Washed the Terrain
by gregk24 - 10/13/19 10:23 PM
Oil recommendation for my flat tappet cam?
by fusseli - 10/13/19 10:02 PM
Less oil consumption when near add line?
by ledslinger - 10/13/19 09:33 PM
Honda Accord V6 Destroyed -- Timing Belt Failure
by CrackyWainwright - 10/13/19 08:48 PM
Valvoline Advanced Full Synthetic
by GaryPoe - 10/13/19 08:36 PM
Help!!!! 2000 GM 2.4 LITER TWIN CAM WATER PUMP
by Prich - 10/13/19 07:46 PM
Oil running off dipstick after hard driving
by DV0993 - 10/13/19 07:39 PM
Craftsman YT4000 - Slow uphill
by Covington - 10/13/19 07:23 PM
Outside Temperature Gauge
by rrretiree7 - 10/13/19 06:59 PM
Battery judgement based on analyzer
by tvaughn0712 - 10/13/19 06:49 PM
Low number plate
by Nayov - 10/13/19 06:34 PM
Valve Lubrication help
by MikeDanger - 10/13/19 05:31 PM
Havoline Pro DS Problems/Benefits?
by TheLawnRanger - 10/13/19 04:40 PM
Reusing oil filter
by Brojo - 10/13/19 04:11 PM
Vehicle Turbo Efficiency
by Al - 10/13/19 03:58 PM
Conv When Car Manual Calls For Syn Blend
by Mr_Luke - 10/13/19 03:01 PM
ATF contamination in PS Fluid--Honda CR-V 2007
by Blurider24 - 10/13/19 02:53 PM
Mag1 gear oil at PepBoys
by kstanf150 - 10/13/19 02:33 PM
1000Bulbs.com 500 at Talladega
by bdcardinal - 10/13/19 12:35 PM
LMLowner, Gordonhersh, Starrman, Covington, pktrkt
69548 Registered Users
75 registered members (AdditiveOCD, 4WD, 19jacobob93, A_User55555, andyd, bdcardinal, 2 invisible), 1,574 guests, and 30 spiders.
Topics295,935
Posts5,087,642
Members69,548
Most Online3,532
Jul 30th, 2019
towing cark in park #5112569 05/22/19 04:15 PM
M
matrass Offline OP
M
Hello and good afternoon all .
My Trailblazer is currently stuck where I am unable to move the shifter from the park position. ( gauge shows neutral )
When this happened I was backing up to hook up my boat and my truck is rear wheel drive.
If I am unable to move it away from my boat and it is in park what type of damage can I expect getting it on a rollback ?
Figure the tires will take a hit .
Seems like it could be a cable , soelonoid .
Going to take the console off tomorrow but not sure I will be able to get it in neutral as I am also not able to get under it .
Took the week off for some fishing , what a way to start it
Re: towing cark in park [Re: matrass] #5112571 05/22/19 04:16 PM
M
matrass Offline OP
M
mad
Tried to add the mad icon in my original post not sure what happened
Re: towing cark in park [Re: matrass] #5112586 05/22/19 04:26 PM
J
JustN89 Offline
J
I would check the shift cable first before I tried to tow anything in park- those bushing are prone to failure and can cause separation.
Re: towing cark in park [Re: matrass] #5112591 05/22/19 04:31 PM
sdowney717 Offline
Rear wheel drive? If so disconnect the drive shaft at the rear end. Its and easy thing to do, but block the tires, you dont want it to roll onto you.
Re: towing cark in park [Re: matrass] #5112593 05/22/19 04:33 PM
justintendo Offline
the carrier operator can put the wheels on dollies and drag it on with the winch...otherwise drop the driveshaft.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: towing cark in park [Re: matrass] #5112599 05/22/19 04:36 PM
Astro14 Offline
Getting it on a flat bed won’t hurt it. Dollies for the wheels, or just dragging it on the metal bed, either way is very little tire wear, and not a ton of strain on the parking pawl. If the winch can pull it, it won’t be more load on anything than parking on a hill...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: towing cark in park [Re: matrass] #5112606 05/22/19 04:50 PM
E
eljefino Offline
E
They drag illegally parked cars all the time... and shake them off at the impound lot! No worries.
Re: towing cark in park [Re: matrass] #5112607 05/22/19 04:51 PM
M
madRiver Offline
M
If you drag tires it set your parking brake so you don't place the stress on transmission.
Re: towing cark in park [Re: matrass] #5112611 05/22/19 04:53 PM
sdowney717 Offline
Dragging might road rash the tires, create a flattish spot, which when your driving your going to notice that. We had a jammed up wheel cylinder, so a rear brake dragged, and it ruined the tire.
Re: towing cark in park [Re: matrass] #5112630 05/22/19 05:12 PM
A
AntiMatic Offline
A
See what JustN89 said: happened to me in Lowes parking lot: got stuck in Reverse. Used some wire ties until I could get the bushing in the Help! Section at AAP. YouTube video had the correct part number.
72 Cutlass Convertible 350 4 speed, 8 bbl, 3.28 Triple Black
09 Accord 5 speed, 25k
11 BMW Z4 6 speed, 75k
07 VTX 1300 5 speed, 15k
08 GoldWing 5 speed, 45k
03 Trailblazer Slush box, 95k
Re: towing cark in park [Re: matrass] #5112672 05/22/19 06:07 PM
R
rekit Offline
R
If you're on cement lift the axle with 2 floor jacks, ready to roll the correct direction maybe?
Re: towing cark in park [Re: matrass] #5112692 05/22/19 06:26 PM
Chris142 Online Content
Online Content
Did you check the brake light fuse?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: towing cark in park [Re: Chris142] #5112748 05/22/19 07:13 PM
M
matrass Offline OP
M
I did not check the brake light fuse. what affect would that have if it went ?
The truck is on gravel on the edge of my driveway right now.
With the running boards on the bottom tough for me to get underneath it .
Have seen a couple of videos with an actuator that will let you release the shifter.
Another video said check fuse 25 .
Re: towing cark in park [Re: matrass] #5112835 05/22/19 08:28 PM
T
tiger862 Online Content
Online Content
T
Put emergency brake in then crawl under vehicle and follow cable to transmission. Next move linkage forward if I remember correctly. Normally cable comes loose in console with repair kits readily available. Last one i did was about 3 years ago.
Tiger862
2018 Grand Caravan
Re: towing cark in park [Re: matrass] #5113383 05/23/19 11:14 AM
M
matrass Offline OP
M
had to dig my way under the truck to see what I could find.
The bushing for the shifter linkage gave way , just like justN89 mentioned ( thanks for pointing me in the right direction )
Going to use the Dorman 14057 shifter bushing repair .
Worst case it could get me moving until I can replace the shifter cable .
Has anybody used this part for a while and how does it hold up for a longer term repair ?
