Delphi ecu and segment swap
by P10crew - 10/21/19 10:06 PM
Close Call!😨
by Mad_Hatter - 10/21/19 10:06 PM
12 bolt truck rear
by P10crew - 10/21/19 09:57 PM
More painful motorcycle hill climbing footage
by Reddy45 - 10/21/19 09:57 PM
Charging for parking
by madRiver - 10/21/19 08:59 PM
OxyClean car wash
by dawgn86 - 10/21/19 08:58 PM
Oil Catalogue Idea
by GaryPoe - 10/21/19 08:51 PM
Liqui Moly longtime vs 4605
by jkhawaii - 10/21/19 08:17 PM
Name a good alcohol wine/beverage for a beginner.
by Vern_in_IL - 10/21/19 07:06 PM
Pulling a bumper pull keystone outback
by ram_man - 10/21/19 06:54 PM
Another fuel mileage thread
by tiger862 - 10/21/19 06:54 PM
Winter Truck: RWD w/ locking diff OR 4x4 w/o locking diff
by PotatoFarmer77w - 10/21/19 05:36 PM
M1 ESP 0W30 (8200 km run for an 2018 VW Golf R)
by 21Rouge - 10/21/19 05:11 PM
Allis Chalmers 50/50 4X4
by mem - 10/21/19 05:03 PM
Grand Cherokee Knock sound when using 4WD Low?
by John344 - 10/21/19 04:58 PM
Ecogard Synthetic + S4651
by kstanf150 - 10/21/19 04:52 PM
2015+ F150 SuperCab Rear Seat Room
by The Critic - 10/21/19 04:52 PM
New Michelin Endurance XT silicone wipers
by faramir9 - 10/21/19 04:15 PM
Any deals on Brake Cleaner and Engine Decreaser?
by eddielasvegas - 10/21/19 04:07 PM
Haiducek, NoRegrets, SouthDakotaDad, StaceyWoolsey, kluthage421
69639 Registered Users
94 registered members (92saturnsl2, 2010Civic, 77GrandPrix, 69GTX, 12 invisible), 1,668 guests, and 25 spiders.
Topics296,303
Posts5,095,217
Members69,639
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Distilled water bad? Use reverse osmosis water instead? #5111860 05/21/19 10:38 PM
A
atikovi Offline OP
A
Guy says distilled water is bad because it pulls minerals, aluminum and iron oxides from the block. Says to use reverse osmosis water or filtered rain water. Go to time 5:55: https://www.youtube.com/watch?v=2ovO1esqzVo Thoughts?
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111862 05/21/19 10:47 PM
W
Warstud Offline
W
Antifreeze manufactures use both in there 50/50 mix.
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111871 05/21/19 10:59 PM
Chris142 Offline
Once antifreeze is added it becomes a coolant loaded with anti corrosion additives.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111878 05/21/19 11:12 PM
Z
zrxkawboy Offline
Z
Either distilled or RO is fine.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111879 05/21/19 11:14 PM
das_peikko Offline
Distilled water pulls minerals out of the engine block? Boy that does it right there. I've heard everything now. LOL
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111944 05/22/19 03:47 AM
O
OnTheRocks Offline
O
I would be more concerned with tap water from a hose. But tens of thousands of people use regular water. Shops use regular water.
Re: Distilled water bad? Use reverse osmosis water instead? [Re: das_peikko] #5111950 05/22/19 04:36 AM
F
FordCapriDriver Offline
F
It does sound like complete BS
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111956 05/22/19 05:17 AM
Shannow Offline
To quote a now permabanned member...that's utter bollocks.
Yes, all of those waters are "mineral hungry", they will chew the concrete lining off concrete lined pipes to elevate their hardness...but inside metal receptables, no, they won't eat them.
Power stations we use deionised water inside the boilers and feed system, purified with ion exchange, polished with ion exchange, and ultimately as the water is recirculated through the boiler and turbine many many times...distilled.
Corrosion rates are low, unless air gets into the system...oxides need oxygen.
If we used tap water or rainwater, we'd have scaling as well as corrosion, and intergranular corrosion.
People used tap water forever, demineralised/deionised/distilled is best practice for coolant longevity.
If it's the truth....it can handle the pressure !!!
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111960 05/22/19 05:33 AM
M
Mainia Offline
M
RO water is corrosive NO!!!!!! It needs plastic or stainless steel in it's equipment. BIG MISTAKE to use RO water. I run a $80,000 RO system at work. You can use it in batteries, but don't use it in a aluminum or steel block, that's just nuts. In fact we had a problem with RO water attacking our chemistry in printing, we have to "pre treat" the virgin RO water to "attack" an additive BEFORE we use it, since it is so aggressive. Distilled is 110% the best water to use in an engine block.
Re: Distilled water bad? Use reverse osmosis water instead? [Re: das_peikko] #5111964 05/22/19 05:39 AM
A
alarmguy Offline
A
^^YUP^^
Amazing how anyone can produce a youtube video and people watch it like its true.
Its complete BS, in fact wont even watch it, why add "views" to the person making it, which is why its there to begin with.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Distilled water bad? Use reverse osmosis water instead? [Re: Mainia] #5111965 05/22/19 05:40 AM
A
alarmguy Offline
A
Originally Posted by Mainia
... Distilled is 110% the best water to use in an engine block.
^^^YES^^^
07 Suzuki C50
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5111975 05/22/19 05:55 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Complete nonsense. The issue is with deionized water. And even deionized water is safe once the first bits of antifreeze are added to it.
Re: Distilled water bad? Use reverse osmosis water instead? [Re: alarmguy] #5111982 05/22/19 06:16 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Originally Posted by alarmguy
... why add "views" to the person making it, which is why its there to begin with.
To give it a thumbs down.
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5112030 05/22/19 07:17 AM
A
askani79705 Offline
A
Both are fine
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala Pennzoil Ultra 10w30 AC Delco Filter
Re: Distilled water bad? Use reverse osmosis water instead? [Re: atikovi] #5112035 05/22/19 07:23 AM
T
TTK Offline
T
That is the 'hungry water" theory, originated by Click&Clack, as a joke I assume
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Page 1 of 3 1 2 3
