Originally Posted by gathermewool
Originally Posted by talest
The best gasoline additives will have PEA, everything else is pretty much a waste. Better to put a PEA cleaner like Gumout with Regane (look for the word Regane) or some others that have it than something like Seafoam or Berryman B12 which may do some cleaning, sure, but not as much as a PEA thing. Seafoam also ups the octane points a little bit so your engine may feel peppier, most engines do on higher octane fuel especially if you are used to a lower octane. Still a waste if not needed but sometimes it is needed!
Have not had to store a vehicle, might do a Sta-Bil if it doesn't affect anything. Then you add the fresh gas and burn it off etc.
Seafoam makes the engine peppier???
A higher octane makes an engine peppier? That is not how I thought octane worked, isn't it purely a measure of knock resistance? If you're running a 10:1 compression ratio shouldn't 87 and 91 feel the same, since none of it is causing knock?
