Got new tires!
by michaelluscher. 06/16/19 07:45 PM
Should I change atf on 2003 vw passat
by joegreen. 06/16/19 06:54 PM
Thoughts On Resizing Loaded Ammo
by 2015_PSD. 06/16/19 06:47 PM
Checked out a 2019 Ford Ranger, Disappointed
by LoneRanger. 06/16/19 06:40 PM
York Compressor comes with PAG only
by Beach_dude. 06/16/19 06:32 PM
K&N HP 2005 Questions
by 53' Stude. 06/16/19 05:41 PM
Troybilt Pony ride on dropped dead
by RDMgr. 06/16/19 05:21 PM
What does a Bosch D+ 3312 fit?
by 53' Stude. 06/16/19 05:08 PM
Engine oil flush recommendation.
by Bill7. 06/16/19 04:24 PM
Anyone familiar with Speed Ventures?
by SLO_Town. 06/16/19 04:13 PM
A/C Blower Motor
by HouseTiger. 06/16/19 03:38 PM
Painting Garage Floor
by raaizin. 06/16/19 03:23 PM
bluetooth scan tool
by Ranger1. 06/16/19 03:22 PM
Chevrolet website, how does this happen?!
by SLO_Town. 06/16/19 03:06 PM
Pinewood derby cars
by Fitter30. 06/16/19 02:44 PM
6000 miles too long for PP?
by flinter. 06/16/19 02:27 PM
Consumer Report full size trucks
by kstanf150. 06/16/19 01:29 PM
Woes of an aging Hyundai
by Fifth87. 06/16/19 01:08 PM
Happy Father's Day
by dave1251. 06/16/19 12:42 PM
Filter Forum rules
by dnewton3. 06/16/19 12:09 PM
Cannedcreamcorn, Kestor, Slipcase, SyedTribo, bagyoau
68416 Registered Users
117 registered members (AdditiveOCD, 2015_PSD, 77GrandPrix, 53' Stude, 2003f7, Astro14, 19 invisible), 1,915 guests, and 25 spiders.
Topics290,293
Posts4,987,872
Members68,416
Most Online2,967
Mar 10th, 2019
Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? #5109236
05/19/19 11:29 AM
05/19/19 11:29 AM
Midwest USA
LoneRanger Offline OP
Midwest USA
I shoot for 55%. We don't have a dedicated dehumidifier, but recently had a new HVAC system installed which is a communicating dual stage type and uses an advanced thermostat (Honeywell Prestige IAQ) which displays current indoor RH in smaller font just below the temperature.
'09 Subaru Forester ...................(QS HM 5W30)
'19 GMC Terrain ........................(Factory fill)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109256
05/19/19 11:46 AM
05/19/19 11:46 AM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
45 in summer or less with dedicated dehumidifiers. Easier on AC too.
Winter raise humidity try to stay above 35 prefer 45 to 55.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109282
05/19/19 12:21 PM
05/19/19 12:21 PM
Atlanta, GA
pezzy669 Offline
pezzy669  Offline
Atlanta, GA
When I was in hotels I learned that 40-50% was optimal - only reason I learned this was because the large well known chain I worked for had a brand standard of I think it was 45 or 48%.
I just had my 19 year old heat pump replaced, my old unit was so inefficient that it easily maintained low 40% because it had to run so long to cool. Now the new unit is cooling properly so right now I am lucky to hit the low 50's with a thermostat setting of 74, hoping it gets into 40% once we get further into the summer and it is running more often. For me mid-high 50's it starts getting too muggy inside and I end up fiddling with my ceiling fans to stay comfortable at 74 degrees, low 50's the 74 starts feeling decent and 40's the 74 is just perfect.
2012 Volkswagen Jetta Sportwagen TDI - 66k
2011 Volkswagen Jetta Sportwagen TDI - 46k
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109354
05/19/19 02:20 PM
05/19/19 02:20 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
I don't try to maintain any specific level, just setting the thermostat to a comfortable level. An A/C IS a dehumidifier. It makes little sense to run a separate indoor dehumidifier in summer in the midwest US because it is essentially also an air conditioner yet a less efficient one, with a shorter effective life:cost ratio, that dumps a lot of heat into the room instead of exhausting outdoors (which is why it is called a dehumidifier instead of an air conditioner, functionally they both work pretty much the same besides this).
If you have a specific area where moisture is coming in and cannot seal it any better than it presently is, it would make more sense to put a portable air conditioner in that room except in the colder months of the year when you are running a heater instead of A/C, then a dehumidifier makes sense if you have a particular moisture problem (leaking basement/foundation/etc) instead of the more typical desire to increase humidity in winter heating months.
