Powerstop Brake kits
by RhondaHonda - 10/14/19 03:00 PM
Oil recommendations
by Speak2Mountain - 10/14/19 02:28 PM
Maxlife ATF
by charmer37 - 10/14/19 02:18 PM
Anyone want a NAPA GOLD 1334 and FRAM ULTRA 3593A
by 53' Stude - 10/14/19 01:59 PM
Sams Choice Cuban Style Mustard
by skyactiv - 10/14/19 01:55 PM
Front suspension still making noise
by A_A_G - 10/14/19 01:20 PM
What is this? It says SmartGear
by JLawrence08648 - 10/14/19 12:20 PM
2004 Toyota Sienna
by Char Baby - 10/14/19 11:48 AM
Installing your own winter tires
by Snagglefoot - 10/14/19 10:43 AM
2018 Subaru Forester Premium 11mo Review
by badtlc - 10/14/19 10:40 AM
Good price on Mobil 1 Delvac 75w-90?
by kehyler - 10/14/19 09:09 AM
Ford IDI diesel starters
by bullwinkle - 10/14/19 09:07 AM
Portable Induction Bolt Heater
by billt460 - 10/14/19 06:51 AM
Coil springs, is there a top and bottom?
by LeakySeals - 10/14/19 06:20 AM
Non-DPF engine oil in Diesel BMW F10
by L93013 - 10/14/19 04:00 AM
Mercedes, Worth It?
by rrretiree7 - 10/14/19 02:30 AM
Using Marine Gear Oil in a Tractor
by Hot_Ajax - 10/14/19 12:53 AM
HotelPrisoner, Germanium, ffr1222k, Laurie, messerschmitt
69554 Registered Users
101 registered members (Anduril, A310, benhen77, Audios, aquariuscsm, 10 invisible), 2,560 guests, and 42 spiders.
Topics295,960
Posts5,088,154
Members69,554
Most Online3,532
Jul 30th, 2019
Page 5 of 8 1 4 5 6 8
Re: Why hasn't someone made a more efficient filter? [Re: ZeeOSix] #5110849 05/21/19 06:04 AM
dnewton3 Offline
Global Moderator
Global Moderator
Originally Posted by ZeeOSix
Originally Posted by dnewton3
I have seen no proof whatsoever, nor has anyone here ever shown any evidence, that super-duper lubes and filters are the exclusive means to long equipment life.
Granted, super high efficiency oil bypass filters are primary used in heavy duty diesel engine applications where OCIs are super long, and there have been lots of studies done showing that cleaner oil resulted in less engine wear. I think this was posted by someone here at some point but worth showing again.
Good morning, Zee. Curious where that data is from? What study? Was it a HALT? Can you link the study or the source please? I would like to review it.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5110857 05/21/19 06:13 AM
A
Al Offline
A
Originally Posted by Patman
True, but even if they charged $15 or $20 (as opposed to the $10 for the Ultra) they could still be popular.
As far as bypass filtration goes, I think the complexity of it scares a lot of people away. Having a simple spin on filter that is super efficient would be more user friendly.
I am not so sure it would work at 15 to 20 bucks Patman. But I am with you. I am required to use premium gasoline and a $3.50 per gallon I would pay $20 for a 10 micron filter in a heartbeat.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5110858 05/21/19 06:13 AM
A
AuthorEditor Offline
A
Logic would indicate that if long-haul trucks benefit from better filtration than all engines would gain some reduction in wear. I don't think that is in dispute. The argument that many of us are making is that the gain is not worth the cost, or any cost, since our engines are already lasting beyond the useful life of the rest of the vehicle. There might be some odd use cases where the gain could be worth paying for extra efficiency. Someone who maybe drives regularly 8-10 hours a day at highway speeds many days of the year, racking up 100,000 miles a year like a trucker. You might want to gain every bit of engine longevity and every bit of oil longevity between OCIs.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5110903 05/21/19 06:50 AM
sdowney717 Offline
Not wanting to read every comment, they have made a better filter.
