Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
38 registered members (AndyB, BlueOvalFitter, Bighorn2500, chemman, 8 invisible), 638 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
Car door hinge squeals like a stuck... #5112603
05/22/19 04:39 PM
05/22/19 04:39 PM
WA
Mad_Hatter Offline OP
WA
What's a good grease for lubricating that metal slide part that pushes into the door as it's closing?? Sorry, I don't know what it's technically called.
It's rubbing up against a white plastic, grommet like thing and is annoying . I had a tube of permatex ultra disc brake lube laying around and I tried that but it's started to squeak again.
Any suggestions???
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5112605
05/22/19 04:44 PM
05/22/19 04:44 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
That’s the door check. They can be very hard to lubricate properly without taking the door apart. Inside there is a roller on a shaft and it can be almost impossible to get lubricant into the correct place. Trying to spray something in there with a spray straw is about the best you can do without taking the door panel off.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 413K
2000 Toyota ECHO, 281K
Re: Car door hinge squeals like a stuck... [Re: kschachn] #5112618
05/22/19 05:01 PM
05/22/19 05:01 PM
WA
WA
I was afraid of that. I tried jamming a straw in there using a can of silicone spray lubricant I had but apparently it didn't hit the right spot.
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5112622
05/22/19 05:05 PM
05/22/19 05:05 PM
NC
BigD1 Offline
BigD1  Offline
NC
Yes it's an annoying sound.
Best thing that I have used is CRC white lithium grease spray.
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5112623
05/22/19 05:05 PM
05/22/19 05:05 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I have tried using an aerosol grease like Lubriplate Spray Lube- A but have found that Three and One Oil with the extended tip works about as good as anything I have tried. You have to observe what component of the hinge assembly the pin is turning in and apply oil in those locations. I believe the pin is fixed to the movable hinge so you have to apply oil between the movable and fixed components.. Kept mine squeak-free for fifteen years doing that. Don't over oil and wipe away as much excess oil as possible to prevent dirt buildup on the hinges. Go for it
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5112660
05/22/19 05:59 PM
05/22/19 05:59 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Try tightening all the little bolts that you can see on the door and door jamb. Mine was making a sort of popping sound, which I tried to remedy with a few types of lubricant. The bolts on the door were not very tight and tightening them did the trick.
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5112766
05/22/19 07:27 PM
05/22/19 07:27 PM
WA
WA
Thanks, I hadn't thought to check all the bolts. None of them looked loose but I'll double check them. I was originally going to use the 3 in 1 with the telescopic applicator because 3 in 1 is an awesome penetrating oil in my opinion but I can't get the 3 in 1 back in there far enough to work.
Here's my dilemma, there's a white plastic like grommetty thing that I believe is there to prevent metal on metal occuring on that door check mechanism. I believe if I hacked that piece out there I could probably get a straw in there better aimed at whatever joint is on the other end squealing. I think using a spray lithium would probably work better than my silicone, bicycle chain lubricant I used. The reason I haven't done it yet is I'm afraid I'll be setting myself up for another problem with not having that plastic grommet like part in place.
Anyone take apart the door panel on a 09 Kia Sedona? Is it something you would attempt if you never have disassembled a door panel? Or I was wondering if I took it to a car audio installer and see if they would take it off for a reasonable price just so I could get on there to lubricate things.. I honestly have no idea what something like that would run.
I've thought about living with it because it doesn't bother me the driver as I don't use that door but when I have a passenger get it, darn it sounds just awful at times. None of the other doors do it, just that one.
Re: Car door hinge squeals like a stuck... [Re: Mad_Hatter] #5113885
05/23/19 07:24 PM
05/23/19 07:24 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I’d try some of the CRC clear penetrating grease via a straw. I wouldn’t count on it working, in which case, I’d probably remove it, soak in wd-40, gasoline or diesel, clean and dry, then get grease, clear spray or otherwise, in there.
Success not guaranteed...
