Originally Posted by Astro14
Seals fail over time, too... if you're lucky, the pistons won't be rusted.
But you're going to have to pull them off to find out.
Given a choice between Cardone/NAPA/whoever and new ATE from Mercedes, I would go new, every time.
www.Mboemparts.com
That's the crux of the matter - the wild card of rusted pistons.
This is a CA car, rust free, so it shouldn't be an issue. But one never knows what they'll find.
Originally Posted by nthach
OP has Bendix calipers and those are over $1K each, the later W126 cars also got them. Mercedes is doing a decent job keeping parts for their older cars around. If those were ATE calipers, you can still get rebuild kits in the blue ATE box from any competent wholesaler(Worldpac and IMC).
IIRC the late w126 calipers are different to fit vented discs. The w123 has solid discs all around.
So the cost structure may be different, but you're right, MB is only supporting new Teeves (ATE) calipers.
Rebuild kits are available for both.
Originally Posted by dk1604
If a rebuild kit is no longer available and you want to retain as much of the OE parts as possible, you could try rebuilding the OE unit with parts from a reman unit.
Yes, could go that way. Again, the wild card is the piston. Wish there was some standard brake rebuilding guide that listed sizes and shapes of pistons, and replacement parts. I'd doubt that the piston Bendix used here is all that different from what they used elsewhere. But how would one know?
Granted, it is a big assumption that the piston is bad. Perhaps I can rebuild as -is. But the piston did seize...
So I don't know what to expect, and would prefer to be somewhat ready if the issue arises in one of the four calipers (might as well do them all, no??).
