Originally Posted by ZeeOSix
Any filter, regardless of construction and if it has a center tube or not, will leak dirty oil if the ends of the pleats are not sealed 100%. This is a new venture into the weeds as a back peddle move.
No it's not, whatever that is supposed to mean about back pedal move. The Fram has a defect and the pleats are exposed. A Toyota that has no defects is not the same discussion. It would be like saying your perfect Ultra "could have" an oil leak. Maybe the end cap has a hole it it. etc. Made up stuff. This one here the cap is off the pleats, not as designed. There is a strong reason it could have a leak.
Maybe grasping at straws is a better description. So how is it going to leak dirty oil because of those exposed pleats? Photo isn't even clear enough to see exactly what's going on inside that gap with the pleat ends as far as the glue job. What if there was no center tube at all like some cartridge filters? - the ultimate "gap" and exposure of pleats. Your getting pretty obtuse saying "there could be no glue on some of the pleat ends" ... but where's the proof that's the case? Can you find any C&P thread where that's been shown? People could say "there could be a flaw" on any oil filter ever made with no visible proof ... that's all you've done in this case.
So where is the proof that this one is leaking dirty oil at the gap?
All that's being said is that it's shoddy construction. It very well could leak. Also this is not by any means an isolated case. A lot of the ocod and tgs have endcaps that are offset like this.
Personally, after using and dissecting one, I consider the brittle end cap material to be a liability.
