119 registered members (2oldtommy, AandPDan, 69Torino, 53' Stude, 50jeffrey, 11 invisible),
2,135
guests, and 56
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,499
Posts5,136,655
Members70,076
Most Online3,589 Nov 2nd, 2019
Cub Cadet LTX1050VT keeps shredding mower belts
#5111507
05/21/19 03:27 PM
oilpsi2high
OP
OP
Posts: 1,862 |
I have an 03 Cub Cadet with the 50" deck an 3 blade setup. This thing destroys mower belts. I go through 2 or 3 OEM belts a season. My lawn is 2-3 acres and kind of bumpy, but it shouldn't be eating belts at this rate. The mower only has 242 hours on it.
I'm going to pull the deck off and replace the belt (again).
Is anyone familiar with these, or know anything I should check or adjust? Each blade spins fine, no binding or anything.
Re: Cub Cadet LTX1050VT keeps shredding mower belts
[Re: oilpsi2high]
#5111518
05/21/19 03:39 PM
Donald
Posts: 23,249 |
Any pulleys rusted? Mis-aligned? Are you buying quality belts or EBAY specials?
2015 Subaru Forester 2.5 engine/CVT 2015 Ford F250 w/Powerstroke 2016 Subaru Crosstrek CVT (wife's)
[Re: oilpsi2high]
#5111533
05/21/19 03:54 PM
oldhp
Posts: 2,302 |
How is the belt tensioner? Could it be letting the belt slap against a fixed guard or something bracket eating the belt???
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod" "When others cut you down, remember where they came from." "I don't run...........I just wait"
[Re: Donald]
#5111535
05/21/19 03:55 PM
Convert
Posts: 121 |
Do any of the bearings on the pulleys on the deck need to be replaced? TOMB
TOMB 2006 Volvo XC90 2013 Toyota Tacoma TRD Sport 1976 Moto Guzzi Convert
[Re: oilpsi2high]
#5111592
05/21/19 04:48 PM
oilpsi2high
OP
OP
Posts: 1,862 |
Well, I think I found the problem.
I don't think this deck was ever cleaned. Not once since 2003.
Two of the blades I couldn't even turn by hand due to grass buildup on both the top and bottom of the deck.
I'll post before and after pics shortly.
[Re: oilpsi2high]
#5111631
05/21/19 05:37 PM
Tman220
Posts: 229 |
I'll post before and after pics shortly. 2-3 Belts a season and you have never bothered to clean out the top of the deck? All the grass and leaves insulating the belt and over heating it and causing it to fail? Don't forget to pump some grease into the spindles while you have it all a part
2012 Regal GS Turbo PP 5w30 90k 1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k 2005 GMC Sierra 1500 5.3 160k 2004 Civic LX M5 178k 2007 Camry 2.4 232k 2016 Victory Vegas
[Re: oilpsi2high]
#5111754
05/21/19 07:40 PM
spk2000
Posts: 1,517 |
I looked at buying this Cub model and saw reviews about the belt issues so I steered clear. Might see if a dealer can get a very strong kevlar belt but it may not matter.
96 Grand Marquis 203,000 mi 01 Sable LS Wagon 163,000 mi 02 Montero 191,000 mi 03 Sable LS Sedan 73,000 mi
[Re: oilpsi2high]
#5111760
05/21/19 07:46 PM
Slick17601
Posts: 1,678 |
I'll post before and after pics shortly. Can't blame the machine for a lack of maintenance. If you never clean the deck i can only imagine how bad the blades look.
2018 RAM Bighorn 5.7 2008 Toyota Sienna 3.5
[Re: oilpsi2high]
#5113380
05/23/19 10:12 AM
JTK
Posts: 12,171 |
I'm still trying to figure out how all those belt replacements got done without noticing this..
I'm assuming we're talking about the belt on the deck itself and not the PTO to the deck belt.
2019 Nissan Pathfinder SV 2017 Ram 1500 4x4, 3.6L. 2015 Nissan Versa 1.6 S
[Re: oilpsi2high]
#5113559
05/23/19 01:12 PM
oilpsi2high
OP
OP
Posts: 1,862 |
This is my landlord's mower, not mine. Anyway, I gave it a full once-over and did the following maintenance for him: Sharpened and balanced blades Cleaned and oiled deck Greased spindles Replaced drive belt (had to remove deck, hydrostatic clutch, trans fan, pulley, and bend the engine pulley keeper tabs back just to get this belt off.) Replaced mower belt Oiled chassis It's due for new blades, but I think we can get another year or two out of these after sharpening. One of the spindles' hubs are almost rounded off, and the hydrostatic trans is leaking fluid. I checked but didn't see anywhere to add (I guess it's a sealed unit. FAIL.) This thing runs like a new machine now. The deck vibrations are gone as well. Hopefully we can at least get through this year without any more repairs. ![[Linked Image]](https://i.ibb.co/MRk8TT4/image1.jpg) ![[Linked Image]](https://i.ibb.co/J7XtDrK/image2.jpg)
[Re: oilpsi2high]
#5113649
05/23/19 02:33 PM
Cujet
Posts: 9,060 |
Just a note to say that belt slip is tops when it comes to things that kill belts. They can take amazing loads, but are intolerant of heat. Make sure the tension is sufficient.
Also, bad bearings can heat the pulley and kill a belt. .
