Discount Tire Direct flash sale
by c502cid - 09/23/19 01:49 AM
Discount Tire Direct Instant $100 Savings One Day ONLY
by 71Chevyguy - 09/23/19 01:48 AM
Hankook Fall Rebate
by FordBroncoVWJeta - 09/22/19 11:23 PM
Axle and exhaust fixes this weekend
by Colt45ws - 09/22/19 11:07 PM
Maxlife v dex/merc
by HyundaiAbuser - 09/22/19 09:24 PM
15,119 Mile Supertech UOA
by Stumpy - 09/22/19 08:54 PM
Rust-Oleum Factor 4
by CatCam2 - 09/22/19 08:20 PM
Local Walmart Magnatec Closeout- Maybe Others?
by SSerian - 09/22/19 07:32 PM
Anti theft measures for new truck
by Oldtom - 09/22/19 07:28 PM
What would you do?
by Rexinaus - 09/22/19 06:26 PM
What size wire for 5 HP motor?
by dlundblad - 09/22/19 06:12 PM
Studless V/S studded winter tires
by cecil56 - 09/22/19 06:10 PM
200K more to Go!
by Gebo - 09/22/19 06:07 PM
Toyota license plate bolts/screws
by edwardh1 - 09/22/19 05:38 PM
How Do You Clean Your Grill ?
by Warstud - 09/22/19 04:05 PM
Curious question?
by Bill_W - 09/22/19 03:06 PM
Haldex, Automatic on demand clutch fluid?
by sloinker - 09/22/19 03:02 PM
dburch, Hueiyeh, Texguy, jm1, Dunkaroo
69364 Registered Users
26 registered members (c502cid, 4WD, 71Chevyguy, ArrestMeRedZ, bernardch, ChristianReske, 6 invisible), 718 guests, and 20 spiders.
Topics294,932
Posts5,069,488
Members69,364
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Honda 1.5T Edge 0W40 8,800mi. #5111552 05/21/19 05:17 PM
dblshock Offline OP
Ran this thru the bitter cold fall-spring
Attached PDF document
05 Lexus GX470 167k
640:1 TCW-3
5/30 10/30 5/40 15/40
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Citgo 10/30 conv XG3614
Falken Wildpeak AT3W
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111562 05/21/19 05:23 PM
JohnnyJohnson Offline
Poor FE and flash point.
2004 Corolla 135530
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76414
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111575 05/21/19 05:34 PM
The Critic Offline
Are you running the latest ECM/PGM-FI calibration on this car?
2011 Toyota Prius 1.8L - 197K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111581 05/21/19 05:41 PM
dblshock Offline OP
this UOA was to see if my step plan was working..3 times I drew about a qt. and replaced it with .5qt. as the bitter cold weather (100 mi. north of Green Bay) short trip dilution pushed it over the full level, the filter (Ultra) was at 21k when this was taken. all in all I'm o.k. with it.
05 Lexus GX470 167k
640:1 TCW-3
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111584 05/21/19 05:42 PM
dblshock Offline OP
no mods or reflashes, vintage 2016.
05 Lexus GX470 167k
640:1 TCW-3
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111585 05/21/19 05:43 PM
I
Imp4 Offline
I
Probably want to remove your personal information from that attachment...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111598 05/21/19 05:53 PM
K
kjbock Offline
K
Was your MM at 15% or less?
2019 Honda Civic Hatchback - FF
2015 Acura MDX - M-1 0W-20 AFE, M-1 M-110
2009 Honda Fit - PUP 5W-20, Fram Ultra XG7317
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111606 05/21/19 05:58 PM
dblshock Offline OP
I don't MM, go by miles or season...It was pretty much coal black colored.
05 Lexus GX470 167k
640:1 TCW-3
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111608 05/21/19 06:00 PM
dblshock Offline OP
saw alot of -10F to some -25F, winter was pretty brutal again here.
05 Lexus GX470 167k
640:1 TCW-3
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111616 05/21/19 06:07 PM
M
MParr Offline
M
The comments by the Blackstone person are total garbage and contradictory. In one sentence he talks about fuel dilution and another he say to try for 10,000 miles. SMDH! The 0W40 is a fine choice but, you may want to reduce the mileage between oil changes.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111621 05/21/19 06:16 PM
P
parshisa Offline
P
I’m approaching 8K on current 5w30 ams fill. MM is at 20% so will probably have it changed out at 10% or so, UOA to follow.
I wonder if elevated fe is due to winter/FD or something else?
Thanks for sharing
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111623 05/21/19 06:22 PM
dblshock Offline OP
the 210 viscosity was good, excess fluid volume is my worry hence the reason I draw it down...but if you do that math eventually you'd be almost all fuel so here we see that 3-4 qts. is vert doable and that will get you to an extended OCI...changing outside in the frigid here is a pia with the skid plate.
05 Lexus GX470 167k
640:1 TCW-3
Michelin Latitude
06 4Runner SR5 150k
640:1 TCW-3
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: MParr] #5111645 05/21/19 06:49 PM
O
oil_film_movies Offline
O
SMDH here too! (I had to look that one up in Urban Dictionary. TMAM ! (Too Many Acronyms, Man) )....
Hating Honda's fuel dilution. Wear numbers stink, especially by historical Honda-Toyota standards, where 1 ppm iron per 1,000 miles was almost expected.
0w40 is probably over-kill here, since it resulted in a 30 weight in the end, and this engine is spec'ed for 0w20.
Stick with the Xw30 option, as you're doing now with the Citgo 10w30 you're using now. Although M1 AFE 0w30 for your tough winters.
I can't say any adjustment you make will help those wear numbers though.
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111720 05/21/19 08:11 PM
2
2010Civic Offline
2
That is BS that on a new Honda you have to remove literally quarts of fuel from the oil.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Honda 1.5T Edge 0W40 8,800mi. [Re: dblshock] #5111731 05/21/19 08:24 PM
T
Triple_Se7en Offline
T
I would imagine you cold-start-idled that vehicle a-lot last winter.
Virgin [email protected] probably started out at least one number higher.
I would have ran Castrol Magnatec 5w30 and changed it at the midway point of the OCI (4400 miles).... then again at another 4400, instead of one [email protected] 8800. The winters there north of Green Bay are brutal.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Page 1 of 3 1 2 3
