2012-2014 Lexus GS350 AWD Reliability?
by GZRider - 10/17/19 10:28 PM
Switch to High Mileage Oil or No?
by Blake1107 - 10/17/19 10:21 PM
Found this funny
by taztheman - 10/17/19 10:04 PM
How much gas to start a 3L or larger engine?
by paulri - 10/17/19 09:54 PM
Syneresis, learned a new word today!
by Cujet - 10/17/19 09:28 PM
What is more important in an oil?
by Rglossip - 10/17/19 08:03 PM
Chevy 2.4 Oil Burner Oil/Filter Change?
by GaryPoe - 10/17/19 07:57 PM
2016 F150 2.7 UOA 4k
by tomcruise - 10/17/19 07:13 PM
Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB
by Whimsey - 10/17/19 07:01 PM
How To Avoid Deer?
by Passport1 - 10/17/19 06:41 PM
Mazda6 P0401 code
by miden851 - 10/17/19 06:15 PM
2004 Crown Vic shock/ struts recommendation
by umungus1122 - 10/17/19 06:12 PM
Undercarriage pics of my 2003 E46 330Ci ZSP
by SLO_Town - 10/17/19 06:11 PM
Porter Cable air compressor not shutting off
by JLawrence08648 - 10/17/19 06:06 PM
OCI older car, modern oil
by VQLT - 10/17/19 05:24 PM
ZAINO Products
by BlueOvalFitter - 10/17/19 05:17 PM
BMW N63 engines... Valve seals
by Ndx - 10/17/19 04:53 PM
jmichels, Collins92, Paul_Millner, kelsdawnj, Emtp1990
69591 Registered Users
85 registered members (92saturnsl2, 4WD, AZjeff, bdcardinal, 9 invisible), 1,656 guests, and 19 spiders.
Topics296,121
Posts5,091,480
Members69,591
Most Online3,532
Jul 30th, 2019
'02 BMW 530i, Castrol Edge 0W-40, 3,850 miles #5112890 05/22/19 09:36 PM
Q
Quattro Pete Offline OP
Q
Time in service: 13 months (April 2018 - May 2019)
Driving conditions: lots of short tripping.
Oil filter: Mann (OEM)
Air filter: Mann (OEM)
Make-up oil:
- 0.5 qt Castrol Edge 0W-40
- 0.5 qt Castrol Edge HM 10W-40
- 0.5 qt Pennzoil Platinum Euro 5W-40
[Linked Image]
[Linked Image]
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113109 05/23/19 06:36 AM
B
BMWTurboDzl Offline
B
Nice ride!
435i
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113135 05/23/19 06:54 AM
JohnnyJohnson Online Content
Online Content
Wear Metals suck. If it was a different oil go back to the oil in history 1.
2004 Corolla 136181
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76552
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113148 05/23/19 07:14 AM
O
OVERKILL Online Content
Online Content
O
EP H2O and IR Fuel both are significantly higher than no previous runs.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113222 05/23/19 08:26 AM
A
addyguy Offline
A
Wear metals have jumped up a lot, especially lead and aluminum. Lots of short trips in cold weather I would say is to blame.
2010 Kia Soul 2U - 2.0L I-4, auto; 146k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: OVERKILL] #5113243 05/23/19 08:54 AM
Q
Q
I sent some clarification questions to Wearcheck on this. For one, I don't understand the difference between IR Fuel and IR (Gasoline).
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: addyguy] #5113250 05/23/19 09:00 AM
Q
Q
Yes, that's part of it. Here are the culprits, IMO:
1. The car is no longer garaged, so cold starts during winter are much colder than what they used to be. Plus, the amount of short tripping (6 miles) has gone up.
2. I was experiencing rough idle (as if some cylinders were not firing) on cold startup plus some heavy smoke out of tailpipe on occasions. The shop couldn't replicate the smoke, but stated that my CCV may have been plugged up. CCV on this engine is a weak spot, so I told them to go ahead and replace it.
3. I ran a bottle of Berryman Chemtool through the tank just before taking this sample. From my experience, often times running such fuel system cleaner will manifest itself as increased wear metals on a UOA.
The main reason for doing this UOA was to test for coolant presence as I was not sure if I had a potential head gasket issue on my hands.
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113278 05/23/19 09:32 AM
Q
Q
Here is my exchange with them:
1. What is IR (EP H2O)? It seems to be significantly higher in this sample compared to my older samples. What's the reason for it?
2. What is Infra-red Fuel? It does not look like it was tested in older samples. Why is it so high? How does it differ from IR (Gasoline)?
Originally Posted by WearCheck
You are looking at unconverted raw data* that has no significance. Those things are not on the report for that reason and are not used in our analysis. FTIR ‘measures’ those parameters but we do not calibrate for them. It just get loaded into the lab system on the data transfer.
Difference between current and histories is that we replaced the FTIR those earlier readings were taken on. Different program, and the methods have evolved.
*he is referring to the data in the second image I included in my OP.
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113283 05/23/19 09:39 AM
Q
Q
BTW, one thing that I found a little surprising was viscosity at 100C, despite adding 1.5 quarts of make-up oil. I know Edge 0W-40 is on the lower end of 40-grade to begin with, but still. My guess is the oil took a serious beating, and fuel dilution and moisture condensation did it in during winter, even if it all burned off by the time Spring came and I pulled this sample.
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113345 05/23/19 10:41 AM
A
addyguy Offline
A
Most Euro 40-weight oils are about 12.8-13.2 cst; so this oil hasn't actually sheared much, especially considering winter short trips.
The B-12 in the gas during winter, again with short trips, explains the lead.
Oil/filter TBD
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: addyguy] #5113358 05/23/19 10:54 AM
Q
Q
FYI, the other two samples (History1, History2) were on a Euro 40-grade oil as well (PU 5W-40), and subject to fair amount of short tripping also, yet viscosity stayed higher. But yeah, this winter the car was subject to even harsher conditions, having to sit outside.
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5113708 05/23/19 04:20 PM
A
addyguy Offline
A
Car starts in the 'colder' outside, it runs richer for longer warming up. Plus, this winter in the northwest was much colder and snowier than normal, so cold, low-speed driving was a bigger part of the picture.
Oil/filter TBD
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Quattro Pete] #5114031 05/23/19 09:47 PM
G
Garak Offline
G
I believe you have a very good handle on the culprits over this OCI.
Plain, simple Garak.
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: JohnnyJohnson] #5114171 05/24/19 04:08 AM
B
Bjornviken Offline
B
+1
Re: '02 BMW 530i, Castrol Edge 0W-40, 3,850 miles [Re: Bjornviken] #5114257 05/24/19 07:41 AM
Q
Q
+1
It's not the oil. I already explained it up above.
