Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
41 registered members (bernau, 53' Stude, Best F100, AndyB, 11 invisible), 671 guests, and 22 spiders.
Topics290,259
Posts4,987,230
Members68,412
Most Online2,967
Mar 10th, 2019
Water leak from passenger door? #5111998
05/22/19 06:40 AM
05/22/19 06:40 AM
WI
HoosierJeeper Offline OP
WI
Noticed last tonight that there was a small stream of water coming in over the interior door sill on the Liberty. Been getting some moderate to heavy rains. Any ideas? It was a stream in the red circle area, perpendicular to the sill trim piece (parallel to the ridges on it). Didn't see any other drips on the a pillar or kick panel. Nothing on the headliner or Huskyliner floor mat. I do have a sunroof.
Any ideas? Hoping it's a simple fix!!!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112022
05/22/19 07:07 AM
05/22/19 07:07 AM
RI
mattd Offline
mattd  Offline
RI
First thing I would do is blow the drains out with compressed air
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Water leak from passenger door? [Re: mattd] #5112073
05/22/19 08:07 AM
05/22/19 08:07 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yes, check the drains, and if that doesn't fix the problem pull the panel and check the water shield underneath along with all the perimeter seals.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 413K
2000 Toyota ECHO, 281K
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112077
05/22/19 08:12 AM
05/22/19 08:12 AM
WI
WI
Which drains? Door or sunroof?
Here's the exact path. You can see it in the dirt.
[Linked Image]
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112087
05/22/19 08:19 AM
05/22/19 08:19 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
What year model ?
Did you drive in water deep enough to infiltrate from the bottom ? Or did the water come in from the top ( around the glass ? ) .
My general concept is , it is often difficult / impossible to keep water out of something . Make sure there is a path for it to drain out .
Is you live in the salt belt , pull the interior panel & and clean , flush , wash any salt / mud residue out of the interuior of the door and use some sort of rust inhibitor , inside the door .
Wyr
God bless
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112088
05/22/19 08:20 AM
05/22/19 08:20 AM
PimTac Offline
PimTac  Offline
How about the door seals? Give them a good look over.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112089
05/22/19 08:20 AM
05/22/19 08:20 AM
RI
mattd Offline
mattd  Offline
RI
Start at the ones on the sunroof. They are probably backed up near the bottom of the drains and water is traveling along that pillar
ASE Master, L1
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112102
05/22/19 08:28 AM
05/22/19 08:28 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I had that happen in a Chrysler van of mine. When it rained heavy, the door would fill up with water. Never did care to figure out why, I just drove out of my neighborhood with the door propped open slightly, and let it drain out as I drove out of the neighborhood. (closed the door before getting to the main road)
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Edge 0W40
06 GMC Sierra SuperTech 10W30
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112104
05/22/19 08:29 AM
05/22/19 08:29 AM
WI
WI
I didn’t see any evidence of water coming in from the glass/top...it’s not wet at either of the pillars either. The wettest spot is right under that path in the second pic, which starts under the door seal. I’ll check the sunroof drains though, just hit them with compressed air? Any risk of blowing them apart or something?
It’s an 05 Jeep Liberty by the way.
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112108
05/22/19 08:32 AM
05/22/19 08:32 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Since it is 14 years old it is possible the perimeter seals have been permanently compressed and no longer seal properly. That's what happened on my old Accord.
1994 BMW 530i, 242K
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112115
05/22/19 08:39 AM
05/22/19 08:39 AM
WI
WI
I’m sort of leaning towards that. Wonder if a little silicone could help?
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112125
05/22/19 08:47 AM
05/22/19 08:47 AM
NC
BigD1 Offline
BigD1  Offline
NC
Get up underneath it, and see if there are any slotted drains. I use a coat hanger that I have straightened, and start fishing the drains. Leaves, dirt, sand, bugs, and pine needles just kept on coming on the last drains I cleaned out.
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112179
05/22/19 09:30 AM
05/22/19 09:30 AM
RI
mattd Offline
mattd  Offline
RI
Wouldn’t be a bad idea just to check the cowl drains as well but usually that will leave the front of the carpet near the firewall wet
ASE Master, L1
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112189
05/22/19 09:36 AM
05/22/19 09:36 AM
WI
WI
It’s completely dry up there!
Re: Water leak from passenger door? [Re: HoosierJeeper] #5112295
05/22/19 11:26 AM
05/22/19 11:26 AM
PimTac Offline
PimTac  Offline
Check the aft part of the wheel well as well as the door bottom. A missing screw on a splash guard? Lots of ways this can happen. Opening the inner door might show the path.
2017 Mazda CX5
Roki OEM filter.
