Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Lucase483, Chaucha, UofA, Jeffrey78, Markovchain
70788 Registered Users
105 registered members (55hambone, AC1DD, 4WD, 2010Civic, 53' Stude, 12 invisible), 2,394 guests, and 24 spiders.
Topics301,836
Posts5,203,696
Members70,788
Nissan Type A suspension fluid, need replacement #5106783 05/16/19 09:42 AM
V
VH45DE Offline OP
V
This is for a hydraulically assisted closed loop suspension system on a survivor Q45.
[Linked Image]
Some basics on the system for those unfamiliar:
It has a radial plunger engine driven pump, System pressures are typically 400 to 1450 psig.
It has a number of spool valve bodies solenoid controlled
It has strut actuators at the 4 wheel positions
it has 9 accumulators that have fluid on one side of the piston and trapped Argon (nitrogen was used for factory fill) on the other.
I posted a VOA of the factory Nissan Type-A suspension fluid here:Virgin Type-A
The Nissan fluid is no longer available in the USA.
Since this fluid is used in a 'hydraulic' system, I figured I'd post here as well.
The viscosity is light, close to an ISO32, but I'm not all that familiar with dedicated Hydraulic oils or what might have a similar additive pack to what the system was designed for.
Looking for input.
Drive it like you OWN it
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5106813 05/16/19 10:21 AM
Astro14 Offline
My Mercedes has a hydraulic assisted active suspension. The OEM fluid is Pentosin CHF-11s. Synthetic oil base.
Here are the specs: http://www.pentosin.net/specsheets/Pentosin_CHF_11S.pdf
Exactly the same viscosity as your VOA from the Nissan fluid.
CHF-11s can be found in liter, 5 liter, or 20 liter jugs on Amazon, Rock Auto, or at local parts stores (my local foreign car parts store carries it, for about $19/liter). 5 liter jugs on Amazon bring it down to about $13/liter.
It’s designed for suspensions, so detergency, viscosity, anti-foaming additives are all appropriate to your application.
Liquid Moly has a selection of suspension fluids, if you would like an alternative to the Pentosin.
https://products.liqui-moly.com/oil...23633-122929171.1558023633&trstate=0
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5106834 05/16/19 10:50 AM
V
VH45DE Offline OP
V
Thanks Astro. So this is what you use in the S600?
It is interesting, because I've been looking at the CHF11S product as an alternative fill for power steering fluid on my A6 Avant.
I'm hopeful that you or someone would be able to post a link to some VOAs on these hydraulic fluids.
Off topic: have you had to recharge your accumulators? Have you met up with Keith Bowers?
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5108455 05/18/19 11:08 AM
Astro14 Offline
Sorry for the delayed response, we are out in Saint Louis for my daughter’s medical school graduation.
Yes, I run the CHF-11s in the S600. I flush it every two years and Mercedes has a very good filter in the return line. The fluid is used for both the suspension system and the power steering system.
I don’t have a VOA on it, but after about two years, the color (clear green) starts to fade a bit and I reckon it’s about due for a change. The Mercedes STAR system allows me to “Rodeo” the car: run each suspension component through full articulation. I do this Rodeo while feeding pressurized* fresh fluid into the reservoir and catching the fluid in the return line in a waste container for a complete change and flush.
The valve blocks and other components in this system are subject to corrosion from moisture and degradation from debris (wear particles) in the fluid. Keeping the fluid clean helps preserve the life of some very expensive components.
I don’t know what Infiniti has for flushing regimen, but I would recommend similar.
*The Mercedes suspension pump requires fluid under pressure to prime. It suctions fluid from the reservoir. I have a 2 gallon pressure pump made by Motive (like a big power bleeder) that I use exclusively for suspension fluid.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Nissan Type A suspension fluid, need replacement [Re: Astro14] #5109171 05/19/19 08:55 AM
V
VH45DE Offline OP
V
Congrats to your daughter!
Filtration in the infiniti system also good. multi-stage, fine mesh in control valves and pleated paper also in return. Used sample had insolubles at 0.0 (would have expected nothing worse). I don't have rodeo mode (specialised nissan consult-i interface tool for the active ECU required)
curious if your system has separate pumps for PS and active? The infiniti system uses a tandem single shaft pump. the PS side is typical Dex iii recco.
funny you mention priming the the active pump. Infiniti recco's to vac the system after fluid fill to suck out the air bubbles. I once forgot to do that and of course had no pump head. fortunately an easy fix with my cooling system venturi vacuum.
I have also used the motive (dry) to pressurise cooling systems for leak checks.....good versatile tool.
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5109532 05/19/19 06:11 PM
Astro14 Offline
The pump for the S600 is a tandem pump. One pulley, two hydraulic chambers/circuits, two inlets, and two outlets. The fluid doesn't mix between PS and suspension.
I hadn't thought to vacuum the system to remove bubbles, but it makes sense. The Mercedes system has a total of 4 accumulators. They need replacing periodically. Pump noise is usually amoung the first symptoms.
Though my most recent pump noise has only gotten worse and I believe it's time for a pump. Not cheap. That's a project for next month...
By the way, I always liked the Q45. I always thought it was much more of a sports/muscle car than the Lexus competition. That active suspension must give it nice handling along with a plush ride.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Nissan Type A suspension fluid, need replacement [Re: Astro14] #5112120 05/22/19 07:43 AM
V
VH45DE Offline OP
V
Thanks for the replies.
Good luck with your pump, at least it sounds like you have continued parts support which I have heard is a legacy of Mercedes. Parts obsolescence is becoming near-prohibitive for me. I have to get creative at times, but I'm also a stickler for maintaining true to the car's provenance.
I'm biased of course, but I've always thought the 1st gen Q45 is underappreciated for what it is. Of course, very mediocre compared to today's car's in every category, except I would offer....'soul'. 25+ years ago it was waaaaay ahead of its time. I actually own two examples of active Q.
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5112121 05/22/19 07:44 AM
V
VH45DE Offline OP
V
PS- I got some Lubri-Moly central from Amazon, we will give it a go.
Re: Nissan Type A suspension fluid, need replacement [Re: VH45DE] #5114111 05/23/19 10:51 PM
N
nthach Offline
N
Supposedly the Nissan Active Suspension is based off Bosch or ZF designs - seeing how Bosch worked with Hitachi in the 1980s-1990s. I think Pentosin CHF 11S is a safe bet.
