Best Shell/Pennzoil is ?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
Filter type for New Holland TC24DA
by jayjr1105. 06/15/19 09:13 PM
Subaru OEM Cut Open (2014 Crosstrek) - 8,000 kms
by mcwilly. 06/15/19 08:30 PM
Fram CA9997
by mcwilly. 06/15/19 08:23 PM
Snoopy found...
by Shannow. 06/15/19 08:15 PM
Tire buying in 5min Sam’s Club
by Patrick0525. 06/15/19 08:11 PM
AR-style rifle -- suggestions
by 92saturnsl2. 06/15/19 08:07 PM
To oil or not oil OPE foam pre-filters
by 92saturnsl2. 06/15/19 07:54 PM
Any Harvest King High mileage VOA'S?
by 53' Stude. 06/15/19 07:24 PM
Champion AGM Batteries
by The Critic. 06/15/19 06:52 PM
Redneck Battery Recovery
by cwilliamsws6. 06/15/19 06:29 PM
Currently Using iPhone 6S...Should I Upgrade?
by john_pifer. 06/15/19 05:08 PM
Is it Router or Comcast?
by RW1. 06/15/19 05:01 PM
bagyoau, frank57, gheewala114, Rob_Jeff, BrianinTucson
68412 Registered Users
39 registered members (buck91, BlueOvalFitter, AndyB, CB900F2, Bighorn2500, 8 invisible), 630 guests, and 19 spiders.
Topics290,259
Posts4,987,225
Members68,412
Most Online2,967
Mar 10th, 2019
Sea Foam question #5111753
05/21/19 08:40 PM
05/21/19 08:40 PM
California
vavavroom Offline OP
California
Is Sea Foam Spray Top Engine Cleaner & Lube the exact same Seafoan formula as Sea Foam Motor Treatment?
Re: Sea Foam question [Re: vavavroom] #5112513
05/22/19 03:14 PM
05/22/19 03:14 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Sorry don't know but if I had to guess probably not
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Sea Foam question [Re: vavavroom] #5112534
05/22/19 03:39 PM
05/22/19 03:39 PM
New Mexico
Rick505 Offline
Rick505  Offline
New Mexico
I'm too lazy to look but try and find the MSDS for both products and compare. For some reason I seem to think they stopped showing the real contents of regular Seafoam and started showing "proprietary" or something for some of the contents. Good Luck.
Re: Sea Foam question [Re: vavavroom] #5113775
05/23/19 05:36 PM
05/23/19 05:36 PM
California
DGXR Offline
DGXR  Offline
California
Seafoam engine cleaner spray goes directly into the intake through a tube device. Regular Seafoam is mixed with gas and oil.
Considering the different methods of use, I also would guess that the formulation is different.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Sea Foam question [Re: vavavroom] #5116201
05/26/19 10:15 AM
05/26/19 10:15 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Dunno. I don't use it. There are better products out there IMO, like Techron, Berrymans or Gumout. They have PEA which is the best cleaner you can buy and all, I believe, have a UCL. Seafoam last I checked did not.
If you're wanting it for the fancy straw, you could just disconnect the intake hose at the airbox or at the throttle body and have a friend gas the engine while you spray. You'll likely get a check engine light but that should go away once you put everything back together. Otherwise, just dump a bottle into the tank..unless you have GDI, in which case you'll need to introduce via the intake. That'll get your valves, piston tops and injectors cleaned.
Re: Sea Foam question [Re: Mad_Hatter] #5128731
06/08/19 06:02 PM
06/08/19 06:02 PM
Michigan
Greggy_D Offline
Greggy_D  Offline
Michigan
Berrymans does not have PEA.
Greggy D.
