0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Need new Binoculars
by FirstNissan - 11/20/19 09:47 PM
Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
81 registered members (4WD, 69Torino, 69GTX, 2004tdigls, 2010Civic, 5 invisible), 1,382 guests, and 25 spiders.
Topics297,700
Posts5,120,944
Members69,924
Most Online3,589
Nov 2nd, 2019
Oil extractor on Honda r18 engine #5112707 05/22/19 05:35 PM
J
JunkdrawerDog Offline OP
J
Does anyone have experience using an oil extractor on an r18 engine as used in 2006-2015 Civic or 2016 to present HRV ? What brand and model extractor? Any difficulty getting extractor tubing down dipstick tube. How much oil were you able to remove? Thanks in advance for comments!
Re: Oil extractor on Honda r18 engine [Re: JunkdrawerDog] #5112729 05/22/19 05:55 PM
T
Talent_Keyhole Offline
T
I have watched YT videos of people using them to suction transmission fluid from a pan. It leaves a fair amount behind. MACTFORDEDGE on youtube has one video and recommendation. Along with the 10-20% of oil remaining after a normal oil change, why would you want to leave even more behind. I recently sampled a new oil and within 15 minutes of changing the oil by dropping the drain plug and filter. It was contaminated with wear metals 10x increase in hard particluates and silicon. You could not see through the sample bottle even with a light.
Re: Oil extractor on Honda r18 engine [Re: Talent_Keyhole] #5112746 05/22/19 06:08 PM
I
Imp4 Offline
I
How could you possibly know this to be the case?
Did you get an oil analysis completed on an oil only run for 15 minutes????
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Oil extractor on Honda r18 engine [Re: JunkdrawerDog] #5112764 05/22/19 06:26 PM
dblshock Offline
go to a real good hardware store and buy a 24" brass tube with OD 5/32" check that just fits inside the last extractor tube then
flatten the tip to mimic the oblong dipstick. I did this for my '16 Civic works great drawing hot oil.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: Oil extractor on Honda r18 engine [Re: JunkdrawerDog] #5112933 05/22/19 09:23 PM
U
user52165 Offline
U
I've installed this model on countless Honda and Hyundai, Attach a hose and drain directly into a jug. No mess, no fuss, easy disposal. You have to get under to remove the filter so why not go one step further?
https://www.amazon.com/Fumoto-F106N-Drain-Valve-Nippple/dp/B07D995XRF/ref=sr_1_1?crid=1OM5KATW12FVK&keywords=fumoto+f106n&qid=1558581475&s=gateway&sprefix=fumoto%2Caps%2C205&sr=8-1
Re: Oil extractor on Honda r18 engine [Re: user52165] #5113020 05/22/19 11:59 PM
U
UncleDave Online Content
Online Content
U
You only have to get under the car every other time - and depending on the filter location may never need to go under the car at all. I don't with my ridgeline.
The extractor is way easier and incredibly fast and clean for a top side change - 12 minutes from drain to refill.
UD
https://www.youtube.com/watch?v=c-URwerwX6U&t=148s
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Oil extractor on Honda r18 engine [Re: Imp4] #5113246 05/23/19 07:56 AM
T
T
That is what I said, or tried to say., I sampled new oil, dumped old oil and filter, ran new for 15 minutes on the highway, and sampled again. It is refereed to as Short Volume Oil Changes. This is well documented in articles and testing at Machinery Lubrication. This explains why TBN drops so quickly after a change. Engine oil testing labs, typically flush their test engines 3-4 times to get a near 99.8% clean oil and prevent fluid mixing.
Re: Oil extractor on Honda r18 engine [Re: UncleDave] #5113439 05/23/19 11:26 AM
J
J
UD
This. My goal is to never go under the car again. I want to alternate between getting oil and filter changed at the local independent Honda garage and doing oil change only myself with extractor.
Re: Oil extractor on Honda r18 engine [Re: Talent_Keyhole] #5114317 05/24/19 07:33 AM
I
Imp4 Offline
I
I think the intent of short volume oil changes is for industrial applications where the volume of oil being changed (sometimes hundreds of gallons) or the practically of doing a complete exchange are a challenge.
Niether of these conditions exists in your circumstance.
You are just tinkering and not producing anything of value based on your application.
But have fun!!!
cheers
