2012 chevy equinox with 121,xxxx
by Robw. 06/20/19 06:31 AM
F1 - 2019 French Grand Prix
by gofast182. 06/20/19 06:17 AM
Yard rollers
by dlundblad. 06/20/19 05:20 AM
EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
The cool people of Bitog
by Marco620. 06/19/19 08:52 PM
How do Adjust Your Seat and Mirrors
by buster. 06/19/19 08:37 PM
AC for hybrid and electric vehicles
by JimPghPA. 06/19/19 08:06 PM
Mobil 1 sold at Walmart vs Summit Racing
by kosoku. 06/19/19 08:02 PM
Troy Bilt TB200
by Floyd1. 06/19/19 07:54 PM
Cutting vinyl planking, Do I need a snapper?
by JLawrence08648. 06/19/19 07:13 PM
1969 Honda N600, Serial #1...
by mattwithcats. 06/19/19 06:02 PM
My Son Turned Me On to a New Cooking Show
by NYEngineer. 06/19/19 05:42 PM
Naphthenic Oils
by MolaKule. 06/19/19 05:06 PM
Mopar 5W-20?
by John344. 06/19/19 04:39 PM
Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
DesertTech, Jamie_E_M, Tambo, Robw, taschnewitz
68438 Registered Users
78 registered members (AurionX2, aquariuscsm, ArrestMeRedZ, Bailes1992, Astro_Guy, Aredeeem, 9 invisible), 1,127 guests, and 23 spiders.
Topics290,691
Posts4,991,039
Members68,438
Most Online2,967
Mar 10th, 2019
Carbon - Soot #5112072
05/22/19 08:07 AM
05/22/19 08:07 AM
Texas
WyrTwister Offline OP
Texas
Most of us have read the reason oil in diesel engines quickly turns dark / black is from soot .
I have also read the soot is abrasive . However graphite is sometimes used as a lubricant . Can some one please explain the difference ?
Also , is the soot to " fine " to be captured / trapped by the oil filter ?
Also , this is / may be applicable , to a much smaller degree in gasoline engines .
Thanks , :-)
Wyr
God bless
Re: Carbon - Soot [Re: WyrTwister] #5112093
05/22/19 08:24 AM
05/22/19 08:24 AM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
One reason can be the structure of the carbon. Graphite, a lubricating form of carbon, is plate like in structure due to the nature of the double bonds between the carbon atoms. Regular carbon (ie a soot particle) has mainly all single bonds and can be hard and angular. Remember that a diamond is very pure carbon in this state with no impurities and we all know how hard diamonds are.
2013 VW Passat TDI SE, 65,100 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 21,170 miles Castrol Professional VW505 5W-40
Re: Carbon - Soot [Re: Boomer] #5112100
05/22/19 08:27 AM
05/22/19 08:27 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Right, but the hardness of diamond isn't really related to the purity, it is because of the three-dimensional structure of four covalent bonds between each atom. Graphite would essentially be quite strong in the plane if you could stress it like that.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Carbon - Soot [Re: WyrTwister] #5112101
05/22/19 08:28 AM
05/22/19 08:28 AM
Newport News, VA
sdowney717 Offline
sdowney717  Offline
Newport News, VA
Soot is not abrasive unless it gets bigger, as long as its 1/10 micron its ok and has not been allowed to clump together by depleted oil additives. Otherwise diesel engines would completely wear out fast as they make a lot of soot. Soot is really small, too small to easily filter out from oil. I dont like unrestrained soot in my oil so I added a roll of toilet paper filter to my Dodge ram diesel 2005 truck. I started that thread in the bypass filter section. Even that TP will not remove small soot particles, but it will help.
Re: Carbon - Soot [Re: WyrTwister] #5112128
05/22/19 08:49 AM
05/22/19 08:49 AM
Texas
Texas
Correct or not . I do not know .
But I once read that particles smaller than a certain size , do not hurt in engine oil ? It said it acts as a " polish " ?
Wyr
God bless
Re: Carbon - Soot [Re: WyrTwister] #5112150
05/22/19 09:12 AM
05/22/19 09:12 AM
MN
oil_film_movies Offline
MN
Organic chemistry. example: All carbon are the buckyballs, a form of carbon that is made up of 60 atoms and shaped like a hollow soccer ball. Carbon molecules can get really weird, with special shapes, kind of like constructing them out of Tinker Toys, ya know?
[Linked Image]
Re: Carbon - Soot [Re: sdowney717] #5112153
05/22/19 09:14 AM
05/22/19 09:14 AM
CO
UberArchetype Offline
CO
Originally Posted by sdowney717
...I added a roll of toilet paper filter to my Dodge ram diesel 2005 truck.
Better filtration is one way to avoid accelerated diesel engine wear. High-density depth filters, centrifuges and gravity are the only 3 ways I am aware of to remove soot from engine oil. The oil itself and the oil change cycle is typically the only thing protecting a diesel from soot-induced wear. If you are relying only on oil changes, I would recommend establishing a baseline OCI schedule with oil analysis to determine where your soot red zone is. Typically short OCIs with a good quality diesel-rated lube will be worry-free in most consumer applications. Severe service (towing, etc.) might be another story.
Re: Carbon - Soot [Re: sdowney717] #5112186
05/22/19 09:35 AM
05/22/19 09:35 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
...........oil so I added a roll of toilet paper filter to my Dodge ram diesel 2005 truck. I started that thread in the bypass filter section. Even that TP will not remove small soot particles, but it will help.
I'll bet it was Charmin 3-4-ply and not Scotts 1000 one-ply.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Carbon - Soot [Re: WyrTwister] #5112219
05/22/19 10:04 AM
05/22/19 10:04 AM
MN
MN
Both Gasoline Direct Injection engines and of course Diesel engines produce soot in the oil.
"Soot reduces the effectiveness of anti-wear additives and its effect on wear depends upon the characteristics of the particles and agglomerates of soot. Abrasive wear occurs and wear scar width closely matches the primary particle size. Oil thickening was found to enhance timing chain elongation due to abrasive action of soot on pins and bushing."
---- https://www.sciencedirect.com/science/article/pii/S0301679X15000432
[Linked Image]
Re: Carbon - Soot [Re: oil_film_movies] #5113299
05/23/19 09:58 AM
05/23/19 09:58 AM
CO
CO
True. But diesels put an order of magnitude greater amount of it in the oil - even more if tuned hot.
