My 2007 altima 3.5s needs rear coil springs. I pretty much always order from rockauto due to being canadian (they handle duty/taxes and are waaaaay cheaper than parts up here in canada).
Rockauto has 2 choices for me;
MOOG® Problem Solver® for $46.79 USD or
ACDelco Professional for $67.99 USD
Q1. any advice on which is a better quality part would be appreciated.
Q2. will the ride height be the same with both of these springs? I found one single review when googling the part number, which claims that the acdelco has 7 "coils" vs 6 on the moog, and claims the ride height is higher than stock.
https://www.amazon.com/gp/customer-...dp_d_rvw_ttl?ie=UTF8&ASIN=B07B3MV1PS
Q3. can replacing only rear coil springs increase (rear) ride height, or are other adjustments necessary?
Q4. one mechanic told me an alignment is required after this job, another said its not necessary. thoughts?
Thanks!
Thanks!
