ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
Pennzoil Ultra on Sale
by Nyati. 07/16/19 04:39 PM
Not All Mid-Grade Blended At the Pump
by RayCJ. 07/16/19 04:30 PM
Determining if car battery has much life left
by paulri. 07/16/19 02:47 PM
kohker oil recomendation
by 1978elcamino. 07/16/19 02:44 PM
Rear Diff Seal Leak?
by Pike51. 07/16/19 02:31 PM
Using synthetic to clean a crankcase
by NavyVet88. 07/16/19 02:26 PM
Next Project: 1968 Cub Cadet Model 72
by Phishin. 07/16/19 02:14 PM
Mother's CMX
by rooflessVW. 07/16/19 01:54 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
126 registered members (9050lx, 2010Civic, 4WD, 2009Edge, 14Accent, 12 invisible), 2,184 guests, and 19 spiders.
Topics291,966
Posts5,014,167
Members68,681
Most Online2,967
Mar 10th, 2019
Garage floor coating #5113841
05/23/19 06:43 PM
05/23/19 06:43 PM
Florida, Cape Coral
Eddie Offline OP
Eddie  Offline OP
Florida, Cape Coral
My concrete garage floor finish is looking really bad. The concrete surface is good but, the paint/coating is bad. I need suggestions and approximate prices to have the floor refinished. I am unable to do this so I must hire someone. Ed
2014 CX5 Touring 2.5L :-)
Re: Garage floor coating [Re: Eddie] #5113847
05/23/19 06:53 PM
05/23/19 06:53 PM
GoVols
kstanf150 Offline
kstanf150  Offline
GoVols
Hello Ed
I’ve never coated my garage floor, but the owner of the company I work for did his about 10 years ago
It was an epoxy compound product that he contracted through with HD
He was never satisfied with the results and now it’s peeling off the floor in several places.
Just FYI for ya
Good luck sir !👍
Re: Garage floor coating [Re: Eddie] #5113852
05/23/19 06:58 PM
05/23/19 06:58 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Unless it's brand new concrete, it's going to have oil stains. Concrete is porous so oil soaks deep down. Don't see how they can clean it well enough for the coating to stick long term.
Re: Garage floor coating [Re: Eddie] #5113873
05/23/19 07:16 PM
05/23/19 07:16 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Ed, suggest you read through the garage floor discussions over on the Garage Journal forums. They are to floors what this place is to oil.
Re: Garage floor coating [Re: Eddie] #5113876
05/23/19 07:18 PM
05/23/19 07:18 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
Tile it.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Garage floor coating [Re: Eddie] #5113879
05/23/19 07:21 PM
05/23/19 07:21 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Success depends heavily on prep, prior treatments and contamination, quality of the coating, and quality of application. It also depends heavily on how much moisture your concrete wicks.
In my garage, I used a single base epoxy from a big box store, followed instructions to the letter, let it cure a few extra days, it came off under my shoes and the tires immediately.
I sanded it all off, re-prepped everything, and used UCoat It 2-part epoxy. 14 years later and it's only gone from where the tires physically sanded it off from turning in place.
Various musings: http://hangfire.net
Re: Garage floor coating [Re: atikovi] #5113882
05/23/19 07:22 PM
05/23/19 07:22 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
From my understanding, they use an acid to clean the top enough so the paint / epoxy can grab onto the concrete, sealing the oil down below. You are not going to see it anyways (unless you use a clear sealant).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Garage floor coating [Re: Eddie] #5113984
05/23/19 08:57 PM
05/23/19 08:57 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Have it polished.
Me: 13' VW GTI 3 door 6 speed manual
Re: Garage floor coating [Re: Eddie] #5114008
05/23/19 09:24 PM
05/23/19 09:24 PM
Virginia
mattwithcats Offline
Virginia
To get oil stains up,
Pour some clay cat litter (not the scoopable kind) on the stain
Put on a pair of boots,
Shuffle feet through cat litter, grinding it into the concrete and stain.
Sweep up cat litter...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Garage floor coating [Re: Eddie] #5114098
05/23/19 11:12 PM
05/23/19 11:12 PM
MB, Canada
propuckstopper Offline
MB, Canada
I did my floor myself with some help from friends. The floor was 25 years old with stains and some cracks. We started by epoxy filling the cracks. When the exoxy crack filler was dry, we brought in a concrete grinding machine and went to town.
Next up, five or six good solid rounds of pressure washing with degreaser, just to clean up what the grinder might have left behind.
When the floor dried, it was time to apply a coat of primer, the epoxy colour coat, the flakes, and two coats of clear.
We used Legacy Products out of Florida, and the stuff looks amazing five years later. It's just beautiful. It is way more expensive than what you buy at Home Depot, but the process was way too labour intensive to ruin it with cheap product.
If I could do it all again, I would not change a thing. Conversely, a friend of mine did his floor with minimal cleaning and cheap product and it looks like [censored].
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
Re: Garage floor coating [Re: Eddie] #5114642
05/24/19 02:24 PM
05/24/19 02:24 PM
michigan
dirtymudder Offline
dirtymudder  Offline
michigan
I did my 20 year floor ( at the time) 9 years ago. lots of oil stains. So for cleaning up those stains I used acetone on the oil scrubbed it in and then clay cat litter on it. Then had a man come in and sandblast the floor. used a 2 part industrial epoxy then added paint flakes to it and followed up with a 2 part clear urethane. The urethane is more chemical resistant than clear epoxy. ( tires won't stain it ) It has been holding up very well ( I have a gravel driveway ) I have no peeling of the paint 9 years later.
Re: Garage floor coating [Re: Eddie] #5114737
05/24/19 04:48 PM
05/24/19 04:48 PM
Florida, Cape Coral
Eddie Offline OP
Eddie  Offline OP
Florida, Cape Coral
Lots of good and interesting information here and I thank you. Now to head over to the GARAGE JOURNAL FORUM for more information-thanks Langanobob. Ed
Re: Garage floor coating [Re: Eddie] #5114760
05/24/19 05:43 PM
05/24/19 05:43 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Several years ago, I was in a friend's man-cave and he had installed something similar to this:
https://www.costco.com/PlastiPro-Loc-Heavy-Duty-Garage-Floor-Tiles.product.100457737.html
Although, if I remember right, he said he got it through a third-party company through WalMart.
