NY Yankee fans...
by gfh77665 - 10/20/19 12:56 AM
168 inch pounds feels really--really tight
by perfect_oil - 10/19/19 11:36 PM
Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
27 registered members (Char Baby, Donald1953, BlakeB, cjcride, 4WD, 2 invisible), 614 guests, and 21 spiders.
Topics296,198
Posts5,093,331
Members69,612
Most Online3,532
Jul 30th, 2019
Page 1 of 6 1 2 6
2019 - 502/505 is dead in US #5109126 05/19/19 08:44 AM
V
vinu_neuro Offline OP
V
Maybe discussed already, this is the first time I've seen all engines officially moved away from 502/505. In fact Audi has skipped 504 all together for many engines and gone straight to 508. I'll stick to 504 in our Q5 in any case and don't think 508 products are even on the shelves here yet outside the dealer.
2017
https://www.audiusa.com/content/dam...ed_Maintenance_Flipbook_Pages_022317.pdf
2018
2019
https://www.audiusa.com/content/dam...eduled-Maintenance_4-23-2019-w-etron.pdf
2008 Acura TL
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109129 05/19/19 08:46 AM
JohnnyJohnson Offline
If it can't just run API standard oils its always been dead to me!
2004 Corolla 136202
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76552
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109157 05/19/19 09:24 AM
B
BMWTurboDzl Offline
B
Not surprised. The Euros moved to HTHS < 3.5 some time ago. For example BMW LL04 was replaced by LL12FE.
435i
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109172 05/19/19 09:56 AM
T
Trav Offline
T
I don't know why anyone would run 502 today, its pretty much an obsolete old spec and inferior to 504. It was only necessary because of the poor quality fuels offered in the USA but now they are cleaning up their act with low sulfur.
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109204 05/19/19 10:50 AM
K
Kamele0N Offline
K
We mostly run vw504/507....BMW LL-04...MB 229.51/52 over here... Low saps formulations but with HTHS 3.5+....thats like 90% of the market here...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109205 05/19/19 10:50 AM
O
oil_film_movies Offline
O
Can be ordered on europaparts.com , fcpeuro.com , ecstuning.com , ebay.com , blauparts.com , I'm sure I've missed some..... You can often get an oil filter and new drain plug packaged with the oil too. Should be able to beat dealer prices! Castrol Edge Professional LL IV FE 0W-20 and LiquiMoly, Ravenol, Motul, Total Quartz, available here in the states.
rmeuropean.com has Motul, LiquiMoly, and Total Quartz brands of 508 oil. Looks like dealerships use Castrol Edge 508 typically though.
https://www.rmeuropean.com/Make/PartNumberSearch.aspx?pnsearch=0w-20
.... and gone straight to 508. I'll stick to 504 in our Q5
That would give you a small decrease in wear. Audi-VW probably looks at the small extra wear hit using the thinner stuff and says its acceptable. Something like this:
[Linked Image]
... which is around 10% or so extra wear, although boundary additives in the VW 508 thin oils might cut that to 5% or so. That means an engine that wears its rings out in 300,000 miles would, worse case, wear out in 270,000 miles instead. No biggie.
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109217 05/19/19 11:12 AM
O
O
Going to a 504 (HTHS 3.5) when Audi says 508 (HTHS 2.7) is going overboard. Adding +0.5 is more reasonable. Problem here is, that I don't see many HTHS ~3.0 to ~3.2 oils around that meet the tough VW specs. LL-01FE or MB 229.6 are higher saps, might not quite get to VW performance standards, and somewhat hard to get. Yes, going to VW 504 is good. Maybe VW 508 in winter-only.
Re: 2019 - 502/505 is dead in US [Re: oil_film_movies] #5109408 05/19/19 03:47 PM
Malo83 Offline
502 alive and well in the USA LOL
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109430 05/19/19 04:27 PM
J
js1956 Offline
J
For the past 3 winters (Dec - April) I run on WM Super-Tech 0W20 SN Plus with good results.
Rest of the year Amazon Basics European Formula 0W40 A3/B4.
Should I switch to 508 00 / 509 00 Castrol EDGE® Professional® 0W20 Long Life IV for winter or maybe year round?
2015 VW Mk7 Golf Launch Edition 1.8 TSI
Re: 2019 - 502/505 is dead in US [Re: JohnnyJohnson] #5109479 05/19/19 05:53 PM
M
MCompact Offline
M
That’s totally understandable, considering that aside from the dealer you can only find Euro spec oils in a very few extremely isolated and remote locations such as Advance Auto, AutoZone, and Walmart. Then factor in having to actually open and read the owners manual?
That’s way too inconvenient for me.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109539 05/19/19 07:25 PM
The Critic Offline
2017
2018
2019
LM TT 6200:
https://pim.liqui-moly.de/pidoc/P004100/20780-TopTec62000W-20-26.0-en.pdf
Motul 508.00:
https://d23zpyj32c5wn3.cloudfront.net/images/product_descriptions/technical_data_sheets/83126/Specific_508_00_509_00_0W-20_%28GB%29.pdf?1492182230
Both of these are readily available in the aftermarket. About $60/5L. Judging by the pour point and the pricing, I think these oils may be mostly PAO.
2011 Toyota Prius 1.8L - 198K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 139K - Valvoline Premium Blue Restore 10W-30
Re: 2019 - 502/505 is dead in US [Re: Malo83] #5109542 05/19/19 07:26 PM
Snagglefoot Offline
There’s no replacement for displacement. laugh
If you want the job done right......do it yourself.
Re: 2019 - 502/505 is dead in US [Re: JohnnyJohnson] #5109635 05/19/19 09:16 PM
G
Garak Offline
G
Then don't buy the baby Duramax. Or the gasser. wink
Plain, simple Garak.
Re: 2019 - 502/505 is dead in US [Re: vinu_neuro] #5109662 05/19/19 10:00 PM
V
V
@oil_film_movies and @The Critic: 508 being available on the shelves = on the shelves at WM, AAP oil change special, etc for $25/5qt.
@oil_film_moves, most of the engines on that list were developed for 3.5 HTHS. It's safe to say that's what's optimum and most people aren't going to bother with a couple % etc fuel economy.
2008 Acura TL
Re: 2019 - 502/505 is dead in US [Re: BMWTurboDzl] #5109697 05/19/19 10:51 PM
E
edyvw Offline
E
Only in USA.
In Europe, all are still on LL04.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Page 1 of 6 1 2 6
