Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
39 registered members (53' Stude, bernau, Best F100, AndyB, 10 invisible), 698 guests, and 22 spiders.
Topics290,259
Posts4,987,232
Members68,413
Most Online2,967
Mar 10th, 2019
Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l #5112645
05/22/19 05:40 PM
05/22/19 05:40 PM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
This time, I extended the OCI past my normal interval. You can see three previous analysis results, with the intervals listed. The Iron, Lead and Silicone readings are higher than it should be if you extrapolate from the previous results.
As an example, consider the Iron reading of 21 ppm. The Dec 13 analysis has 13 ppm on a 9270 km interval. Extrapolating gives 10980/9270 x 13 = 15.4 ppm.
Do the current results indicate that the OCI was over extended? I expected the Mobil 1 oil to handle the extended interval, even though I went about 10 % past the OLM on my truck. I was using a Mobil 1 oil filter. My oxidation, sulfation and nitration readings are also high when compared to previous readings.
Attached PDF document
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112700
05/22/19 06:33 PM
05/22/19 06:33 PM
Canada
addyguy Offline
addyguy  Offline
Canada
Lead shot up badly, w/o a drastic increase in Silicon or fuel dilution....not great.
Was during the winter, and we had a very cold winter this year, only thing I can think would cause this.
Did it see a lot of short trips and restarts in the cold?
2010 Kia Soul 2U - 2.0L I-4, auto; 143k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112702
05/22/19 06:33 PM
05/22/19 06:33 PM
Alberta
carviewsonic Offline
Alberta
10.9k kms shouldn't be too high for a quality oil. What kind of use did your truck see during this interval, lots of short tripping or hauling/towing?
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112733
05/22/19 06:57 PM
05/22/19 06:57 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I would not be concerned but winter conditions are the hardest on the oil. If you are going to extend your oil change interval, do it in the summer. My car produces more wear particles per mile in the winter vs summer.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112770
05/22/19 07:33 PM
05/22/19 07:33 PM
ZFW
JustN89 Offline
JustN89  Offline
ZFW
I would run another interval at the same distance, take a sample, and see what lead reads then. Hopefully, it's just a streak.
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5112804
05/22/19 08:01 PM
05/22/19 08:01 PM
Toronto, Canada
Toronto, Canada
Not excessive short tripping but a lot of stop and go driving because I live in the middle of a very busy city. My city/hwy miles ratio is about 80/20. The driving conditions were the same for the previous samples too.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: George7941] #5113077
05/23/19 05:59 AM
05/23/19 05:59 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
This UOA does show some concerns, but too few samples to really understand the trending. Could just have been a particle streak; wont' know until the next UOA comes in. The Si is unlikely the issue; there are two other readings essentially as high and not correlation to metals. Without correlation there can be no causation.
Is not the 4.3L based on the "old" GM 350 engine (essentially 3/4 of the engine with two cylinders lopped off)? That old 350 engine was never a good wearing product; shed a lot of metals, historically. (I'm not saying it didn't run well or last a long time; it just has high wear-rates).
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Mobil 1 5W30, 10980 kms, GMC Sierra 4.3l [Re: dnewton3] #5113598
05/23/19 02:53 PM
05/23/19 02:53 PM
Toronto, Canada
Toronto, Canada
Yes, the 4.3 is a three quarter 350 engine.
Si readings were very high initially on this engine. The first analysis had Si readings of around 80 ppm. That had me worried and I tried another air filter with no improvement in the Si readings. Wear metals figures were normal and not high. The Si figures has been slowly trending down over the years and at about the eight year mark in the life of the truck, Si figures finally dropped down to reasonable levels. My best guess is that the Si came from factory applied RTV somewhere in the engine.
1987 BMW R80 - sold
2015 Honda CBR300R