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: Dave9] #5109378
05/19/19 02:45 PM
05/19/19 02:45 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
This. The central air dehumidifies to whatever it is as it cools the house.
Right now it is 92°F and 73% relative humidty according to my weather gauge outside, inside is 79°F and 58% RH (A/C is set to 80°F).
'18 Santa Fe:Delo XLE 10W-30/OEM/3k
'12 xB:M1 EP 0W-20/CQ Blue/5k
'07 Vue:Synpower 5w-30/Ecogard Syn/OLM
'02 F150:Magnatec 5W-20/Bosch D+/1yr
'94 VT1100:Peak 15W-40/Bosch D+/1yr
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: blupupher] #5109388
05/19/19 03:08 PM
05/19/19 03:08 PM
Texas
4WD Offline
4WD  Offline
Texas
Yeah, where did our short norther go ? Pretty muggy this am …
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109418
05/19/19 04:07 PM
05/19/19 04:07 PM
Peace valley, Missouri
Fitter30 Offline
Fitter30  Offline
Under 50%. If you live in a humid area alot of utility companies offer a energy audit that offers a blower door test. My coop charged $50 and gave me a box of goodies. This test they put a fan in the front door with a canvas frame that seals the fan to the door way. Adjust fan speed to a certain air pressure reading and take a cubic foot per minute reading which shows how tight your house is. Lower the cfm reading the tighter your house is.
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: pezzy669] #5109475
05/19/19 05:49 PM
05/19/19 05:49 PM
Midwest USA
Midwest USA
See if a tech can come out and lower the blower fan speed on the new system. It might be set by default to a faster blower fan speed than is optimal for dehumidifying. If it is a dual stage or multi stage "communicating" system and has the newer ecm type blower fan motor or whatever it can likely vary the blower fan speed by the smart thermostat they installed with it (usually a Nest or a Honeywell IAQ).
You want a slower fan speed so the evap coil gets colder and condenses water out of the indoor air more effectively
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109489
05/19/19 06:15 PM
05/19/19 06:15 PM
New England
gathermewool Offline
New England
Always <50% = no mold. I set my dehumidifiers to 45%
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109494
05/19/19 06:25 PM
05/19/19 06:25 PM
Suburban Washington DC
atikovi Online content
atikovi  Online Content
Is humidity even adjustable on newer A/C systems? I'm still using a 29 year old unit.
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: atikovi] #5109719
05/19/19 11:30 PM
05/19/19 11:30 PM
Litchfield, Ohio
CDX825 Offline
CDX825  Offline
Litchfield, Ohio
Some of the newer thermostats allow you to run the ac to dehumidify. What it does is allow the temperature to drop a few degrees below the set point if needed to remove the humidity.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Pennzoil Platinum 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109753
05/20/19 12:50 AM
05/20/19 12:50 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Heating, cooling homes, now adjusting the humidity. My home is set to ambient temps, and humidity as supplied by our weather system. I've spent my life doing it that way,no need to change now.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109765
05/20/19 01:10 AM
05/20/19 01:10 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Well, humidity is pretty nonexistent in Phoenix so it's not something we worry about.
2015 Hyundai Sonata 2.4L 97k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 234k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: LoneRanger] #5109800
05/20/19 03:35 AM
05/20/19 03:35 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
60 with my basement. Normally not that hard to maintain and I'm smack in the middle of the Great Lakes.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Those in Humid Areas, What Summer Indoor Humidity (RH) Do You Try to Maintain? [Re: Silk] #5109971
05/20/19 09:05 AM
05/20/19 09:05 AM
New England
New England
I'll tell you what. I can deal with high and low temperatures pretty well. See previous threads where some of you guys make fun of me for keeping temps outside of our bedroom in the 50's all winter! lol
One thing I can't deal with, is high humidity. I simply can't sleep at night if the humidity is too high.
Do you guys have basements there?
the previous owners of my home had a dehumidifier in the basement, but weren't using it the several times in the fall that we walked through.
There was white and yellow mold in two different parts of the basement that we had them take care of, and to check if it was active.
Anyway, the basement smelled very musty until I setup two dehumidifiers. A few months later and the musty smell is gone.
We store a decent amount of stuff downstairs, so it's nice to not worry about moisture damage, smell, and rust (to a certain degree)
Upstairs, we let the humidity do its thing. I usually run the window unit the large upstairs only for de-humidification, since it's too small to keep up with temps.
I honestly don't mind 80F+ and low, low humidity. We turn on the second, large window unit when the smaller one can't keep up with very high humidity days or the temps get threaten to exceed 90F.
Fans are A LOT more effective when the humidity is AZ low.
