Akebono ProAct Brake Pads with hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
43 registered members (agpatel, ArrestMeRedZ, BlakeB, ajchien, adams355, 3 invisible), 1,391 guests, and 21 spiders.
Topics300,298
Posts5,172,777
Members70,467
Most Online3,728
Jan 11th, 2020
Cub Cadet LTX1050VT keeps shredding mower belts #5111507 05/21/19 03:27 PM
O
oilpsi2high Offline OP
O
I have an 03 Cub Cadet with the 50" deck an 3 blade setup. This thing destroys mower belts. I go through 2 or 3 OEM belts a season. My lawn is 2-3 acres and kind of bumpy, but it shouldn't be eating belts at this rate. The mower only has 242 hours on it.
I'm going to pull the deck off and replace the belt (again).
Is anyone familiar with these, or know anything I should check or adjust? Each blade spins fine, no binding or anything.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111518 05/21/19 03:39 PM
Donald Offline
Any pulleys rusted? Mis-aligned? Are you buying quality belts or EBAY specials?
2015 Ford F-250 w/Powerstroke
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111533 05/21/19 03:54 PM
O
oldhp Online Content
Online Content
O
How is the belt tensioner? Could it be letting the belt slap against a fixed guard or something bracket eating the belt???
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: Donald] #5111535 05/21/19 03:55 PM
Convert Offline
Do any of the bearings on the pulleys on the deck need to be replaced?
TOMB
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
USAF 1966-1970
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111592 05/21/19 04:48 PM
O
O
Well, I think I found the problem.
I don't think this deck was ever cleaned. Not once since 2003.
Two of the blades I couldn't even turn by hand due to grass buildup on both the top and bottom of the deck.
I'll post before and after pics shortly.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111631 05/21/19 05:37 PM
T
Tman220 Offline
T
2-3 Belts a season and you have never bothered to clean out the top of the deck? All the grass and leaves insulating the belt and over heating it and causing it to fail? Don't forget to pump some grease into the spindles while you have it all a part
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 166k
2004 Civic LX M5 186k
2007 Camry 2.4 245k
2016 Victory Vegas
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111754 05/21/19 07:40 PM
spk2000 Offline
I looked at buying this Cub model and saw reviews about the belt issues so I steered clear. Might see if a dealer can get a very strong kevlar belt but it may not matter.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111760 05/21/19 07:46 PM
Slick17601 Offline
Can't blame the machine for a lack of maintenance. If you never clean the deck i can only imagine how bad the blades look.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113380 05/23/19 10:12 AM
J
JTK Offline
J
I'm still trying to figure out how all those belt replacements got done without noticing this..
I'm assuming we're talking about the belt on the deck itself and not the PTO to the deck belt.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113559 05/23/19 01:12 PM
O
O
This is my landlord's mower, not mine.
Anyway, I gave it a full once-over and did the following maintenance for him:
Sharpened and balanced blades
Cleaned and oiled deck
Greased spindles
Replaced drive belt (had to remove deck, hydrostatic clutch, trans fan, pulley, and bend the engine pulley keeper tabs back just to get this belt off.)
Replaced mower belt
Oiled chassis
It's due for new blades, but I think we can get another year or two out of these after sharpening. One of the spindles' hubs are almost rounded off, and the hydrostatic trans is leaking fluid. I checked but didn't see anywhere to add (I guess it's a sealed unit. FAIL.)
This thing runs like a new machine now. The deck vibrations are gone as well.
Hopefully we can at least get through this year without any more repairs.
[Linked Image]
[Linked Image]
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113649 05/23/19 02:33 PM
Cujet Offline
Just a note to say that belt slip is tops when it comes to things that kill belts. They can take amazing loads, but are intolerant of heat. Make sure the tension is sufficient.
Also, bad bearings can heat the pulley and kill a belt. .
