Originally Posted by CDX825
Originally Posted by atikovi
Is humidity even adjustable on newer A/C systems? I'm still using a 29 year old unit.
Some of the newer thermostats allow you to run the ac to dehumidify. What it does is allow the temperature to drop a few degrees below the set point if needed to remove the humidity.
This is exactly what the Honeywell Prestige IAQ thermostat does that was included in the pkg deal w/ our new system installed in February. There is a button on the touch screen titled "Dehumidification" and it's page is a slider scale to select the desired indoor humidity allowing choice of RH levels in 5% increments from 40 on up to, I think, 70 although I forget the upper limit. And there is a setting you can get to with the installer code that allows you to choose the over-cooling limit that the system will use trying to maintain the selected RH. I think the over cooling limits were 0, 1, 2, and 3 degrees below the current temperature set point (temp you have the thermostat set to).
I've noticed that with the Dehumidification feature active (select "Auto" and choose desired RH on the slider scale) the blower fan runs at a low speed just as you'd expect.
