Carfax reveals cursed vehicle
by Elkins45. 06/16/19 09:38 AM
We love our ethanol!
by SevenBizzos. 06/16/19 09:36 AM
LSPI Event - ?
by josephp732. 06/16/19 08:39 AM
'09 Honda Metropolitan hit 15k this morning
by Lawn_Care. 06/16/19 08:17 AM
16 y/o car w/98k, switch oil?
by Ricky_Samsonia. 06/16/19 08:13 AM
Ultrasonic Cleaner
by ET16. 06/16/19 06:27 AM
Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
83 registered members (1foxracing, Audios, Bighorn2500, ArrestMeRedZ, AndyB, AandPDan, 11 invisible), 1,933 guests, and 31 spiders.
Topics290,267
Posts4,987,399
Members68,413
Most Online2,967
Mar 10th, 2019
Looking for IP rated 24V DC regulator/conditioner #5112239
05/22/19 10:26 AM
05/22/19 10:26 AM
Middle of Iowa
DriveHard Offline OP
Middle of Iowa
Howdy forum of crazy knowledge. I have some sensitive equipment that I need to mount on an off highway vehicle that is running a 24V DC system. The components also run off of 24V DC. The problem is the voltage swings I see on the vehicle system cause my equipment to fault out, so I am looking for something that would have a 10-36 ish volt input and be able to output a clean 24V supply with about a 10 amp capability. Below is the closest I have found, but alas it is only about half of the amperage I need. Anybody know of something like this?
DC 24V 4A voltage stabilizer surge protector
Thank you in advance for the help!
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112250
05/22/19 10:34 AM
05/22/19 10:34 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
How long are the swings lasting ?
Do you have a 24 Volt battery or two 12 Volt batteries wired in series ?
Would a large capacitor and maybe a choke coil installed in the circuit to the equipment in question ?
I have read some of the old USAF surplus equipment was 24 VDC ?
Also , if the charging coming from an alternator ? Might check & see if it is going bad ? Also look for bad / corroded / loose connection in the electrical system .
https://www.google.com/search?clien...HRs0D0kQBQgpKAA&biw=1344&bih=677
Wyr
God bless
Re: Looking for IP rated 24V DC regulator/conditioner [Re: WyrTwister] #5112258
05/22/19 10:40 AM
05/22/19 10:40 AM
Middle of Iowa
Middle of Iowa
Not sure on duration...I will dig into it, but I believe while they are mostly less than 1 second, the low voltage conditions can be much much longer. I am leaning toward energy savings techniques much like GM uses on their cars where if the battery is fully charged the charging system will drop way down and run off the battery to save energy.
Two 12V in series
Maybe...have to be a pretty darn big cap to supply 10 amps for even a second and maintain the 24V level
machine is brand new...less than 200 hours, all connections have been triple checked
Again, I think this is mainly a charging algorithm issue that is not compatible with my instrumentation.
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112261
05/22/19 10:42 AM
05/22/19 10:42 AM
Middle of Iowa
Middle of Iowa
...I am also considering just purchasing two of the items I linked in the first post and running them in parallel. Any considerations/cautions I should be aware about if I decide to do that?
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112323
05/22/19 11:49 AM
05/22/19 11:49 AM
New England
Virtus_Probi Offline
New England
Load sharing is a tricky problem...you'd probably end up with one regulator bearing most of the load and probably being stressed.
I see lots of products bucking 24V down to 12V at 10A, and others boosting 12V to 24V at 10A...nothing yet in a buck/boost that will take ~24Vin and make 24Vout at 10A.
There are lots of companies like ADI and TI that make integrated buck/boost power modules that can handle your Vin/Vout/Iload, but you'd have to figure out how to heatsink them and make your pin connections...not trivial.
Wait....maybe this would work?? 150W is still less than you are asking for, but it's getting closer...
https://www.amazon.com/DROK-Adjusta...;qid=1558543581&s=gateway&sr=8-3
2014 Forester XT, 100000 miles
Last Change;
M1 10W30 HM SN+
Tokyo Roki 15208AA170 filter
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112327
05/22/19 11:54 AM
05/22/19 11:54 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
https://www.amazon.com/s?k=super+capacitor&ref=nb_sb_noss_1
https://www.youtube.com/results?search_query=super+capacitor
Do some research on super capacitors . I have watched videos on people using them in place of car batturies . Wire 2 in series .
Wyr
God bless
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112357
05/22/19 12:23 PM
05/22/19 12:23 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
buy a 12-24 volt step up converter wire it to a single battery. or parallel.
something like this https://www.ebay.com/itm/221937983352 (<$60)
or if you want to be spendy get something like this for $270
https://www.ebay.com/p/Samlex-Idc-3...t-Dc-dc-Switch-Mode-Converter/1403627566
They also make ruggedized 24-24 volt but it costs closer to $1000
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112438
05/22/19 02:00 PM
05/22/19 02:00 PM
Georgia
DeepFriar Offline
DeepFriar  Offline
Georgia
I don't have enough direct knowledge to help other than perhaps direct you toward investigating marine systems. Lots of 24 volt system with environmentally hardened sub-parts. I'll look around too, send along if I find.
Re: Looking for IP rated 24V DC regulator/conditioner [Re: DriveHard] #5112459
05/22/19 02:24 PM
05/22/19 02:24 PM
Middle of Iowa
Middle of Iowa
Thanks all for the advice. I actually have two loads I need to drive at 24 volts, so my plan is to get two of these 12v to 24v boosters and run one off of each battery. Thanks again!
Link to booster
