Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
99 registered members (bdcardinal, 2009Caraman, 4WD, 2010Civic, austinlunsford, 11 invisible), 1,614 guests, and 24 spiders.
Topics297,566
Posts5,118,122
Members69,899
Most Online3,589
Nov 2nd, 2019
Garage floor coating #5113841 05/23/19 05:43 PM
E
Eddie Online Sleepy OP
OP Online Sleepy
E
My concrete garage floor finish is looking really bad. The concrete surface is good but, the paint/coating is bad. I need suggestions and approximate prices to have the floor refinished. I am unable to do this so I must hire someone. Ed
2014 CX5 Touring 2.5L :-)
Re: Garage floor coating [Re: Eddie] #5113847 05/23/19 05:53 PM
K
kstanf150 Offline
K
Hello Ed
I’ve never coated my garage floor, but the owner of the company I work for did his about 10 years ago
It was an epoxy compound product that he contracted through with HD
He was never satisfied with the results and now it’s peeling off the floor in several places.
Just FYI for ya
Good luck sir !👍
Re: Garage floor coating [Re: Eddie] #5113852 05/23/19 05:58 PM
A
atikovi Offline
A
Unless it's brand new concrete, it's going to have oil stains. Concrete is porous so oil soaks deep down. Don't see how they can clean it well enough for the coating to stick long term.
Re: Garage floor coating [Re: Eddie] #5113873 05/23/19 06:16 PM
L
Langanobob Offline
L
Ed, suggest you read through the garage floor discussions over on the Garage Journal forums. They are to floors what this place is to oil.
Re: Garage floor coating [Re: Eddie] #5113876 05/23/19 06:18 PM
M
maxdustington Offline
M
Tile it.
97 GMC RCLB K2500LD L30/4L60
99 Toyota Tercel CE 5EFE/C151
Re: Garage floor coating [Re: Eddie] #5113879 05/23/19 06:21 PM
H
HangFire Offline
H
Success depends heavily on prep, prior treatments and contamination, quality of the coating, and quality of application. It also depends heavily on how much moisture your concrete wicks.
In my garage, I used a single base epoxy from a big box store, followed instructions to the letter, let it cure a few extra days, it came off under my shoes and the tires immediately.
I sanded it all off, re-prepped everything, and used UCoat It 2-part epoxy. 14 years later and it's only gone from where the tires physically sanded it off from turning in place.
Various musings: http://hangfire.net
Re: Garage floor coating [Re: atikovi] #5113882 05/23/19 06:22 PM
P
PandaBear Offline
P
From my understanding, they use an acid to clean the top enough so the paint / epoxy can grab onto the concrete, sealing the oil down below. You are not going to see it anyways (unless you use a clear sealant).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Garage floor coating [Re: Eddie] #5113984 05/23/19 07:57 PM
skyactiv Offline
Have it polished.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Garage floor coating [Re: Eddie] #5114008 05/23/19 08:24 PM
M
mattwithcats Offline
M
To get oil stains up,
Pour some clay cat litter (not the scoopable kind) on the stain
Put on a pair of boots,
Shuffle feet through cat litter, grinding it into the concrete and stain.
Sweep up cat litter...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Garage floor coating [Re: Eddie] #5114098 05/23/19 10:12 PM
P
propuckstopper Offline
P
I did my floor myself with some help from friends. The floor was 25 years old with stains and some cracks. We started by epoxy filling the cracks. When the exoxy crack filler was dry, we brought in a concrete grinding machine and went to town.
Next up, five or six good solid rounds of pressure washing with degreaser, just to clean up what the grinder might have left behind.
When the floor dried, it was time to apply a coat of primer, the epoxy colour coat, the flakes, and two coats of clear.
We used Legacy Products out of Florida, and the stuff looks amazing five years later. It's just beautiful. It is way more expensive than what you buy at Home Depot, but the process was way too labour intensive to ruin it with cheap product.
If I could do it all again, I would not change a thing. Conversely, a friend of mine did his floor with minimal cleaning and cheap product and it looks like [censored].
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
Re: Garage floor coating [Re: Eddie] #5114642 05/24/19 01:24 PM
dirtymudder Offline
I did my 20 year floor ( at the time) 9 years ago. lots of oil stains. So for cleaning up those stains I used acetone on the oil scrubbed it in and then clay cat litter on it. Then had a man come in and sandblast the floor. used a 2 part industrial epoxy then added paint flakes to it and followed up with a 2 part clear urethane. The urethane is more chemical resistant than clear epoxy. ( tires won't stain it ) It has been holding up very well ( I have a gravel driveway ) I have no peeling of the paint 9 years later.
Re: Garage floor coating [Re: Eddie] #5114737 05/24/19 03:48 PM
E
OP Online Sleepy
E
Lots of good and interesting information here and I thank you. Now to head over to the GARAGE JOURNAL FORUM for more information-thanks Langanobob. Ed
Re: Garage floor coating [Re: Eddie] #5114760 05/24/19 04:43 PM
K
Kruse Offline
K
Several years ago, I was in a friend's man-cave and he had installed something similar to this:
https://www.costco.com/PlastiPro-Loc-Heavy-Duty-Garage-Floor-Tiles.product.100457737.html
Although, if I remember right, he said he got it through a third-party company through WalMart.
