16 Kia Sorento defender ltx?
by Torro - 10/19/19 07:38 AM
Oil for BMW B58 Engine in Toyota Supra
by Ch2289 - 10/19/19 07:36 AM
Hyundai Engine Oil Selection
by STIcandy - 10/19/19 07:17 AM
2015 Forester XT oil catch can recommendation
by jbutch - 10/19/19 07:00 AM
Brake Cap - Lost It
by coopns - 10/19/19 05:00 AM
Toyota Corolla 2020 CVT
by georgemiller - 10/19/19 03:55 AM
Illinois football fans
by mjk - 10/18/19 11:52 PM
Multi oscillating tool?
by xfactor9 - 10/18/19 11:24 PM
Titan oil filter mount
by AZjeff - 10/18/19 10:49 PM
Racor gas vs diesel fuel filters
by Meridian28 - 10/18/19 10:20 PM
Just curious, why no polls here?
by blupupher - 10/18/19 09:39 PM
0w-30 over 5w-30?
by SDGolden - 10/18/19 09:33 PM
Motorcraft FL-820S Cut Open - 4k Miles
by ThirdeYe - 10/18/19 08:19 PM
Mopar OAT alternatives?
by WillB - 10/18/19 06:57 PM
Honda GS190?
by Astro_Guy - 10/18/19 05:28 PM
Autozone Clearance and G-05 Sale
by Warstud - 10/18/19 05:18 PM
Toyota Oil Loss (3.3L)
by MaximaGuy - 10/18/19 03:46 PM
SkipCam, Ch2289, Paul_Nieminen, CanRex13, Pickles
69606 Registered Users
73 registered members (Astro14, 97Astro, AndyB, atikovi, 2015_PSD, bbhero, 7 invisible), 1,416 guests, and 25 spiders.
Topics296,162
Posts5,092,613
Members69,606
Most Online3,532
Jul 30th, 2019
Water heater on a timer? #5112343 05/22/19 12:08 PM
R
racin4ds Offline OP
R
Hi ladies and gents. I've recently been talking to my dad and a few others about the benefits of turning the Electric water heater off except certain times of the day when needed and began to really wonder if this can save much on the electric bill?
Yes I know it constantly runs to maintain the water temp but wouldn't it be counter-productive to leave it off all day while at work and then turn it on late in the evening when everyone needs a shower? To me, that would require the elements to stay on 100% DC to heat the entire 55 gallons back up and cause a higher use of electricity vs just maintaining the temp by cycling on and off throughout the day.
I've see the "Little grey box" and other timers as well as folks just wiring in a switch. Is there some validity to this or a waste of time and money? What say you?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Water heater on a timer? [Re: racin4ds] #5112350 05/22/19 12:16 PM
K
KrisZ Offline
K
If the heater is well insulated, then yes because it will retain heat, so the water will not be stone cold, provided no one is using hot water during the day.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Water heater on a timer? [Re: racin4ds] #5112354 05/22/19 12:20 PM
dadto2 Offline
Think about it like this... There is constant heat loss from the system, whether it's powered on all day or not. The energy will continue to try and equalize to the outside of the tank. The hotter the tank is, the more energy there is present to escape.
So if you cut the power and allow the energy to escape without replacing it all day, then turn on in the evening and bring the water back to hot, you will lose less energy to waste.
There are a lot of variables here that will change your result. Is the heater in a cold or warm environment? How well is the tank itself insulated? Is your electric rate fixed all day, or are you subject to peak and off-peak rates?
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: Water heater on a timer? [Re: racin4ds] #5112368 05/22/19 12:45 PM
JohnnyJohnson Offline
Had a little Gray Box on my water heater three houses ago. On a 50 gallon tank. It powered off at 9:30 PM back on at 4:30 AM then back off at 10 AM and back on at 2:30PM it did save me several dollars a month on my bill. Power is more expensive now and these timers are now more programable than mine was. Now some of the boxes allow you to program different hours each day and weekend plus vacation shutdowns.
