Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
125 registered members (69GTX, 2015_PSD, 4WD, 07hemi, 01rangerxl, 14 invisible), 1,825 guests, and 24 spiders.
Topics292,007
Posts5,015,095
Members68,692
Most Online2,967
Mar 10th, 2019
Cub Cadet LTX1050VT keeps shredding mower belts #5111507
05/21/19 04:27 PM
05/21/19 04:27 PM
NY, USA, etc.
oilpsi2high Online content OP
oilpsi2high  Online Content OP
NY, USA, etc.
I have an 03 Cub Cadet with the 50" deck an 3 blade setup. This thing destroys mower belts. I go through 2 or 3 OEM belts a season. My lawn is 2-3 acres and kind of bumpy, but it shouldn't be eating belts at this rate. The mower only has 242 hours on it.
I'm going to pull the deck off and replace the belt (again).
Is anyone familiar with these, or know anything I should check or adjust? Each blade spins fine, no binding or anything.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111518
05/21/19 04:39 PM
05/21/19 04:39 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Any pulleys rusted? Mis-aligned? Are you buying quality belts or EBAY specials?
2015 Ford F250 w/Powerstroke
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111533
05/21/19 04:54 PM
05/21/19 04:54 PM
High Tax Illinois
oldhp Online content
oldhp  Online Content
High Tax Illinois
How is the belt tensioner? Could it be letting the belt slap against a fixed guard or something bracket eating the belt???
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait."
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: Donald] #5111535
05/21/19 04:55 PM
05/21/19 04:55 PM
Wethersfield Connecticut
Convert Offline
Convert  Offline
Do any of the bearings on the pulleys on the deck need to be replaced?
TOMB
TOMB
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111592
05/21/19 05:48 PM
05/21/19 05:48 PM
NY, USA, etc.
NY, USA, etc.
Well, I think I found the problem.
I don't think this deck was ever cleaned. Not once since 2003.
Two of the blades I couldn't even turn by hand due to grass buildup on both the top and bottom of the deck.
I'll post before and after pics shortly.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111631
05/21/19 06:37 PM
05/21/19 06:37 PM
MN
Tman220 Offline
Tman220  Offline
MN
2-3 Belts a season and you have never bothered to clean out the top of the deck? All the grass and leaves insulating the belt and over heating it and causing it to fail? Don't forget to pump some grease into the spindles while you have it all a part
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 160k
2004 Civic LX M5 178k
2007 Camry 2.4 232k
2016 Victory Vegas
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111754
05/21/19 08:40 PM
05/21/19 08:40 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
I looked at buying this Cub model and saw reviews about the belt issues so I steered clear. Might see if a dealer can get a very strong kevlar belt but it may not matter.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111760
05/21/19 08:46 PM
05/21/19 08:46 PM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Can't blame the machine for a lack of maintenance. If you never clean the deck i can only imagine how bad the blades look.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113380
05/23/19 11:12 AM
05/23/19 11:12 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I'm still trying to figure out how all those belt replacements got done without noticing this..
I'm assuming we're talking about the belt on the deck itself and not the PTO to the deck belt.
2017 Ram 1500 4x4, 3.6L.
2016 Nissan Quest SV (Babe magnet IV)
2015 Nissan Versa 1.6 S
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113559
05/23/19 02:12 PM
05/23/19 02:12 PM
NY, USA, etc.
NY, USA, etc.
This is my landlord's mower, not mine.
Anyway, I gave it a full once-over and did the following maintenance for him:
Sharpened and balanced blades
Cleaned and oiled deck
Greased spindles
Replaced drive belt (had to remove deck, hydrostatic clutch, trans fan, pulley, and bend the engine pulley keeper tabs back just to get this belt off.)
Replaced mower belt
Oiled chassis
It's due for new blades, but I think we can get another year or two out of these after sharpening. One of the spindles' hubs are almost rounded off, and the hydrostatic trans is leaking fluid. I checked but didn't see anywhere to add (I guess it's a sealed unit. FAIL.)
This thing runs like a new machine now. The deck vibrations are gone as well.
Hopefully we can at least get through this year without any more repairs.
[Linked Image]
[Linked Image]
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113649
05/23/19 03:33 PM
05/23/19 03:33 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Just a note to say that belt slip is tops when it comes to things that kill belts. They can take amazing loads, but are intolerant of heat. Make sure the tension is sufficient.
Also, bad bearings can heat the pulley and kill a belt. .