They are venturi duel element. Having a 'bypass' type element combined with a full flow in the same can. All the oil goes to the engine oil gallery, the diversion takes place inside the filter.
LF9028 and BD7317 fit my Dodge Cummins diesel.
https://www.cumminsfiltration.com/s...i%20Combo%20Lube%20Filter%20Brochure.pdf
https://www.cumminsfiltration.com/venturi
Re: Why hasn't someone made a more efficient filter? [Re: dnewton3] #5110936 05/21/19 07:20 AM
P
Patman Offline OP
Global Moderator
Global Moderator
P
My Point? You don't need super duper syn lubes or extra premium filters to make an engine last a long time. There is more than one means to an end.
Because contamination is low early in an OCI, then you don't need premium products; "normal" oils and filters will keep the engine clean enough to last a LONG time. If you choose to extend your OCIs as a fiscal savings tool, then syns and BP filtration are important to keep the sump clean for really long OCIs.
I have seen no proof whatsoever, nor has anyone here ever shown any evidence, that super-duper lubes and filters are the exclusive means to long equipment life. The VAST MAJORITY of data shows that wear rates trend down, even out to 15k miles of the OFCI, regardless of what products are used. This is true of every darn engine series I've studied. And there is ZERO correlation that allows us to conclude that low wear is the exclusive result of premium products. Even "normal" oils and filters exhibit this phenomenon. Because both normal products AND premium products both experience the downward trend of wear out to 15k miles, it's clear that neither is the controlling factor of wear. What has been proven to be a controlling factor is the TCB in normal OFCIs.
I have not seen any proof that is credible (in today's applications for normal OFCIs) that proves we need "more" filtration or "better" oils. Your car is FAR, FAR more likely to be totaled in a wreck, or rusted to oblivious, or traded out from sheer boredom, long before the engine dies, as long as you practice a sensible OFCI program with normal products.
So, the reason there's not a mass market filter that's "more" efficient is because it's not needed. It might be wanted, but it's not needed.
Maybe not, but using higher quality synthetic oils and the best filters is something that I PERSONALLY want to do, I still stand by the belief that better oils and better filters cannot hurt, so why not do everything you possible can to give your engine the best chance at living a long life? I treat every car I own as if I'm going to keep it forever, and even when I don't keep them forever, at least the engine is still running as good as new in every way for the entire time I have the car, instead of that engine getting tired and not running it's best as it ages.
2018 Corvette, 17k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 152k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,121k, GC 0w40 & Fram Ultra
Re: Why hasn't someone made a more efficient filter? [Re: dnewton3] #5111141 05/21/19 10:31 AM
P
Patman Offline OP
Global Moderator
Global Moderator
P
Also, let’s put this another way. Everyone’s driving habits, climate and different engines will react differently. What worked in the past to get to that higher mileage with the cheaper oils and filters might not work today with higher compression direct injected engines (many of them with forced induction too, adding even more stress). If I’m wrong my only problem is that I’ve spent too much money on oil and filters. If you’re wrong, you’ll end up spending way more money rebuilding an engine sooner than otherwise necessary. That’s a gamble I’m not willing to take.
Re: Why hasn't someone made a more efficient filter? [Re: dnewton3] #5111323 05/21/19 01:17 PM
Z
ZeeOSix Offline
Z
That was posted in another thread quite a while ago, not sure which one. I'll dig around on my computer and see if I can find the source of the data.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5111350 05/21/19 02:01 PM
Z
ZeeOSix Offline
Z
dnewton - I found the source. See the attached PDF file (the internet link is no longer alive). I saved the PDF back when that thread was going on back in 2017. Member Ducked summarized the info in Section 4.1 of the paper by the Pall Corporation. Of course it's a diesel engine focused paper, but IMO gives good general info on engine wear vs oil cleanliness.
https://www.bobistheoilguy.com/foru...62/re-particle-size-question#Post4597662
Attached PDF document
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5113121 05/23/19 06:46 AM
dnewton3 Offline
Global Moderator
Global Moderator
Thanks Zee - I'll try to read it this weekend. Swamped at work this week.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5113136 05/23/19 06:54 AM
dnewton3 Offline
Global Moderator
Global Moderator
First of all, unless you're going to do something immoral, unethical, or illegal, you'll never get an argument from me about what you "want" to do. You should do what you "want", as will I, and most any other person.
