2012-2014 Lexus GS350 AWD Reliability?
by GZRider - 10/17/19 10:28 PM
Switch to High Mileage Oil or No?
by Blake1107 - 10/17/19 10:21 PM
Found this funny
by taztheman - 10/17/19 10:04 PM
How much gas to start a 3L or larger engine?
by paulri - 10/17/19 09:54 PM
Syneresis, learned a new word today!
by Cujet - 10/17/19 09:28 PM
What is more important in an oil?
by Rglossip - 10/17/19 08:03 PM
Chevy 2.4 Oil Burner Oil/Filter Change?
by GaryPoe - 10/17/19 07:57 PM
2016 F150 2.7 UOA 4k
by tomcruise - 10/17/19 07:13 PM
Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB
by Whimsey - 10/17/19 07:01 PM
How To Avoid Deer?
by Passport1 - 10/17/19 06:41 PM
Mazda6 P0401 code
by miden851 - 10/17/19 06:15 PM
2004 Crown Vic shock/ struts recommendation
by umungus1122 - 10/17/19 06:12 PM
Undercarriage pics of my 2003 E46 330Ci ZSP
by SLO_Town - 10/17/19 06:11 PM
Porter Cable air compressor not shutting off
by JLawrence08648 - 10/17/19 06:06 PM
OCI older car, modern oil
by VQLT - 10/17/19 05:24 PM
ZAINO Products
by BlueOvalFitter - 10/17/19 05:17 PM
BMW N63 engines... Valve seals
by Ndx - 10/17/19 04:53 PM
jmichels, Collins92, Paul_Millner, kelsdawnj, Emtp1990
69591 Registered Users
70 registered members (4WD, 19jacobob93, alchargo, 2015_PSD, 8 invisible), 1,424 guests, and 19 spiders.
Topics296,121
Posts5,091,494
Members69,591
Most Online3,532
Jul 30th, 2019
9gtronic transmission fluid for 7gtronic plus #5112962 05/22/19 11:06 PM
J
JP69 Offline OP
J
https://blog.fcpeuro.com/mercedes-benz-722.9-transmission-service-modifications
FCPEuro has some interesting recommendations for servicing Mercedes 7gtonic plus transmissions. Currently, the 7gtronic plus (2nd gen. 7 speed) uses fluids listed in MB sheet 235.15.
The 9gtronic 9 speed transmission uses fluid speced under MB sheet 235.17. FCPEuro recommends using the 9 speed transmission fluid on the 7gtronic, basically dumping 235.15 and replacing it with 235.17.
What are your thoughts on FCPEuro's recommendation?
Re: 9gtronic transmission fluid for 7gtronic plus [Re: JP69] #5113096 05/23/19 06:24 AM
B
BMWTurboDzl Offline
B
Typo: It's 236.xx not 235.xx
I don't know why FCP is recommending. I would ask. Perhaps they were made aware of some "unofficial" backwards compatibility?
435i
Re: 9gtronic transmission fluid for 7gtronic plus [Re: BMWTurboDzl] #5113630 05/23/19 03:16 PM
J
JP69 Offline OP
J
I asked, will update.
I thought the blog post was extremely informative. Seems like Mercedes was making multiple developments when upgrading from 7g to 7g+.
Didn't realize the OEM filter was so advanced and better than aftermarket filters.
If you got an early model 7g+, and didn't get the upgraded filter and deeper pan, IMO it's worth the money to upgrade to deeper pan with the advanced filtron filter.
The 7g+ is very close to the 9g. In fact I believe 7g+ has the hardware to do 9 speeds. The similarity of the transmissions may be why the 9 speed fluid could work in 7g+.
