Originally Posted by oilpsi2high
Originally Posted by The Critic
Tundra with the 5.7L.
No DI, no variable cylinder management. 10-yr old platform. Super reliable.
What years? I haven't heard very good things about those trucks as they age. Even Scotty Kilmer said to avoid them, haha.
2007 was the redesign and brought in the 5.7 (which is timing chain). The 4.7 had a timing belt and was replaced in 2010 by the 4.6 (which has a timing chain and is a destroked 5.7); the 4.7 only got a 5AT while 4.6 & 5.7 are 6AT (neither trans is known for having issues). The 4.6 & 5.7 can have water pump leaks; cam towers can leak oil. Front diff had problems, forget the range but it was like 2007 through 2011 (bad bearing preload so it chews up a bearing). Steering racks was bad in a similar timeframe. I think there might be a TSB for bed bolts now. 2007-2013 I don't think is known for rotting frames--but it's a Toyota, you know it'll rust pretty good. 2014 was a sheetmetal refresh with the same drivetrain. 4.6 does not get better mpg than the 5.7 so it's not worth getting (but it will do most anything you want, just slower). No rear locker / limited slip, but it will pull brake lines to control wheel slip. At least for my year the VSC is very intrusive and driving in snow usually has me turn TC & VSC off else it gets stuck too easily. Snow tires are must on this thing! Clinebarger points out that starters are not trivial to replace. Skidplate has to come off to remove oil filter, and it's a cartridge design that no one here likes. Holds 8 quarts of oil too.
Mine has been ok. Front diff had to be rebuilt around 80k (warranty repair). Serpentine tensioner got noisy. Had to replace it and do a throttle valve cleaning around the same time (110k or so). I did the plugs at the same time and found at least one spark plug tube was leaking. Had a rear caliper seize around 130k. Paint chips easily.
Thirsty beast, I think mine is averaging 17mpg right now, but I don't drive it a lot. I saw 21mpg with some hypermile tricks, but it refused to do better than 16 in winter on snow tires.
