This is my first time doing an UOA on any car I've owned and first time posting on here. Just posting this here as a record and for others as information if helpful at all
Basically around 47k Miles I replaced my cam chain tensioner or timing chain tensioner as a preventative maintenance as the OEM units are known to go bad on the F20C/F22C1. I decided to go with a Ballade Sports replacement unit and little did I know that their product was defective. It over tensioned my chain and caused the idler bolt that holds the gear which drives the chain to explode into pieces.
I was very fortunate as upon inspection there was no major damage to the motor however I did have to replace that idler bolt and the gear that holds the chain. So I replaced everything in that area including new chain and guides as well. This time I went with a chain tensioner made by a well known member on the SK2I forums.
For the first few hundred miles after the part replacement I ran a 30/70 mix of Lucas ZDDP 30 weight oil and 5W30 Phillips 66 Syn Blend oil to clean out the engine as a precautionary thing. The motor and the intake is stock. Mainly city driving and it took me a year and a half to put 3021 miles on the car. I also added LiquiMoly Mos2 additive.
Thanks for looking!
Thanks for looking!
