Evinrude oil
by FastLane. 06/19/19 03:40 PM
engine air filters...all the same?
by flinter. 06/19/19 03:37 PM
GM Dexron Developer Passes Away
by MolaKule. 06/19/19 03:20 PM
Hard Tonneau Cover Clean/Protect
by jims5600. 06/19/19 03:17 PM
2006 Camry 4 cyl. 15,000 miles on M1 5W-30
by Deontologist. 06/19/19 02:29 PM
puma oil nissan 350z? 20w50
by 1978elcamino. 06/19/19 02:04 PM
PL14612 cut open, ~5100 miles
by Sayjac. 06/19/19 01:42 PM
Best ATF for vintage Toyota P/S system
by timoboy. 06/19/19 01:16 PM
Touchless 303 thoughts?
by DriveHard. 06/19/19 12:59 PM
Napa Conventional 5qt @ $11.99
by SlavaB. 06/19/19 12:53 PM
Just spotted: 1974 Pinto!
by dadto2. 06/19/19 12:49 PM
Steering Rack Quality
by LazyDog. 06/19/19 12:43 PM
Liquid lawn fertilizer
by LeakySeals. 06/19/19 12:01 PM
HynKia Carquest filters: 85334 vs 95459
by SlavaB. 06/19/19 11:26 AM
Shell Spirax S1 alternatives
by avacado11. 06/19/19 10:38 AM
ZF HP8 Transmission Servicing
by Joel_MD. 06/19/19 08:50 AM
HF flashlight recall = 5 dollar gift card
by 1978elcamino. 06/19/19 08:41 AM
LS Diff gear oil
by WyrTwister. 06/19/19 07:55 AM
2005 BMW 325i, 12,065 miles, Mobil 1 0W-40
by Toto. 06/19/19 07:50 AM
taschnewitz, SilverFL, CactusLady, Ignatius, Kyle_O
68434 Registered Users
115 registered members (2015_PSD, 53' Stude, 77GrandPrix, 1978elcamino, 007, AlienBug, 17 invisible), 2,313 guests, and 22 spiders.
Topics290,669
Posts4,990,617
Members68,434
Most Online2,967
Mar 10th, 2019
Ronin 15% discount code #5112211
05/22/19 09:54 AM
05/22/19 09:54 AM
Florida
1978elcamino Online content OP
1978elcamino  Online Content OP
Florida
For all you F150 plastic oil drain plug owners you know why you're here. Use code "SURVEY" for 15% off your next order. I bought one and did a survey, they sent me a code, figured everyone can use it.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Ronin 15% discount code [Re: 1978elcamino] #5112248
05/22/19 10:31 AM
05/22/19 10:31 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I would buy one of these because it keeps you from crawling under my car?
2004 Corolla 132701
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74906
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Ronin 15% discount code [Re: 1978elcamino] #5112302
05/22/19 11:33 AM
05/22/19 11:33 AM
Florida
Florida
With the F150's new plastic oil pan and plastic drain plug the oil is uncontrollable and spills all over the place, all 10 quarts. So this is a solution, kinda like Fumoto.
2018 F150 5.0
Re: Ronin 15% discount code [Re: 1978elcamino] #5112399
05/22/19 01:20 PM
05/22/19 01:20 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
And now the bad news....
The Ronin valve (~$80 pre discount) is a spring loaded "closed-at-rest" valve which screws into the pan's hole.
You thread a SEPARATE PIECE into it after removing the dust cap to press against its spring and allow oil flow.
It all'll boil down to the separate piece which you can easily misplace.
Plastic oil pans....what next?
Re: Ronin 15% discount code [Re: 1978elcamino] #5112410
05/22/19 01:37 PM
05/22/19 01:37 PM
Far East Side
DoubleNickels Offline
Far East Side
Scotty Kilmer featured something like that.
Re: Ronin 15% discount code [Re: 1978elcamino] #5112413
05/22/19 01:39 PM
05/22/19 01:39 PM
Far East Side
Far East Side
I haven't looked under the new F-150 yet. Any reason why the Fumoto won't work?
Re: Ronin 15% discount code [Re: 1978elcamino] #5112423
05/22/19 01:45 PM
05/22/19 01:45 PM
Kira Offline
Kira  Offline
I went to Fumoto's site and entered the Ford F-150 year and engine involved. Fumoto has none for the application.
I'd bet it's because of the "keyed" or heavily lugged design of the Ford Ecoboosts' pans' holes.
A Fumoto is a simple, small screw in valve.
Hardware to fit those Fords would require different tooling for limited applications resulting in a one pound product.
Any reports on plastic Ford pans getting cracked?
WWHS? (What Would Henry Say)
Re: Ronin 15% discount code [Re: 1978elcamino] #5112426
05/22/19 01:48 PM
05/22/19 01:48 PM
Far East Side
Far East Side
Maybe it's just not populated onto the Fumoto site yet. Key is to find out the thread pitch.
Re: Ronin 15% discount code [Re: 1978elcamino] #5112456
05/22/19 02:21 PM
05/22/19 02:21 PM
CO
JLTD Offline
JLTD  Offline
CO
After doing a little reading on the Ford F1 50 forums, it seems that the Fumoto once installed, drips on exactly the same place as the factory opening does. It's simply a bad design, and you need some kind of hose with the Ronin to direct the flow.
What would Henry say, indeed! Another example of the engine team and the body team not working together.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, OE5w30/Wix
Re: Ronin 15% discount code [Re: Kira] #5112467
05/22/19 02:40 PM
05/22/19 02:40 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
So kind of like the old Fram Sure Drain?
Looked at the current F150 drain, looks like a horrible design. Why fix something that is not broken?
Fumoto makes a drain with a nipple that you can attach a hose to.
'18 Santa Fe:Delo XLE 10W-30/OEM/3k
'12 xB:M1 EP 0W-20/CQ Blue/5k
'07 Vue:Synpower 5w-30/Ecogard Syn/OLM
'02 F150:Magnatec 5W-20/Bosch D+/1yr
'94 VT1100:Peak 15W-40/Bosch D+/1yr
Re: Ronin 15% discount code [Re: 1978elcamino] #5113232
05/23/19 08:37 AM
05/23/19 08:37 AM
Florida
Florida
The Ronin also has an additional piece that screws in to attach a hose to bring the oil right in to a bucket. A hose is not required though. If you loose the second piece you can just unscrew it and drain the oil just like the original oil plug that came with the truck. This Ronin unit way to expensive but without it you are sure to make a mess each time. I have not used it to drain oil yet but so far it appears to be a simple and easy to use accessory. The nice feature is the part that you screw in to drain the oil has threads, this allows you to regulate how fast or slow the oil comes out. They have a video on their site showing how it works. I will post of a review after my next change if anyone wants to know The only reason I posted this is because of the cost. As I said, its way to expensive for what it is, so 15% will at least provide a little financial lube. No big deal if you have a shop change your oil but if you are a DIY as Im sure most folks are on BITOG the Ronin is probably a good investment if you plan to keep the vehicle for quite a long time.
2018 F150 5.0
Re: Ronin 15% discount code [Re: blupupher] #5113573
05/23/19 02:27 PM
05/23/19 02:27 PM
Far East Side
Far East Side
There's also another brand just like it sold on Amazon.
If you go to a plumbing supply, they can thread a ball valve for you.
