Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
Dexron vi
by charmer37 - 09/20/19 10:22 PM
Deposit Shield
by TheLawnRanger - 09/20/19 10:00 PM
Atlanta Airport - Excellent History
by ctechbob - 09/20/19 09:56 PM
Angry at Walmart service center
by Jetsfan421 - 09/20/19 09:52 PM
Fuel System Cleaners
by ZeeOSix - 09/20/19 09:22 PM
Milwaukee 1/2 impact
by wensteph - 09/20/19 09:10 PM
Windows 7 Use After Support Ends
by ZeeOSix - 09/20/19 08:29 PM
Walmart Poulan chainsaws 50% off
by bubbatime - 09/20/19 08:10 PM
Vintage "Ultra Lube" Grease (show & tell)
by GaryPoe - 09/20/19 08:09 PM
Impact driver for auto work?
by Klutch9 - 09/20/19 07:27 PM
2000 Honda CR-V Ex transmission fluid?
by taztheman - 09/20/19 05:36 PM
Pennzoil Launches Four New Motor Oils
by jayjr1105 - 09/20/19 05:25 PM
Strange TPMS ID and no tire warning yet
by Patrick0525 - 09/20/19 05:18 PM
HF Icon Tool Storage - A Game Changer?
by user52165 - 09/20/19 04:39 PM
Update on my sister's oil burning Tucson
by carviewsonic - 09/20/19 04:37 PM
TungGT, ErikLeifson, Kinnes25, Bamajoe, Aleksandar
69347 Registered Users
41 registered members (berlyn, 4WD, 2015_PSD, 87sammy, bernau, 7 invisible), 805 guests, and 26 spiders.
Topics294,847
Posts5,067,849
Members69,347
Most Online3,532
Jul 30th, 2019
Cub Cadet LTX1050VT keeps shredding mower belts #5111507 05/21/19 04:27 PM
O
oilpsi2high Offline OP
O
I have an 03 Cub Cadet with the 50" deck an 3 blade setup. This thing destroys mower belts. I go through 2 or 3 OEM belts a season. My lawn is 2-3 acres and kind of bumpy, but it shouldn't be eating belts at this rate. The mower only has 242 hours on it.
I'm going to pull the deck off and replace the belt (again).
Is anyone familiar with these, or know anything I should check or adjust? Each blade spins fine, no binding or anything.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111518 05/21/19 04:39 PM
Donald Offline
Any pulleys rusted? Mis-aligned? Are you buying quality belts or EBAY specials?
2015 Ford F250 w/Powerstroke
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111533 05/21/19 04:54 PM
O
oldhp Offline
O
How is the belt tensioner? Could it be letting the belt slap against a fixed guard or something bracket eating the belt???
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: Donald] #5111535 05/21/19 04:55 PM
Convert Offline
Do any of the bearings on the pulleys on the deck need to be replaced?
TOMB
TOMB
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111592 05/21/19 05:48 PM
O
O
Well, I think I found the problem.
I don't think this deck was ever cleaned. Not once since 2003.
Two of the blades I couldn't even turn by hand due to grass buildup on both the top and bottom of the deck.
I'll post before and after pics shortly.
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111631 05/21/19 06:37 PM
T
Tman220 Offline
T
2-3 Belts a season and you have never bothered to clean out the top of the deck? All the grass and leaves insulating the belt and over heating it and causing it to fail? Don't forget to pump some grease into the spindles while you have it all a part
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 160k
2004 Civic LX M5 178k
2007 Camry 2.4 232k
2016 Victory Vegas
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111754 05/21/19 08:40 PM
spk2000 Offline
I looked at buying this Cub model and saw reviews about the belt issues so I steered clear. Might see if a dealer can get a very strong kevlar belt but it may not matter.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5111760 05/21/19 08:46 PM
Slick17601 Online Content
Online Content
Can't blame the machine for a lack of maintenance. If you never clean the deck i can only imagine how bad the blades look.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113380 05/23/19 11:12 AM
J
JTK Offline
J
I'm still trying to figure out how all those belt replacements got done without noticing this..
I'm assuming we're talking about the belt on the deck itself and not the PTO to the deck belt.
2017 Ram 1500 4x4, 3.6L.
2016 Nissan Quest SV (Babe magnet IV)
2015 Nissan Versa 1.6 S
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113559 05/23/19 02:12 PM
O
O
This is my landlord's mower, not mine.
Anyway, I gave it a full once-over and did the following maintenance for him:
Sharpened and balanced blades
Cleaned and oiled deck
Greased spindles
Replaced drive belt (had to remove deck, hydrostatic clutch, trans fan, pulley, and bend the engine pulley keeper tabs back just to get this belt off.)
Replaced mower belt
Oiled chassis
It's due for new blades, but I think we can get another year or two out of these after sharpening. One of the spindles' hubs are almost rounded off, and the hydrostatic trans is leaking fluid. I checked but didn't see anywhere to add (I guess it's a sealed unit. FAIL.)
This thing runs like a new machine now. The deck vibrations are gone as well.
Hopefully we can at least get through this year without any more repairs.
[Linked Image]
[Linked Image]
Re: Cub Cadet LTX1050VT keeps shredding mower belts [Re: oilpsi2high] #5113649 05/23/19 03:33 PM
Cujet Offline
Just a note to say that belt slip is tops when it comes to things that kill belts. They can take amazing loads, but are intolerant of heat. Make sure the tension is sufficient.
Also, bad bearings can heat the pulley and kill a belt. .
