Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
103 registered members (4WD, AdditiveOCD, 69GTX, 32319, 2015_PSD, 13 invisible), 1,665 guests, and 22 spiders.
Topics292,008
Posts5,015,110
Members68,692
Most Online2,967
Mar 10th, 2019
Torque converter drain bolt - No sealing washer? #5113518
05/23/19 01:40 PM
05/23/19 01:40 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
98 Expedition 5.4 4x4 4r100 tranny.
I just removed my torque converter drain bolt and was a little surprised to see no washer or thread sealant.
Is this the way it is supposed to be, just the bolt only?
Also anyone have torque for torque converter drain bolt, transmission pan bolts and transmission pan drain bolt?
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113703
05/23/19 04:18 PM
05/23/19 04:18 PM
Newport News, VA
sdowney717 Offline
sdowney717  Offline
Newport News, VA
Had 2 drains on a 1962 Buick transmission torque converter. They were 1/8" NPT plugs, so no sealer was used.
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113725
05/23/19 04:36 PM
05/23/19 04:36 PM
CA
The Critic Offline
The Critic  Offline
CA
On the MB 722.9 transmissions the torque converter drain plug uses a copper washer and thread locker.
Bdcardinal is the person who can help you with this.
2011 Toyota Prius 1.8L - 193K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113748
05/23/19 05:08 PM
05/23/19 05:08 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
No washer listed. The p/n is 87650-S with a description of "plug - dry seal tapered thread - 1/8-27"
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113771
05/23/19 05:30 PM
05/23/19 05:30 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Pipe plug?
2015 F150 2.7
2018 F350 6.2
Re: Torque converter drain bolt - No sealing washer? [Re: CT8] #5113795
05/23/19 06:09 PM
05/23/19 06:09 PM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
Pipe plug is not the same as Dry seal. Look it up.
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113911
05/23/19 07:48 PM
05/23/19 07:48 PM
Iowa
The_Eric Online content
The_Eric  Online Content
Iowa
It's just 1/8 pipe. Just screw it back in with no sealant - you don't want any foreign sealant goo inside the converter/trans
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
