Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
B&S riding mower long filter short filter etc.
by j_mac - 11/11/19 05:32 PM
Covering the cowl vent
by painfx - 11/11/19 05:31 PM
Project: DuckHead Arm
by RayCJ - 11/11/19 05:29 PM
I Found The Perfect Garage Door Oil
by billt460 - 11/11/19 02:03 PM
Oil recommended for Old Snowthrower
by Ckerch - 11/11/19 01:58 PM
Choo Choo train maintenance and repairs?
by Chris142 - 11/11/19 01:58 PM
Hemi Oil Use
by Zap1967 - 11/11/19 01:27 PM
Who Makes the Best Class 8 "Semi" Truck These Days?
by LoneRanger - 11/11/19 01:21 PM
Update to my Wide Open West Broadband Thread
by LoneRanger - 11/11/19 01:15 PM
Is it worth changing my Corolla oil before 10k?
by oxband - 11/11/19 01:10 PM
Blowing smoke in 1970 Chevelle
by 007 - 11/11/19 12:05 PM
Coolant leak parked in the cold
by OCDriver - 11/11/19 11:58 AM
greenmeanie, vw_sod, Mac87, LazyJ, Danohall
69832 Registered Users
131 registered members (379KITTY, Aichiguy, 1978elcamino, AandPDan, 64bawagon, 10 invisible), 2,187 guests, and 21 spiders.
Topics297,283
Posts5,112,241
Members69,832
Most Online3,589
Nov 2nd, 2019
Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l #5112645 05/22/19 04:40 PM
G
George7941 Offline OP
G
This time, I extended the OCI past my normal interval. You can see three previous analysis results, with the intervals listed. The Iron, Lead and Silicone readings are higher than it should be if you extrapolate from the previous results.
As an example, consider the Iron reading of 21 ppm. The Dec 13 analysis has 13 ppm on a 9270 km interval. Extrapolating gives 10980/9270 x 13 = 15.4 ppm.
Do the current results indicate that the OCI was over extended? I expected the Mobil 1 oil to handle the extended interval, even though I went about 10 % past the OLM on my truck. I was using a Mobil 1 oil filter. My oxidation, sulfation and nitration readings are also high when compared to previous readings.
Attached PDF document
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112700 05/22/19 05:33 PM
A
addyguy Offline
A
Lead shot up badly, w/o a drastic increase in Silicon or fuel dilution....not great.
Was during the winter, and we had a very cold winter this year, only thing I can think would cause this.
Did it see a lot of short trips and restarts in the cold?
2010 Kia Soul 2U - 2.0L I-4, auto; 148k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112702 05/22/19 05:33 PM
carviewsonic Offline
10.9k kms shouldn't be too high for a quality oil. What kind of use did your truck see during this interval, lots of short tripping or hauling/towing?
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112733 05/22/19 05:57 PM
W
WobblyElvis Online Content
Online Content
W
I would not be concerned but winter conditions are the hardest on the oil. If you are going to extend your oil change interval, do it in the summer. My car produces more wear particles per mile in the winter vs summer.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112770 05/22/19 06:33 PM
J
JustN89 Offline
J
I would run another interval at the same distance, take a sample, and see what lead reads then. Hopefully, it's just a streak.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112804 05/22/19 07:01 PM
G
G
Not excessive short tripping but a lot of stop and go driving because I live in the middle of a very busy city. My city/hwy miles ratio is about 80/20. The driving conditions were the same for the previous samples too.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5113077 05/23/19 04:59 AM
dnewton3 Offline
Global Moderator
Global Moderator
This UOA does show some concerns, but too few samples to really understand the trending. Could just have been a particle streak; wont' know until the next UOA comes in. The Si is unlikely the issue; there are two other readings essentially as high and not correlation to metals. Without correlation there can be no causation.
Is not the 4.3L based on the "old" GM 350 engine (essentially 3/4 of the engine with two cylinders lopped off)? That old 350 engine was never a good wearing product; shed a lot of metals, historically. (I'm not saying it didn't run well or last a long time; it just has high wear-rates).
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: dnewton3] #5113598 05/23/19 01:53 PM
G
G
Yes, the 4.3 is a three quarter 350 engine.
Si readings were very high initially on this engine. The first analysis had Si readings of around 80 ppm. That had me worried and I tried another air filter with no improvement in the Si readings. Wear metals figures were normal and not high. The Si figures has been slowly trending down over the years and at about the eight year mark in the life of the truck, Si figures finally dropped down to reasonable levels. My best guess is that the Si came from factory applied RTV somewhere in the engine.
1987 BMW R80 - sold
2015 Honda CBR300R
