Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
53 registered members (53' Stude, bbhero, AlienBug, bernau, Best F100, 8 invisible), 775 guests, and 22 spiders.
Topics290,259
Posts4,987,243
Members68,413
Most Online2,967
Mar 10th, 2019
That's not 30-36 lb/ft #5112837
05/22/19 08:29 PM
05/22/19 08:29 PM
Central Maryland
HangFire Offline OP
HangFire  Offline OP
Central Maryland
Did the first new-to-me 2010 Camry oil change today. Had to get the long wrench to get the oil pan bolt out. The crush washer was riveted (see pic), the inner side extruded in one direction and the outer edge the other.
Likewise the oil filter cap didn't want to move with reasonable force. Judging by my effort and the length of the wrench, it took about 200 lb/ft to get it off. Once off, I had to pound off the MotivX filter socket from the cap.
More than a few ugga-duggas happened here. Fortunately all threads seem to be OK, no leaks after proper torquing of both and 6 quarts of Mobil 1. Oil filter was a jobber, NAPA proSelect China, not impressed by the wavy pleats, never pulled a Toyota filter off looking like that, but I guess it did its job.
crushed crush washer
Various musings: http://hangfire.net
Re: That's not 30-36 lb/ft [Re: HangFire] #5112852
05/22/19 08:43 PM
05/22/19 08:43 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
But the import thought is you have to torque that washer down to just the right tons of torque.
2004 Corolla 132497
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74906
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: That's not 30-36 lb/ft [Re: HangFire] #5112856
05/22/19 08:47 PM
05/22/19 08:47 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
The crush washers I'm familiar with as far as Toyotas go, have always been a styrofoam type material.
Re: That's not 30-36 lb/ft [Re: HangFire] #5112860
05/22/19 08:50 PM
05/22/19 08:50 PM
Central Maryland
HangFire Offline OP
HangFire  Offline OP
Central Maryland
Huh? These are aluminum. They do have a textured paint or something on both sides.
Re: That's not 30-36 lb/ft [Re: HangFire] #5112867
05/22/19 08:58 PM
05/22/19 08:58 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
These right here. 1999 Toyota Camrys. They can only be tightened down one time.
[Linked Image]
Re: That's not 30-36 lb/ft [Re: HangFire] #5112889
05/22/19 09:35 PM
05/22/19 09:35 PM
Western Canada
geeman789 Offline
geeman789  Offline
Western Canada
Oil change guys work like this ...
If a filter leaks, or a drain bolt falls off, they get fired.
If the next customer can't get the filter or drain plug off because they are so tight, not their problem ...
They ALWAYS over tighten !
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: That's not 30-36 lb/ft [Re: das_peikko] #5112901
05/22/19 09:43 PM
05/22/19 09:43 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Huh? Real Toyota ones are blue, since at least 2014. Toyota claims they must be replaced every time, but I've reused one several times with no leaking. That's because I don't overtighten the plug, and don't take the washer off the pan. Drain plug still looks brand new at 99k. Nevertheless, I bought spare washers, just in case...
2011 Toyota Prius now at 99K
Re: That's not 30-36 lb/ft [Re: CR94] #5112960
05/22/19 10:59 PM
05/22/19 10:59 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
They were always green with writing on them like in the picture. The oil filter box was white with Toyota printed in red diagonally about a hundred times. I was a lube tech for a Toyota dealer in 1999. Our method of torque was two fingers on a knife edge 14mm combination wrench.
Re: That's not 30-36 lb/ft [Re: das_peikko] #5113047
05/23/19 03:17 AM
05/23/19 03:17 AM
California
OnTheRocks Offline
OnTheRocks  Offline
California
Lube shops and independent garages simply don't carry every drain plug washer. Some may not carry any. They just reuse whatever is on the car. They know it's wrong. You know it's wrong. And it continues to happen. Even though we are talking about a part which cost $0.25. It cuts into their bottom line! If they service 4,000,000 cars, it's $1Million!
I once saw a car with the drain plug head rounded, the washer crushed and flattened beyond belief, and all sorts of blue "stuff" all over the drain port. Corner mechanic shop who serviced the car since it was new provided the insight. Oil leaking. His guys have had to use air impact tools to slam the drain plug in tighter and Loctite on the threads and under the washer to stem the oil leak. This guy is suppose to be a professional!
I found another car with epoxy gummed all around the drain plug. Same story. Gomer & Goober Pyle, the family's trusted mechanics for years, have serviced the car since it was new. Gomer confirmed that there was an oil leak, so he sealed with epoxy a few years ago. I asked him how he's been changing the oil. With a hint of pride in his voice, he told me that in their shop, they have a pump with a hose down the dipstick tube. Again, he is suppose to be a professional!
Re: That's not 30-36 lb/ft [Re: HangFire] #5113066
05/23/19 05:25 AM
05/23/19 05:25 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I just snug up the drain plug. To me the specs are too tight.
The "thinking" man's friend.
Re: That's not 30-36 lb/ft [Re: HangFire] #5113101
05/23/19 06:31 AM
05/23/19 06:31 AM
northern NY
Driz Offline
Driz  Offline
northern NY
The factory filter on my 13 Sonata was on so tight I rounded it with a cheap cap style wrench after none of my band types would work. I almost resorted to punching the thing😆. Dumb 🤖 robot.
Re: That's not 30-36 lb/ft [Re: HangFire] #5113288
05/23/19 09:44 AM
05/23/19 09:44 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
I usually just tightened the drain bolt and tap it 2x with my palm.
Never have a leak.
  • 2017 Toyota Sienna
Re: That's not 30-36 lb/ft [Re: HangFire] #5113699
05/23/19 04:14 PM
05/23/19 04:14 PM
Newport News, VA
sdowney717 Offline
sdowney717  Offline
Newport News, VA
Yes, oil change places do all sorts of weird stuff. I know, I used to work at a Chevy dealer in the 1980's.
Changing the oil type jobs were given to unskilled workers as in non mechanics. It really made no difference what the customer wanted for oil type, all engines got the same oil. We had a big oil tank and overhead hose to fill from. The tech put in whatever oil he wanted. It was a real crapshoot what you might end up with in the engine.
Re: That's not 30-36 lb/ft [Re: das_peikko] #5113905
05/23/19 07:41 PM
05/23/19 07:41 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Huh? Real Toyota ones are blue, since at least 2014. ...
They were always green with writing on them like in the picture. ...
Does that color difference have to do with a size or age difference? The one installed by the dealer on my car when they last changed the oil (in September 2015) is blue. The pack of Toyota ones I ordered from another Toyota dealer are the same shade of blue. All the ones I see on Amazon that are claimed to be genuine Toyota parts are blue.
