Washed the Terrain
by gregk24 - 10/13/19 10:23 PM
Oil recommendation for my flat tappet cam?
by fusseli - 10/13/19 10:02 PM
Less oil consumption when near add line?
by ledslinger - 10/13/19 09:33 PM
Honda Accord V6 Destroyed -- Timing Belt Failure
by CrackyWainwright - 10/13/19 08:48 PM
Valvoline Advanced Full Synthetic
by GaryPoe - 10/13/19 08:36 PM
Help!!!! 2000 GM 2.4 LITER TWIN CAM WATER PUMP
by Prich - 10/13/19 07:46 PM
Oil running off dipstick after hard driving
by DV0993 - 10/13/19 07:39 PM
Craftsman YT4000 - Slow uphill
by Covington - 10/13/19 07:23 PM
Outside Temperature Gauge
by rrretiree7 - 10/13/19 06:59 PM
Battery judgement based on analyzer
by tvaughn0712 - 10/13/19 06:49 PM
Low number plate
by Nayov - 10/13/19 06:34 PM
Valve Lubrication help
by MikeDanger - 10/13/19 05:31 PM
Havoline Pro DS Problems/Benefits?
by TheLawnRanger - 10/13/19 04:40 PM
Reusing oil filter
by Brojo - 10/13/19 04:11 PM
Vehicle Turbo Efficiency
by Al - 10/13/19 03:58 PM
Conv When Car Manual Calls For Syn Blend
by Mr_Luke - 10/13/19 03:01 PM
ATF contamination in PS Fluid--Honda CR-V 2007
by Blurider24 - 10/13/19 02:53 PM
Mag1 gear oil at PepBoys
by kstanf150 - 10/13/19 02:33 PM
1000Bulbs.com 500 at Talladega
by bdcardinal - 10/13/19 12:35 PM
LMLowner, Gordonhersh, Starrman, Covington, pktrkt
69548 Registered Users
68 registered members (bdcardinal, 4WD, AdditiveOCD, 19jacobob93, A_User55555, andyd, 3 invisible), 1,548 guests, and 34 spiders.
Topics295,936
Posts5,087,651
Members69,548
Most Online3,532
Jul 30th, 2019
Motul 300v 5w40 vs Redline 40WT racing in BMW racecar #5111990 05/22/19 06:23 AM
J
junkyard_sal Offline OP
J
I posted this to racing oils but so far no response posting here to see if I can reach a bigger audience for thoughts.
I have two BMW racecars e36 M3 and e46 330i. The easy button is Redline 40wt racing oil and it is what I have always used. I am tempted to switch because FCP EURO sells Motul 300v 5w40 and will allow you to return used oil and will send you new oil so I could lower my operating expenses for the frequent fluid changes by 1k+ at a minimum.
Here are the data sheets
Motul
https://d23zpyj32c5wn3.cloudfront.n...0Power_205W-40_20_28GB_29.pdf?1492017370
Redline
https://www.redlineoil.com/Content/files/tech/40WT_RACE_PROD_INFO.pdf
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5112048 05/22/19 07:41 AM
B
BMWTurboDzl Offline
B
I'd opt for the easy button with w/out a couple of UOA's I'd imagine you're just flipping a coin with regards to performance. On a side note, I thought RL always recommended their 30W for BMW racers?
435i
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5112118 05/22/19 08:42 AM
O
oil_film_movies Offline
O
Shipping costs of the used Motul back to FCP Euro is high, isn't it? Guess the math works out though.
I've seen used oil analysis (UOA) on both Redline and Motul 300V, and I don't think there is any evidence one is better than the other.
If you want to save money, a great high temperature racing oil for your BMWs would be Mobil1 15w50, available for cheap at Walmart (order online for store pickup or shipped, or it is sometimes on the shelf).
https://www.walmart.com/ip/Mobil-1-Advanced-Full-Synthetic-Motor-Oil-15W-50-5-qt/20713647 ---- The value $$-savings option. $23 per 5 quarts ($4.60 per quart)
700+ hp Corvettes use it all the time racing, and have been for years. Very suitable for BMWs too, as HTHS is 4.5, a 25% extra heat-margin over the LL-01 BMW level, and more than what the IMSA WeatherTech SportsCar Championship (IWSC) BMW Team RLL uses when they race. See time point 1:39 in the video below:
https://www.pennzoil.com/en_us/performance/motorsports/performance-matters-for-bmw-team-rll.html
You could use the Walmart Pennzoil Platinum Euro 0w40 like the BMW Team RLL does, for cheap off the shelf, since expense is one of the subjects here, yet the Mobil1 15w50 would offer slightly more heat margin for you. ...
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5113137 05/23/19 06:55 AM
J
J
Cameron Evans (formerly with Redline) has always suggested 40Wt racing for these 5X flavor motors. You can probably use either but the rule of thumb is 10psi/thousand revs and 40wt hot gives you that PSI and 30wt is a little bit lower at the top end. So maybe we could get away with it but we don't see many people doing it.
My buddy runs the Mobil 1 and has for years. He gets a lot of hydraulic lifter tick on hot days and everyone says the thicker oil is the issue but his motors last as long as everyone else so I guess it doesn't matter. He changes his oil a bit more often vs Redline and when we compare Used oil and costs it works out to about the same cost (slightly cheaper) vs Redline with the OCI accounted for.
Thank you for the responses.
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5113146 05/23/19 07:12 AM
B
BMWTurboDzl Offline
B
Gotcha. Enjoy the rides. I'm sure that E36 is getting a little long in the tooth. Looking for a replacement?
435i
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5113436 05/23/19 12:25 PM
J
J
She is old but still pretty, I have a Spec e46 now also.
[Linked Image]
[Linked Image]
Plus this old girl
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5144870 06/26/19 04:31 PM
spiderbypass Offline
I love the look of the “old girl”
Insecurity with overcompensation are the root of evil deeds.
Re: Motul 300v 5w40 vs Redline 40WT racing in BMW racecar [Re: junkyard_sal] #5145135 06/26/19 09:27 PM
B
benjy Offline
B
redline racing oil is just that, best for racing + redline is prolly one of the very best, if you ever checked bearings etc you would see the real answer. that said any oil is likely cheaper than engine work. real synthetic like redlines 40W is a straight weight oil but meets the 15-40 spec because of the ester + maybe PAO + NO viscosity improvers, in real synthetic base oils used, pay me now or pay me more later is the question!
