Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
45 registered members (Black_Thunder, 53' Stude, bernau, Best F100, 11 invisible), 743 guests, and 22 spiders.
Topics290,259
Posts4,987,237
Members68,413
Most Online2,967
Mar 10th, 2019
Greasing without zerks? #5112785
05/22/19 07:47 PM
05/22/19 07:47 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
I have a few ball joints that appear to be somewhat dry and no grease zerks - the boots are not swollen any more.
Any way to lubricate them without zerks, or just wait until they fail and change them to greaseable zerk type joints?
Tapping in zerks is not an option.
98 Expedition
Re: Greasing without zerks? [Re: Fitz98] #5112799
05/22/19 07:55 PM
05/22/19 07:55 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
As long as the boots are intact forget it, they all look low on grease, its normal.
Re: Greasing without zerks? [Re: Fitz98] #5112815
05/22/19 08:10 PM
05/22/19 08:10 PM
Kansas, USA
Kansas_Ron Offline
Kansas_Ron  Offline
Kansas, USA
I have a needle that attaches to a grease gun. I'm not sure how effective it is. Push it through the boot and grease it up.
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Greasing without zerks? [Re: Kansas_Ron] #5112823
05/22/19 08:17 PM
05/22/19 08:17 PM
out there
spasm3 Offline
spasm3  Offline
out there
IF you do that enter the rubber boot at a very almost flat angle, better chance of the stick closing back. Don't go straight in.
But as trav said probably better to leave it be. If its not making noise. If it makes noise , you have nothing to lose.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Greasing without zerks? [Re: Kansas_Ron] #5112849
05/22/19 08:40 PM
05/22/19 08:40 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
All that does is fill up the boot. It does not get grease where it needs to be,in the high load wear areas.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Greasing without zerks? [Re: spasm3] #5112851
05/22/19 08:43 PM
05/22/19 08:43 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Like a solution in need of a problem?🤔
Full Disclosure: I've made that mistake before.
Re: Greasing without zerks? [Re: Fitz98] #5112954
05/22/19 10:45 PM
05/22/19 10:45 PM
indiana
Jimkobb Offline
Jimkobb  Offline
indiana
I grease with some of my co-workers. Oh, wait . I thought you said jerks. tongue2
green_bay_packers_logo_small[1]
Re: Greasing without zerks? [Re: Fitz98] #5113111
05/23/19 06:38 AM
05/23/19 06:38 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
The first car I ever had that didn't have any zerk fittings was a late 80's Honda(also being my 1st import).
So, I went out and bought a grease needle for the end of my grease gun in order to puncture the rubber boots with said needle and get some grease into the joint area.
To say the least, this was a waste of time as the tie rods & ball joints were the first to go and probably would have gone anyway as this style of boot puncturing, only fills the rubber boots and does nothing to "FORCE" grease into the joints themselves the way a zerk fitting would have allowed.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Greasing without zerks? [Re: Kansas_Ron] #5126327
06/05/19 06:41 PM
06/05/19 06:41 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Not effective and you will eventually have a boot peppered with holes to allow moisture and dirt in. The grease won't find its way to where it is needed.
The "thinking" man's friend.
Re: Greasing without zerks? [Re: Kansas_Ron] #5126453
06/05/19 08:36 PM
06/05/19 08:36 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Odds are there's a good chance you'll damage the boot, junk will get in and shorten the life of the joint. As Trav said they all look a little low on grease. Don't fix what ain't broke.
God Bless Our Troops
Re: Greasing without zerks? [Re: Fitz98] #5128898
06/08/19 09:33 PM
06/08/19 09:33 PM
McLean, Va.
vssjim Offline
vssjim  Offline
McLean, Va.
Most fords usually at this age the ball joints get tight, then squeak and then get real loose fast and you need new one with grease fittings in them.
Re: Greasing without zerks? [Re: Fitz98] #5131019
06/11/19 05:24 AM
06/11/19 05:24 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Nothing wrong is quality sealed components these days. Most are seeing 100-200k mile service life. That said, boot failure = joint failure in short order since 1) you can't flush it out with grease and 2) you typically can't replace the boot.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Greasing without zerks? [Re: Fitz98] #5131229
06/11/19 10:11 AM
06/11/19 10:11 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
The factory BJ's use a plastic bearing that wears out over time, but doesn't grind so much from lack of lube. You're doing well to still have the originals and should just factor in replacing them eventually. They typically won't squeak so much dry due to the plastic, as much as just develop a gap that makes a clunk noise from the play in them, before complete failure. They don't always clunk, should be inspected for excessive play.
The lowers can have just the BJ replaced but the uppers require a new control arm that they're built into (some aftermarket replacement uppers do have replaceable BJ's but you need that type to do upper BJs alone the next time), and an alignment done afterwards.
A quality sealed, plastic bearing BJ can have a good service life, especially considering you already got 22 years out of those, but they are not as good for loads, or impacts like potholes, as an all metal greaseable BJ.
