Price of Diesel vs Gasoline 1980-2018
by SubLGT - 10/15/19 08:43 AM
Shield Rebate
by hatt - 10/15/19 08:43 AM
Intermittent shake
by supton - 10/15/19 08:11 AM
0W 20 in place of 5W 30 in First Gen CRV?
by Revrick - 10/15/19 07:29 AM
Servicing '13 Cadillac SRX AWD Haldex unit
by gd9704 - 10/15/19 06:15 AM
Possible WIX failure?!?
by AutoNotifier - 10/14/19 11:59 PM
Possible WIX failure?!? What could have happened?
by tony1679 - 10/14/19 11:48 PM
Anyone use a radiant barrier?
by daves66nova - 10/14/19 10:13 PM
FS- Corolla 15 inch hubcap
by bowlofturtle - 10/14/19 10:04 PM
tire wear from -0.5 degree of camber
by bowlofturtle - 10/14/19 09:48 PM
E85 fuel composition?
by JorgeSimon - 10/14/19 09:12 PM
Microsoft enables Tamper Protection for Home Users
by Jimmy9190 - 10/14/19 08:13 PM
Need rotary hammer for chiseling tile & glued floor laminate
by JLawrence08648 - 10/14/19 08:06 PM
Super Auto of2500x (57045) cut open
by Inlo - 10/14/19 08:01 PM
Detailed the new Renegade!
by HoosierJeeper - 10/14/19 07:34 PM
All My Filters
by kstanf150 - 10/14/19 07:07 PM
Hoffy1, joy786, robinasu, TriniDerian, kaspurr
69565 Registered Users
106 registered members (2015_PSD, Al, alarmguy, A310, 2004tdigls, 2009Edge, 8 invisible), 1,849 guests, and 53 spiders.
Topics295,985
Posts5,088,702
Members69,565
Most Online3,532
Jul 30th, 2019
03 Subaru WRX Valvoline VR1 10/30 196K miles #5113970 05/23/19 08:43 PM
T
TurboJW Offline OP
T
My teenage sons 2003 Subaru WRX that we bought with 191K miles now has 196K miles. Running Valvoline VR-1 10w30 oil and changed it at 3000 miles. Less than positive results on the UOA but I am not surprised honestly. It is living up to the name of "#Smurf_Turd".
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114012 05/23/19 09:27 PM
T
TurboJW Offline OP
T
Had trouble uploading file from my work computer. [censored] Windows 10 and Admin lockouts........
Attached PDF document
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114121 05/24/19 12:32 AM
X
xDoodles Offline
X
Do you plan on trying a 40wt oil or a different brand?
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: xDoodles] #5114151 05/24/19 01:44 AM
T
TurboJW Offline OP
T
When I took the sample we just used the VR-1 again. Upon seeing these results I will most likely look for a better/different oil. Not sure on which one just yet though.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114215 05/24/19 06:40 AM
L
Linctex Offline
L
Why did you choose VR-1?
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114219 05/24/19 06:44 AM
J
JustN89 Offline
J
Hm, it's not great but not horrible either. I would definitely try a different oil, maybe step up to a 40 as well. Is Rotella T6 5W-40 still highly regarded in the Subaru community? If so, might try to give that a run.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: Linctex] #5114243 05/24/19 07:19 AM
T
TurboJW Offline OP
T
I have used it in my 87 GN with good results and I keep a small stock on hand. Evidently the WRX doesn't like it though.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114266 05/24/19 07:50 AM
O
oil_film_movies Offline
O
The oil is not the problem. VR1 is a proven one, and 10w30 is a good weight.
Of course, a million other cheaper choices exist, so why not try something different. Best value and highest performance is Castrol or Mobil1 0w40 at walmart with better performance specs than most other oils to choose from.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114284 05/24/19 08:06 AM
A
ARCOgraphite Online Content
Online Content
A
Is this the 10W-30 Synthetic?
ow is the engine running? Any odd noises other than subaru noises?
The tr for fuel is a good sign.
What issues have you had?
Did he break the trans mount yet?
Kids can be hard on cars.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: ARCOgraphite] #5114299 05/24/19 08:19 AM
T
TurboJW Offline OP
T
[color:#FF9900]
Conventional
How is the engine running? Any odd noises other than subaru noises?
Runs good. No strange noises.
Agreed
Changed valve cover gaskets, complete AC system. No other issues running wise.
Not yet
He thinks its a rally car at times!! Ha!
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: oil_film_movies] #5114301 05/24/19 08:20 AM
T
TurboJW Offline OP
T
The VR-1 thinned out for the low mileage. I guess the boxer engine is harder on oil than others.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114339 05/24/19 09:06 AM
B
bulwnkl Offline
B
There’s more than just a “tr” of fuel in that oil.
Best fluid performance I had in the EJ-255 in my turbo Baja was Renewable Lube’s 5W40HD. That’s pricier than what you’re running, obviously.
Subie turbo engines of this vintage, particularly high-miles units, tend to want a 40-grade to maintain adequate oil flow to the upper areas of the engine at idle and low rpm. This isn’t about dynamic viscosity, it’s purely a matter of kinematic viscosity; getting the oil pressure high enough to push it up to and through things like turbo bearings.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: bulwnkl] #5114367 05/24/19 09:38 AM
O
O
Your lowered flashpoint indicates some fuel dilution. Fuel dilution will affect any oil, regardless of what brand it is.
The KV100 9.49 is within the SAE J300 definition for new oil of a 10w30 (9.3 to 12.5 is the range for new "30" oil). That's a normal viscosity swing engineers know about and design for.
I think your choice of oil is good, although a change to higher-performance Euro spec oils might help a little, as in M1 or Castrol 0w40, basically anything with the MB 229.5, Porsche A40 standards.
Sounds like you have no understanding of dynamic vs. kinematic viscosity. Nice try though.
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: TurboJW] #5114494 05/24/19 11:39 AM
B
Buzzinhalfdozen Offline
B
[Linked Image]
Sorry OP but I had to.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2
2015 Ford F150 5.0
Re: 03 Subaru WRX Valvoline VR1 10/30 196K miles [Re: Buzzinhalfdozen] #5114724 05/24/19 04:32 PM
T
TurboJW Offline OP
T
Originally Posted by Buzzinhalfdozen
[Linked Image]
You're not wrong!!! Lol. I'm an American car guy.
