Washed the Terrain
by gregk24 - 10/13/19 10:23 PM
Oil recommendation for my flat tappet cam?
by fusseli - 10/13/19 10:02 PM
Less oil consumption when near add line?
by ledslinger - 10/13/19 09:33 PM
Honda Accord V6 Destroyed -- Timing Belt Failure
by CrackyWainwright - 10/13/19 08:48 PM
Valvoline Advanced Full Synthetic
by GaryPoe - 10/13/19 08:36 PM
Help!!!! 2000 GM 2.4 LITER TWIN CAM WATER PUMP
by Prich - 10/13/19 07:46 PM
Oil running off dipstick after hard driving
by DV0993 - 10/13/19 07:39 PM
Craftsman YT4000 - Slow uphill
by Covington - 10/13/19 07:23 PM
Outside Temperature Gauge
by rrretiree7 - 10/13/19 06:59 PM
Battery judgement based on analyzer
by tvaughn0712 - 10/13/19 06:49 PM
Low number plate
by Nayov - 10/13/19 06:34 PM
Valve Lubrication help
by MikeDanger - 10/13/19 05:31 PM
Havoline Pro DS Problems/Benefits?
by TheLawnRanger - 10/13/19 04:40 PM
Reusing oil filter
by Brojo - 10/13/19 04:11 PM
Vehicle Turbo Efficiency
by Al - 10/13/19 03:58 PM
Conv When Car Manual Calls For Syn Blend
by Mr_Luke - 10/13/19 03:01 PM
ATF contamination in PS Fluid--Honda CR-V 2007
by Blurider24 - 10/13/19 02:53 PM
Mag1 gear oil at PepBoys
by kstanf150 - 10/13/19 02:33 PM
1000Bulbs.com 500 at Talladega
by bdcardinal - 10/13/19 12:35 PM
HF small flasher
by Donald - 10/13/19 12:19 PM
LMLowner, Gordonhersh, Starrman, Covington, pktrkt
69548 Registered Users
82 registered members (AdditiveOCD, andyd, 19jacobob93, advocate, aleneros, 4 invisible), 1,681 guests, and 31 spiders.
Topics295,935
Posts5,087,635
Members69,548
Most Online3,532
Jul 30th, 2019
Align 3 blade deck #5111866 05/21/19 10:51 PM
R
rekit Offline OP
R
Swisher 60" 3 blade. Parked on level cement the 3 blades seem to measure good. You know, from the cement to the blade tip is the same. I know this heavy turd sinks in the grass, but I try to mow a few feet and see which blade is low or high and shim the blades/bearing holders till it looks better. But it is never consistent. Looks great here and awful there...How do you guys get it right or close to it?
Re: Align 3 blade deck [Re: rekit] #5111902 05/22/19 12:07 AM
R
rubberchicken Offline
R
I found that when you align the blades, it needs to be done front to back, as well as side to side. There is some sort of spec for front to back which will be found in the repair manual.
Re: Align 3 blade deck [Re: rekit] #5111915 05/22/19 01:19 AM
spasm3 Offline
i like the front of my deck to be about 1/8 inch lower than the back of the deck.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Align 3 blade deck [Re: rubberchicken] #5112046 05/22/19 07:38 AM
doitmyself Offline
Here's how Exmark follows your recommendation: ....man, I forgot how shiny they are when new.
Re: Align 3 blade deck [Re: rubberchicken] #5112172 05/22/19 09:27 AM
J
jeepman3071 Offline
J
+1
I was given this tool for christmas a few years back and it actually works pretty well and makes leveling the deck easy:
https://express.google.com/u/0/prod...6pOArsRw-JE_OiofvlOhyPyVRiBoCXZwQAvD_BwE
2013 Jeep Grand Cherokee TrailHawk 5.7L (144k) - PPHM 5w30, Wix 57899
2009 BMW 328i N51 (50k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Align 3 blade deck [Re: rekit] #5112826 05/22/19 08:18 PM
spasm3 Offline
Interesting video, exmark says up to 1/4 inch lower in the front. Might adjust mine a bit.