Oh my Little Gray Box had a cavoite don't use with aluminum wiring.
2004 Corolla 136193
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76552
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Water heater on a timer? [Re: racin4ds] #5112371 05/22/19 12:49 PM
P
PandaBear Offline
P
Back in the days I had an electric water heater at home, that you need to manually turned on 30 mins before taking a shower. So yes it can be done, but you won't know how much electricity you will save until you actually try it out.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Water heater on a timer? [Re: racin4ds] #5112381 05/22/19 01:04 PM
supton Offline
Personally I'd want to hook a temp sensor and wattmeter and measure. So as to be sure.
My thinking: let's say I turn it off, it's off for 8 hours, and when I turn it back on, the water is still at say 100F. I probably am not saving much energy--my thinking, somehow I wind up using the same amount of energy over the course of a day. I realize the bigger the temperature difference from inside to outside -> faster heat transfer, but I'm thinking, a low duty cycle over a long time could be the same effect as high duty cycle but only some of the time.
Now if the tank was hitting ambient long before I switch it back on, then I'm guessing I'd have savings.
Then again, you lose nothing by trying (only time spent waiting for the tank to come up to temp). Proof is in the pudding: does it save energy & money for you?
2011 Toyota Camry, base, 2.5L/6MT, 193k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 214k, his
Re: Water heater on a timer? [Re: racin4ds] #5112394 05/22/19 01:18 PM
Donald Offline
The better insulated a water heater is the less you will save. Feel the outside of the water heater? Is it warm to touch or room temp. I don't think you will save much with a well insulated water heater.
If the heat from the jacket of the water heater goes to heat a lived in room, then its less your furnace will be on. Furnace may be gas and water heater electric.
At one point in time they had off-peak power switch for the electric water heater. Power company controlled when the water heater was on and when off. You got a cheaper rate allowing them to control water heater.
2015 Ford F250 w/Powerstroke
Re: Water heater on a timer? [Re: racin4ds] #5112415 05/22/19 01:40 PM
J
JeffKeryk Offline
J
As a preparation for the future, I installed a tankless (gas) water heater and solar panels.
I guess I would try and insulate the water heater as best as you can.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Water heater on a timer? [Re: racin4ds] #5112454 05/22/19 02:19 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I once turned off the water heater for a weekend. Upon return I took a shower, and didn't realize I turned off the water heater until I finished my shower. That's how efficiently they hold heat.
Re: Water heater on a timer? [Re: racin4ds] #5112532 05/22/19 03:38 PM
E
eljefino Offline
E
If you have off-peak metering go for it. Otherwise, don't. Tepid water is a great way to get Legionairre's Disease.
Re: Water heater on a timer? [Re: racin4ds] #5112579 05/22/19 04:21 PM
digger327 Offline
I had 1 of those grey box timers, saved a few dollars, what has saved me a lot was switching to heat pump water heater, it cut my electrical bill in half.
Re: Water heater on a timer? [Re: eljefino] #5112612 05/22/19 04:55 PM
M
madRiver Offline
M
+1
Re: Water heater on a timer? [Re: racin4ds] #5112627 05/22/19 05:09 PM
2
2oldtommy Offline
2
The best thing you can do is to compare KWH cost with nat. gas cost if available. In OH the cost of nat. gas to heat water makes electric water heaters obsolete. FWIW.
Oldtommy
Re: Water heater on a timer? [Re: racin4ds] #5112691 05/22/19 06:25 PM
B
bullwinkle Offline
B
I would think a add-on water heater blanket & new heat trap fittings for the inlets would save almost as much.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Water heater on a timer? [Re: 2oldtommy] #5112814 05/22/19 08:10 PM
R
Rand Offline
R
Oldtommy
This is very true even with my heat pump water heater in eco mode its 2-3x the cost vs natural gas.
conventional electric is around 8-10x the cost to heat vs natural gas (NE OHIO prices)
Disclaimer:IIRC its been a few years since I ran the numbers..
