Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
38 registered members (AndyB, BlueOvalFitter, Bighorn2500, chemman, bagyoau, 8 invisible), 636 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
Safe to use TWO strut dust covers (strut bellows?) And a few other questions. #5111903
05/22/19 12:08 AM
05/22/19 12:08 AM
New YOrk
lizpat Offline OP
lizpat  Offline OP
New YOrk
I'm replacing the factory shocks and springs (but keeping the strut mounts) for my 2007 Corolla. The new shocks and springs come as a kit from Bilstein and Eibach, it's called the Bilstein B12 kit: it consist of their B8 shocks (a shock designed for lowering springs) and Eibach pro-kit lowering springs which lower the vehicle about 1 inch. It's supposed to be a match.
Today I did the driver side front. I was planning on doing all four but a single side took five hours. I started the other side at 6pm but couldn't get the stabilizer link off--instead I stripped the nut. UGH. I'm going to hacksaw it off and replace it with a well-reviewed MOOG unit.
A few questions:
I used TWO rubber strut bellows (dust covers) to cover the entire strut piston, I used zip ties to join them together and another zip tie to hold the piece to the base. I believe I am creating something of a vacuum and keeping all dust out. Do you think this is a good idea?
I added Sil-Glyde brake grease to the strut mount bearing (I believe it comes from the factory with MP No.2 grease (according to the factory service manual) basically mixing it with whatever was already there from factory.
I reused the factory top mount nut rather than the one Bilstein provided. The factory nut seemed perfectly fine and the Bilstein nut was larger (22mm vs 19mm factory) and it was a blue nylon locking nut which worried me, I was worried I wouldn't be able to torque this thing.)
After installation, I will share pics and give the reader my driving impressions. I've considered lowering my car for a decade now but was always hesistant about it. I haven't been able to find anyone online who has installed this kit.
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5111925
05/22/19 02:18 AM
05/22/19 02:18 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Using 2 bellows should be OK. I don't see why it would create any issues.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5111955
05/22/19 05:13 AM
05/22/19 05:13 AM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
It never ceases to amaze me when a person says that instead of following the installation instructions, they changed 5 things. But they're hesitant about it and are they going to be ok?
Why not just follow the advise of the people that manufactured the parts? In the preponderance of circumstances it is the best available course of action.
Is that so hard?
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: Imp4] #5111957
05/22/19 05:18 AM
05/22/19 05:18 AM
New YOrk
lizpat Offline OP
lizpat  Offline OP
New YOrk
Is that so hard?
That's a fair point but I'll say this: I don't have a garage (I have to make do right on the public streets) and I didn't anticipate certain issues. I wasn't sure I should even add any additional grease since the bearings appear to be well greased from the factory and it was fairly clean.
The Bilstein kit came with generic instructions, I lost confidence in it because the translation was pretty awful. It also had sentences that directly CONTRADICTED each other.
For this project, I sort of had to use my brains, I'm not sure I used it correctly though smile
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: Char Baby] #5111958
05/22/19 05:19 AM
05/22/19 05:19 AM
New YOrk
lizpat Offline OP
lizpat  Offline OP
New YOrk
One possible concern is that there shouldn't be a vacuum against the strut rod: in fact, it may need to inhale and exhale air. Sound weirds but I thought of it.
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5111983
05/22/19 06:16 AM
05/22/19 06:16 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
lizpat: Do tell us how the lowering (of your very stock vehicle) goes.
A friend's son tells me to lower a sedan I have in order to sell it. However, his plan includes darkening the windows-the car is dark green-and adding quiet, tasteful wheels.
None of that is going to happen.
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5111986
05/22/19 06:19 AM
05/22/19 06:19 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Did the Bilstein not come with dust boots?
In any case the use of two dust boots as described should not create issues as long as they are secure. Some dust boots have a hole to allow air to pass so if yours don’t you could create a small hole in the bottom of the lower bellows but I don’t think it is necessary.
I would use the provided nuts.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112078
05/22/19 08:12 AM
05/22/19 08:12 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I was thinking much the same thing . Also , concerned any vacuum might " pull " in contamination ?
Wyr
God bless
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112119
05/22/19 08:42 AM
05/22/19 08:42 AM
Southeast
meep Offline
meep  Offline
Southeast
dust boots will not produce any kind of real vacuums, pressures, at all. Nothing that could impact the seals on the unit. The shaft will still be exposed to dirty atmosphere, but will be protected from rocks, sand and other larger debris.
2018 F150
2015 crv (wifey!)
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112146
05/22/19 09:09 AM
05/22/19 09:09 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
LOL
When I put my Bilsteins on my car, I just gunned the nut on. I've pulled those shocks three times now and they are still OK. I'm not sure torquing them makes any difference other than selling tools you will never use again. That being said, I have plenty of tools I will rarely if ever use.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112229
05/22/19 10:18 AM
05/22/19 10:18 AM
USA
slacktide_bitog Offline
USA
Always use the nuts supplied with the new struts!
And you should replace the strut mounts, especially if you live where there is rust.
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112254
05/22/19 10:36 AM
05/22/19 10:36 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Why are you worried about creating vacuum? These plastic bellows lack the precision reguired to create a good seal. Don't worry about it.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: lizpat] #5112375
05/22/19 12:59 PM
05/22/19 12:59 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
You do not want, or should not create, any vacuum on a strut. This thing move in and out and you will have some air going around. You can shield some of the dirt and mud splashed from the bottom but if you vacuum seal it, the boot will break or rub the rod (try it with a balloon with a rod partially sticking out, and see what it looks like).
I would use a new top nut just to make sure the nylon is new and will grab the thread tight, but it is not really that big of a deal either way.
Not sure if mixing 2 kinds of grease will do anything at all, but most importantly it is the grease inside the bearing that counts, so unless you took that apart and grease it, not going to do much.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Safe to use TWO strut dust covers (strut bellows?) And a few other questions. [Re: Kira] #5112495
05/22/19 03:04 PM
05/22/19 03:04 PM
New YOrk
lizpat Offline OP
lizpat  Offline OP
New YOrk
Thank you all for chiming in.
I know this sounds stupid but I've been driving the car with just one side lowered on Bilsteins (out of necessity.) I have observed that the motion is well controlled--------and I may be imagining this but it seems turn in has improved (yes I know it's just ONE side out of 4.) I'm happy so far, can't wait to get the other sides done. I'm breathing a sigh of relief here, I could have really regretted doing this.
I've decided to cut a hole at the top of the strut boot just to safe and to adhere to OEM Design, and to not lock in moisture.
