$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
112 registered members (2young2retire, ABomb369, 2012AccentSE, 28oz, 330indy, 14Accent, 8 invisible), 2,033 guests, and 15 spiders.
Topics301,694
Posts5,200,695
Members70,756
Blue Devil Flush VS Prestone Flush & Cleaner #5112523 05/22/19 02:29 PM
BlueOvalFitter Offline OP
I have never used either one of these. But, I have used Prestone SUPER FLUSH exclusively in the past. But, no one sells it locally. It can only be bought online.
I have heard very good things about Blue Devil, but nothing about the Flush & Clean. A friend is doing a coolant flush this weekend and asked me about these 2 flushes. Opinions?
https://prestone.com/products?detail=AS105Y
https://gobdp.com/product/radiator-flush-00204/
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112536 05/22/19 02:41 PM
E
Ed_Flecko Offline
E
Given all of the potential problems you might create (i.e., introducing tap water with minerals that will likely cause corrosion, "cleaning" chemicals that the cooling system was never designed to handle...the list goes on), why do you (or your friend) want to "flush" a cooling system?
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112546 05/22/19 02:49 PM
lewdwig Offline
Did a Prestone Super Flush on my daughter's Subaru...I learned how to replace the radiator and heater core...YMMV.
2001 Subaru Forester L
2003 Buick Park Avenue
2015 Ford Escape
Google search:
(search terms here) site:bobistheoilguy.com
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: Ed_Flecko] #5112551 05/22/19 02:54 PM
Ed
Okay, let me be more specific.
I have been doing coolant flushes on vehicles for well over 30 years +. I still used Prestone flushing products back then. On some vehicles I even installed the Prestone flush TEE.
Fast forward to today's times. For the last 20 years or more I have used DISTILLED WATER ONLY to flush and fill, AFTER flushing the chemicals out of the system.
WHY flush the coolant system? He has 181K miles on his 2K Silverado. The last time it was flushed and had new coolant was at 62K miles. Now, how would YOU handle this? IMHO, a flush would be the BEST solution in this case.
Oh, BTW, you might ask, with my exp. doing flushes, why ask? Because, I have NEVER used either one of the aforementioned products. I wanted to know which is better, or used more.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: lewdwig] #5112566 05/22/19 03:13 PM
I was a pipefitter/welder in the HVAC field for 25+ years (Cooling towers, chillers, boilers, AHU's, etc.) Sometimes our service crews had to clean cooling towers and used a solution that was mixed like 1 gallon to 100 gallons of water. One of the guys used some of the solution to flush his radiator. After using/flushing the solution his radiator had so many holes in the radiator and heater core it looked like a sprinkler system. He too had to replace his radiator and heater core. grin
Oh, I did something similar but only had to replace the radiator.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112588 05/22/19 03:29 PM
K
kschachn Online Content
Online Content
K
WHY flush the coolant system? He has 181K miles on his 2K Silverado. The last time it was flushed and had new coolant was at 62K miles. Now, how would YOU handle this? IMHO, a flush would be the BEST solution in this case..
Like many people who post here about "cleaning" something, it doesn't appear that you know for sure it needs flushing with a cleaner. Do you?
In the past 35 years of maintaining my vehicles and most recently in the last 1.2 million miles on my current vehicles I have never used a cleaner or flush. Below is my old Sienna during the last timing belt and water pump change at 412,000 miles, you can see the water pump cavity. It is pristine and so is the rest of the system. Have you looked at the system and determined it needs to be cleaned?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112594 05/22/19 03:33 PM
M
Mad_Hatter Offline
M
Never used the Blue Devil but I have used Prestone FC. Never had a problem with it. It's a very mild flush that uses sodium citrate which is a weak acid. The Prestone super flush incorporates stuff like surfactants to clean out oil etc. Don't know what's in Blue Devil as the last time I checked they listed their ingredients as "proprietary" on their SDS.
Bars works pretty well too...
I wouldn't use anything harsher then a Prestone or Bars flush (Bars uses a detergent type cleaning agent). And I would be leery about the BD product simply because you don't know what's in it. Given the age of your friends system and how long it's been since it was last flushed, it is possible a good thorough cleaning could "reveal" a leak somewhere. I would consider doing water at first then if that doesn't work to your satisfaction, try the Prestone or Bars.
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112631 05/22/19 04:14 PM
Just a random video I found on YT about how a Ford Tech uses a chemical flush every time he does a coolant flush.
Just sayin'...................... whistle
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112634 05/22/19 04:21 PM
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5112762 05/22/19 06:24 PM
A
atikovi Offline
A
30 years ago engines were mostly iron and coolant was changed yearly because of rust and scale buildup from low tech antifreeze. Now most engines are aluminum and some antifreeze is good for 10 years. Chemical flushes are just not needed.
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: atikovi] #5112786 05/22/19 06:48 PM
M
Mad_Hatter Offline
M
True, if you've been the sole owner of the vehicle and have been diligent about changing the fluid out regularly and using only distilled water or a premix but not everybody fits that description. Fact is, many people buy their cars used and have no idea what kind of service history was adhered to by the previous owner(s), so a chemical flush makes sense just to get things started out on the right foot.
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5113274 05/23/19 08:29 AM
K
Online Content
K
Of course that same Ford tech also may sell unneeded throttle body cleaning, transmission flushes, BG oil and fuel additives, paint sealers and glass VIN etching.
Just sayin',
1994 BMW 530i, 251K
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5113289 05/23/19 08:44 AM
doitmyself Offline
I feel your pain, BlueOvalFitter. The ONLY good response you might get is from someone that has actually used those two products.
I agree with the unsolicited advice that well maintained engines on modern coolant don't require chemical flushing. Lesser maintained systems probably benefit from cleaning. To share my anecdote: I maintain a Kohler generator at my workplace with a small 4 cyl. Ford engine (iron block, copper-brass radiator) that specifies conventional iat coolant (I use Zerex). Even with 2 year changes, I started noticing some white krap buildup through the radiator cap hole. I tried both Zerex flush products. The milder one did nothing. The "stronger" one DID remove the white deposits.
Maybe try to compare the ingredients of your two products and choose the one that seems stronger. Best of luck to you.
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: BlueOvalFitter] #5113416 05/23/19 11:00 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
IMO it’s not necessary unless something has happened, like oil in the system.
A 2k Silverado should have had dex cool from the start. So no silicates. A very clean coolant if kept properly.
The engine is likely aluminum, so no rust or cast
Iron dirt.
I’m just not seeing the need. Flushing with distilled, sure. If the cooling system isn’t working well? Ok. But
Otherwise? Meh.
If dex was mixed with something else, it’s a possible different story.
OATs apparently don’t build their protective layer as fast as silicates and phosphates. Flushes could interrupt or remove that layer. Not sure that is desirable.
So not clear I’d want to bother with flushes unless there was a real reason.
Re: Blue Devil Flush VS Prestone Flush & Cleaner [Re: atikovi] #5113432 05/23/19 11:19 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
HOATs and better last 5-10 years in those cast iron engines with aluminum radiators and heater cores.
This was my 81 240D, taken just a few weeks ago. All original, hoses, radiator, everything. G-05.
[Linked Image]
So cast iron by itself isn’t even a determinant, IMO. Modern coolants that aren’t mixed is the best way to go.