But data tells us that you approach is not needed. That is the difference between wants and needs. Do it if you want, but real world data and facts show us that premium products are not an exclusive means to the end; that of long equipment life.
"Better" products won't hurt your engine; no one ever said that. What they do is hurt your wallet. Why pay for "extra" stuff that has shown no benefit in the actual application?
You want to spend money on premium products. There's no proof that the money spent on premium products in normal applications gives a decent ROI.
I want to save money. There exists tons of data that shows normal products protect equipment every bit as well as more expensive products, when used in everyday applications.
Neither of us is wrong to do what we want here.
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5113275 05/23/19 09:29 AM
A
A
Quote
From what we read on BITOG people advocating non-premium products often aren't really saving money. For example, using standard dino oil and changing the filter every 5000 miles does not save you any money over using synthetic oil and a better filter while only changing the oil every 10,000 miles, assuming that synthetics and better filters are about twice the price. If you count your time as worth something you get the same results for 50% of the labor cost. Plus there is a savings on trips to the store or delivery charges, clean up materials, rubber gloves, crush washers, etc. etc. It gets worse if you are doing OCIs of 3000 miles. I haven't seen any definitive proof that the synthetic regime described is any worse for normal engines in normal use. On the other hand, you could argue that ordinary oil and filters could probably be used for double-length OCIs with no harm, and then you would be seeing a significant savings.
Re: Why hasn't someone made a more efficient filter? [Re: dnewton3] #5113554 05/23/19 02:09 PM
P
Patman Offline OP
Global Moderator
Global Moderator
P
But is any of this data for modern engines with direct injection? (which is becoming very common on a lot of engines these days, not just high performance ones) I think a lot of older engine designs were very forgiving when using lesser quality oils. But with direct injection and it's tendency to build up carbon on the back of intake valves (amongst other challenges like fuel dilution) I think choosing a premium oil can in fact make a big difference in it's life span. For instance, the oil I choose to run in my Corvette has a very low SA % of 0.6, and is reported to have a very low NOACK of under 6%. I think those two things alone will make a big difference in intake valve deposits (and overall engine cleanliness too) compared to if I just chose the cheapest available dexos1 rated oil (like Amazon Basics or Supertech for instance, and I doubt either of those choices will have the low SA and NOACK of M1 ESP Formula)
Re: Why hasn't someone made a more efficient filter? [Re: Patman] #5113577 05/23/19 02:30 PM
Z
ZeeOSix Offline
Z
^^^ Patman - yes, DI engines seem to raise the bar and therefore not all products may give the same end results over time.
Re: Why hasn't someone made a more efficient filter? [Re: AuthorEditor] #5114023 05/23/19 09:42 PM
G
Garak Offline
G
That's absolutely true. However, not everyone who switches to a filter and oil about twice the price will choose to double their OCI. Dnewton3's point over the years has been that lubricants and filters are generally very underutilized.
Plain, simple Garak.
Re: Why hasn't someone made a more efficient filter? [Re: Garak] #5115344 05/25/19 11:45 AM
W
WellOiled Offline
W
My Ford Ranger was hard on oil and would shear down conventional or synthetic blend oils in less than 3000 miles. I found the synthetic oils to be more robust and don’t readily shear down. I could easily run 6000 miles with a budget filter and the synthetic oil. If I wanted to extend I would want to back it up with a series of UOAs and a better filter.
Both true statements by Garak and AuthorEditor.
Mazda 6
Factory fill
