Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
goldenjava, Spuzzum, ta249, bobsauto62, Ramz
69044 Registered Users
27 registered members (14Accent, ArrestMeRedZ, 4WD, 2002 Maxima SE, bdcardinal, 4 invisible), 723 guests, and 21 spiders.
Topics293,713
Posts5,045,449
Members69,044
Most Online3,532
Jul 30th, 2019
Grease for Toyota Tundra #5113312 05/23/19 10:09 AM
diyjake Offline OP
What grease do you guys use on your pick up trucks? I want to grease the driveshaft and suspension on my brother in law's 2009 Tundra. This is what I was planning on using since it is what I usually have at home:
Synthetic Multi-Purpose Grease NLGI #2
https://www.amsoil.com/shop/by-product/grease/synthetic-multi-purpose-grease-nlgi-2/?code=GLCCR-EA
Re: Grease for Toyota Tundra [Re: diyjake] #5113324 05/23/19 10:23 AM
CT8 Offline
What grease does the owners manual spec?
Re: Grease for Toyota Tundra [Re: diyjake] #5113335 05/23/19 10:32 AM
J
JMJNet Offline
J
That Amsoil grease is fine.
  • 2017 Toyota Sienna
Re: Grease for Toyota Tundra [Re: CT8] #5113340 05/23/19 10:36 AM
diyjake Offline OP
To be honest I am not sure. He doesn't have a owners manual in the truck. I'll have to google it.
Re: Grease for Toyota Tundra [Re: diyjake] #5113374 05/23/19 11:07 AM
diyjake Offline OP
if someone has another recommendation I am all ears. I like using Amsoil because I can get it locally.
Re: Grease for Toyota Tundra [Re: diyjake] #5113394 05/23/19 11:22 AM
K
kschachn Offline
K
Any random recommendation is pretty worthless, you need to know what the manufacturer specifies and work from there.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: Grease for Toyota Tundra [Re: diyjake] #5113413 05/23/19 11:57 AM
drtyler Offline
From owners manual for 09 Tundra, pg 614, propeller shaft lubrication:
Spider: Lithium based chassis grease, NLGI No. 2
Slide yoke: Molybdenum disulfide lithium base chassis grease, NLGI No.2 or lithium base chassis grease, NLGI No.2
Re: Grease for Toyota Tundra [Re: drtyler] #5113434 05/23/19 12:24 PM
diyjake Offline OP
Thanks!
Re: Grease for Toyota Tundra [Re: diyjake] #5113437 05/23/19 12:26 PM
N
NYSteve Offline
N
There's quite a rabbit hole with Toyota grease recommendations. To do it by the book, you need 2 different greases. Most people just go with a #2 they like.
Re: Grease for Toyota Tundra [Re: diyjake] #5113461 05/23/19 12:46 PM
diyjake Offline OP
I wonder how a quick lube shop would grease it. I am sure they use a generic grease for everything.
Re: Grease for Toyota Tundra [Re: NYSteve] #5113471 05/23/19 12:59 PM
supton Offline
That is my recollection too. And many threads on it (not on BITOG). I elected to go with a #2 for all. I think it's a Mobil grease, I can tell from the red goo that likes to leak from the grease gun (but to be honest I am still using the same tube five years later).
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 209k, his
Re: Grease for Toyota Tundra [Re: diyjake] #5113498 05/23/19 01:24 PM
J
jrvn Offline
J
MYSTIC JT6 or any #2 grease
Re: Grease for Toyota Tundra [Re: diyjake] #5113512 05/23/19 01:34 PM
Chris142 Offline
Ha! Most don't even have a grease gun! Last time I saw jiffy lube use a grease gun the kid was trying to push grease into a brake bleeder screw!
All my cars get Valvoline moly fortified grease in every thing. Yes even U-Joints! I seem to get well over 100k out of the cheap precision U-Joints wit this grease.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Grease for Toyota Tundra [Re: diyjake] #5113619 05/23/19 03:11 PM
Dave9 Offline
I also use Valvoline synthetic w/moly #2 on everything metal-metal. The word suspension was used though, on metal to rubber I use Raybestos silicone brake grease. I mean rubber bushings, having a rubber boot on a ball joint or tie rod end does not count, lol.
Re: Grease for Toyota Tundra [Re: diyjake] #5113781 05/23/19 05:48 PM
G
Gebo Offline
G
i use this for the moly slide yoke (5% moly):
Synthetic Polymeric Off-Road Grease, NLGI #2
[Linked Image]
I use this for the spider:
Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2
[Linked Image]
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
(Subject to Change as the Wind Blows)
