4WD
$50 site donor 2024
The two GM L83's I own appear thoughtful … the plug and filter are further back past all the under pans/shields.
Everything drains into the drain pan, no collusion or obstruction …
In fact there is a small steel sump attached to the aluminum oil pan so that threads are steel on steel.
Perhaps Clinebarger could advise if removing those have a utilitarian purpose ?
