for UOA. Will include TBN next UOA.
Didn't figure TBN was worth it this time because of unknown oil origins so not much useful info going forward.
Just setting the baseline.
Attached PDF document
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: OS4A] #5114207 05/24/19 06:27 AM
J
JLTD Offline
J
Looks decent for an unknown bulk oil. What did you choose to replace it?
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: OS4A] #5114287 05/24/19 08:09 AM
O
oil_film_movies Offline
O
Yep, definitely not the recent super-high-moly Toyota house brand oil. Still OK stuff in there, viscosity looks decent. Might be able to get the wear numbers down some using a better oil though.
I like high moly ( 900 ppm, more than Toyota's oil) Eneos Racing Street 0w20 SN-rated oil in my hybrid. Helps with all the start-stop grinding on the bearings and moly works when engine temps are on the cool side.
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: OS4A] #5114315 05/24/19 08:32 AM
A
ARCOgraphite Offline
A
Grinding on polished surfaces 0.0005" apart?
How bout too much moly gunking rings up?
I used to be a big moly fan (recall the Old Formula Shell) but now I am not so sure it will keep the cylinder balance within 5%.
I do have some liqui-moly in the Generac on top of VR10W30 Syn seem to keep her happy. and not clanking when she heat up.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: ARCOgraphite] #5114376 05/24/19 09:50 AM
O
O
Remember Stribeck curves show the metal-to-metal effects of zero relative surface speeds on friction and wear.
They do a lot of engine testing for that. I'm not too concerned. Maybe it's the worrier in me that says use Valvoline Premium Blue Restore oil every 75,000 miles though, to clean up the ring pack "just in case".
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: oil_film_movies] #5114500 05/24/19 11:44 AM
AZjeff Offline
This is BITOG and all but can there possibly be any measurable advantage to an oil that 99% of the nerds here probably haven't heard of compared to any top shelf brand name?
Yeah, "grinding bearings" might be a wee bit of hyperbole..
Of course there is no such thing as too much protection do what lets you sleep at night!
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: AZjeff] #5114709 05/24/19 03:58 PM
L
Leo99 Offline
L
The delta between the cheapest oil that meets spec and the most expensive is probably very small. Maybe you'll see a benefit past 300k miles and maybe you won't.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: ARCOgraphite] #5114716 05/24/19 04:05 PM
53' Stude Offline
For god's sake man; be quiet and stop with all this b.s. you spew. Just stop talking period!!
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: AZjeff] #5114865 05/24/19 07:59 PM
O
O
Yeah, "grinding bearings" might be a wee bit of hyperbole..!
There really is surface contact (aka, grinding) when bearing speed is at or near zero, as in when starting up initially. ...
Also, parts of cam lobes undergo surface contact normally, when the surface-active additives like ZDDP, polymer esters, & moly (at higher concentrations) keep the pointy end of lobes lasting longer.
I tend to agree with the low-moly crowd sentiment here, as low-moly oils are fine enough. .... A lot of Japanese oils do have high moly (TGMO, MGMO, Zepro, Eneos....) and racing oils use plenty of moly, so maybe its good stuff (???).
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: JLTD] #5115043 05/24/19 11:47 PM
O
OS4A Offline OP
O
JLTD
Actually went with Castrol Edge 0w-20 Bio Synthetic and Purolator Boss filter.
Looking forward to UOA at 6000 k...lol
As a side note...also running Castrol 0w-20 Bio Synthetic in my 2018 Honda Clarity PHEV. Plan is to pull a sample from the Clarity at 6 months for UOA.
2019 Subaru Impreza 5-door Rotella T6 MV 5w-30 PBL14615 filter
2018 Honda Clarity PHEV Castrol Bio-Synthetic 0w-20 PBL14610 filter
2017 Toyota Rav4 Hybrid Castrol Bio-Synthetic 0w-20 PBL25608 filter
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: OS4A] #5115162 05/25/19 07:22 AM
J
JLTD Offline
J
Thanks--
Probably get better results with the Edge, 6k seems pretty short to change so maybe a sample and UOA....?
Using AMSOIL
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: 53' Stude] #5115220 05/25/19 08:35 AM
A
A
Play nice.. Remember the rule book.
It has been proven a high moly load will not pass TEOST in API certification. ILSAC gave 0w20 an exemption at the time as it was not used in Turbocharged engines
So where is the B.S.?
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: OS4A] #5115284 05/25/19 10:09 AM
53' Stude Offline
You have blown up what 5+ engines since being here. Do I need OVERKILL and other members to refresh your memory?
Didn't think so
Just stop talking jibberish and making a fool of yourself
Thank You
Re: 2017 Rav4 hybrid, dealer bulk 0w-20, 10,143 mi, 2.5L (2AR-FE) [Re: JLTD] #5115911 05/25/19 11:19 PM
O
OS4A Offline OP
O
JLTD
I am pulling sample only from the Toyota at 6k for UOA so I can see the numbers. Also pulling sample from the Clarity at 6 months. Be interesting to see similarities/differences from UOA's.
Decision on Toyota OCI will be made after review of UOA. No preconceived notions. Data is data.
Castrol Edge black/gold jugs are part of the usual prospect pool when buying. However...
...I have been curious for some time about the Bio Synthetic and how it will run in different vehicles. Obviously the cost of Bio Synthetic is a bit high. However, curiosity has finally gotten the better of me.
I've read the documentation on Bio Synthetic...now want to see how it does in a couple real world applications.
