I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
modem in 1 room want phone in another room
by raaizin - 08/21/19 02:17 PM
AC Belt Question
by BISCUT - 08/21/19 02:10 PM
Pros and cons of Electronic Parking Brakes?
by KGMtech - 08/21/19 01:50 PM
2016 Mazda6: no belt replacement interval
by Elkins45 - 08/21/19 01:00 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
99 registered members (2strokeNorthstar, 2010Civic, 4WD, 04CorCar, 2009Edge, 13 invisible), 2,010 guests, and 25 spiders.
Topics293,629
Posts5,043,689
Members69,025
Most Online3,532
Jul 30th, 2019
Bolt grades #5110558 05/20/19 08:05 PM
Dave Sherman Offline OP
Not too familiar with bolt grades, but I have a need to replace the blade bolt on my John Deere riding mower. Apparently the tall grass was a little too tall for it, but instead of just stalling the engine the blade bolt sheared. First the gods smiled as I managed to find the washer and blade retainer in the grass, then the gods of broken bolts were favorable as I managed to extract the rest of it from the boss with a bolt-out (first time ever!). I am just in need of a replacement metric bolt, but wondered if I should look for a specific grade.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Bolt grades [Re: Dave Sherman] #5110565 05/20/19 08:13 PM
clinebarger Online Content
Online Content
Generally.....The bolts only job is to hold the blade to spindle.
Knowing John Deere riders.....It was probably loose from the factory LOL
Was there a grade stamped on the head of the bolt? 8.8, 10.9 etc.
2001 Chevy Camaro L92/4L80E
Re: Bolt grades [Re: Dave Sherman] #5110567 05/20/19 08:15 PM
Dave9 Online Content
Online Content
You didn't mention the specific mower but on this page they have bolts that are grade 10.9:
https://www.greenpartstore.com/John-Deere-Blade-Bolt--19M7788_p_19287.html
If you can figure out the JD part # you can probably get the genuine bolt for $4 delivered on Amazon or eBay, if not $1-$2 at a local dealer?
Re: Bolt grades [Re: Dave Sherman] #5110577 05/20/19 08:23 PM
J
JayhawkRoy Offline
J
I have found it easiest to go to the John Deere dealer with the deck model number and get replacements. Cost is minimal. I have had to replace them due to rust and rounding off and keep three extras on hand for my mower decks.
Re: Bolt grades [Re: Dave Sherman] #5110594 05/20/19 08:41 PM
Can’t tell what grade it was, it just has “JD” and 3 lines stamped on the head. Yes, I could order the genuine bolt from JD online, or the local dealer might even have it in stock, but it also looks like something I could find at Lowe’s or HD. Mower is an RX75. Strangely, JD’s online parts show it as a 7/16” by 1 3/4”, but everything on the mower is metric and it has a 15mm head.
Edit: I see the dealer has it in stock for $1.98. Might as well get the real deal.
Re: Bolt grades [Re: Dave Sherman] #5110598 05/20/19 08:45 PM
R
Rand Offline
R
usually 3 lines means grade 5
Re: Bolt grades [Re: Dave Sherman] #5110612 05/20/19 08:58 PM
P
P10crew Online Content
Online Content
P
That is a place where when a single bolt breaks it can mame or kill. I think I would go to your John Deere dealer. Or find one that is for sure US made.
Re: Bolt grades [Re: Dave Sherman] #5110636 05/20/19 09:22 PM
H
hallstevenson Online Content
Online Content
H
Are the (3) lines in a shape kinda like this ?
If so, that's an SAE (inch) bolt, Grade 5. Honestly, you can buy these at any hardware store. If the JD dealer is convenient, $2 isn't terrible.
Also, you measured 15mm (around 0.59") across the bolt head. A 7/16-14 bolt has a 9/16" (0.56") head.
Re: Bolt grades [Re: Dave Sherman] #5110652 05/20/19 09:33 PM
CT8 Offline
Is the bolt grade specific to be a shear bolt?
Re: Bolt grades [Re: CT8] #5110686 05/20/19 10:08 PM
M
maxdustington Offline
M
That would be my concern. Slap a grade 8 on there and blow the entire thing to smithereens.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Bolt grades [Re: Dave Sherman] #5110724 05/20/19 10:44 PM
tom slick Offline
I don’t think JD would use a shear bolt to hold on a blade spinning at 2500 rpm. From what I’ve seen blades are held on with a grade 8 or 10.9 which are similar strength.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Bolt grades [Re: Dave Sherman] #5110757 05/20/19 11:26 PM
R
rubberchicken Offline
R
Re: Bolt grades [Re: Dave Sherman] #5110944 05/21/19 07:28 AM
T
tc1446 Offline
T
Take the threaded portion to Lowes where they have a sizer on the wall near the bolts.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Bolt grades [Re: rubberchicken] #5112386 05/22/19 01:06 PM
Thanks for the info. The new bolt and the old have lines more like \ | / along 3 adjacent edges, don't know if that means the same as the 3 arranged radially. Even the parts guy at the dealer was surprised it sheared. i was afraid maybe I had over-tightened it at some point, since I switch between the mulching blade and the high lift blade in spring and fall. This time I used the torque wrench on it, and there is no way I reached the 90 foot pound spec with the wrench I was using; it would have taken considerably more effort. Anyway, it's got a shiny new OEM bolt, there was no damage when the blade let go, and I was able to coax the broken half out of the spindle.
Re: Bolt grades [Re: Dave Sherman] #5112920 05/22/19 10:08 PM
tom slick Offline
3 lines on one half as you describe is SAE grade 5.2 or ASTM A325 and is a special material and heat treatment.
