7317 or 6607?
by cwilliamsws6 - 11/21/19 08:00 AM
Dana S110 Lube change
by Parkman - 11/21/19 07:21 AM
2003 GMC Sierra 1500HD 6.0L
by Redright9 - 11/21/19 07:17 AM
Canadian Tire Early Black Friday
by Snagglefoot - 11/21/19 07:07 AM
Viscosity at 85°C vs 100°C
by doyall - 11/21/19 06:58 AM
New tires for 1988 Toyota Pickup 4x4 22re
by Yota88 - 11/21/19 04:18 AM
Jeep Cherokee Rumble
by Nick1994 - 11/20/19 11:48 PM
2021 RAV4 Hybrid AWD hot rod
by AZjeff - 11/20/19 10:50 PM
0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Need new Binoculars
by FirstNissan - 11/20/19 09:47 PM
Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Andrewm72, FarmGuy, ImBoosted, XpressAuto, Jmpage388
69926 Registered Users
103 registered members (4WD, ARCOgraphite, Alfred_B, AandPDan, 53' Stude, 2009Edge, 11 invisible), 1,610 guests, and 23 spiders.
Topics297,712
Posts5,121,182
Members69,926
Most Online3,589
Nov 2nd, 2019
Torque converter drain bolt - No sealing washer? #5113518 05/23/19 12:40 PM
F
Fitz98 Offline OP
F
98 Expedition 5.4 4x4 4r100 tranny.
I just removed my torque converter drain bolt and was a little surprised to see no washer or thread sealant.
Is this the way it is supposed to be, just the bolt only?
Also anyone have torque for torque converter drain bolt, transmission pan bolts and transmission pan drain bolt?
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113703 05/23/19 03:18 PM
sdowney717 Offline
Had 2 drains on a 1962 Buick transmission torque converter. They were 1/8" NPT plugs, so no sealer was used.
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113725 05/23/19 03:36 PM
The Critic Offline
On the MB 722.9 transmissions the torque converter drain plug uses a copper washer and thread locker.
Bdcardinal is the person who can help you with this.
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113748 05/23/19 04:08 PM
bdcardinal Offline
No washer listed. The p/n is 87650-S with a description of "plug - dry seal tapered thread - 1/8-27"
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113771 05/23/19 04:30 PM
CT8 Offline
Pipe plug?
Re: Torque converter drain bolt - No sealing washer? [Re: CT8] #5113795 05/23/19 05:09 PM
R
ragtoplvr Online Content
Online Content
R
Pipe plug is not the same as Dry seal. Look it up.
Re: Torque converter drain bolt - No sealing washer? [Re: Fitz98] #5113911 05/23/19 06:48 PM
T
The_Eric Online Content
Online Content
T
It's just 1/8 pipe. Just screw it back in with no sealant - you don't want any foreign sealant goo inside the converter/trans
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
