Delphi ecu and segment swap
by P10crew - 10/21/19 10:06 PM
Close Call!😨
by Mad_Hatter - 10/21/19 10:06 PM
12 bolt truck rear
by P10crew - 10/21/19 09:57 PM
More painful motorcycle hill climbing footage
by Reddy45 - 10/21/19 09:57 PM
Charging for parking
by madRiver - 10/21/19 08:59 PM
OxyClean car wash
by dawgn86 - 10/21/19 08:58 PM
Oil Catalogue Idea
by GaryPoe - 10/21/19 08:51 PM
Liqui Moly longtime vs 4605
by jkhawaii - 10/21/19 08:17 PM
Name a good alcohol wine/beverage for a beginner.
by Vern_in_IL - 10/21/19 07:06 PM
Pulling a bumper pull keystone outback
by ram_man - 10/21/19 06:54 PM
Another fuel mileage thread
by tiger862 - 10/21/19 06:54 PM
Winter Truck: RWD w/ locking diff OR 4x4 w/o locking diff
by PotatoFarmer77w - 10/21/19 05:36 PM
M1 ESP 0W30 (8200 km run for an 2018 VW Golf R)
by 21Rouge - 10/21/19 05:11 PM
Allis Chalmers 50/50 4X4
by mem - 10/21/19 05:03 PM
Grand Cherokee Knock sound when using 4WD Low?
by John344 - 10/21/19 04:58 PM
Ecogard Synthetic + S4651
by kstanf150 - 10/21/19 04:52 PM
2015+ F150 SuperCab Rear Seat Room
by The Critic - 10/21/19 04:52 PM
New Michelin Endurance XT silicone wipers
by faramir9 - 10/21/19 04:15 PM
Any deals on Brake Cleaner and Engine Decreaser?
by eddielasvegas - 10/21/19 04:07 PM
Haiducek, NoRegrets, SouthDakotaDad, StaceyWoolsey, kluthage421
69639 Registered Users
97 registered members (AZjeff, 77GrandPrix, A_User55555, 69GTX, 10ecfarmer, 9 invisible), 1,749 guests, and 25 spiders.
Topics296,302
Posts5,095,200
Members69,639
Most Online3,532
Jul 30th, 2019
95% sure terrible idea #5108960 05/19/19 12:40 AM
H
HyundaiAbuser Offline OP
H
I currently have a Hyundai f5A51 transmission in my Hyundai that Is flaring from 2-3. I don't know a whole lot about these other than they use highly friction modified fluids. I've tinkered around with different fluids (flushing out all previous via cooler lines) w sp3, maxlife and Castrol mv import. I am ready to put a new transmission in it however I'm incredibly curious as to what would happen if I were to throw something like a type f in there. I have no regard for the trans operation afterwards but just a shot in the dark remedy. I am taking opinions as to the quality of that idea (even I think its awful but im curious) and if there are any other remedies I should try before most likely dumpstering this transmission.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108961 05/19/19 12:41 AM
H
H
I also have two other vehicles I can drive so taking one out of commission is not a horridly big deal.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108967 05/19/19 12:55 AM
Chris142 Online Content
Online Content
I would try it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108970 05/19/19 01:05 AM
H
H
What do you think the odds are that it completely grenades my transmission vs stop the slipping?
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108979 05/19/19 01:47 AM
ctechbob Offline
I wouldn't think it would grenade anything, just probably have very firm shifts.
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108986 05/19/19 02:18 AM
G
Gasbuggy Offline
G
Can you drive around the slip? I drove a 95 accord with a bad 2-3 slip from 193,000 miles to 386,000.
I would be [censored] about wasting all that money on trans fluid.
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5108998 05/19/19 04:01 AM
demarpaint Offline
I wonder if a couple of quarts of type-F vs. a complete fill would help more.
God Bless Our Troops
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109052 05/19/19 07:05 AM
K
Kira Offline
K
Questions on this:
As I remember GM transmissions had fiber disc packs.
Ford transmissions had plain metal disc packs and needed the Type F fluid for the texture.
Is it smart to ask what kind of disc packs are in your Hyundai? dermapaint might be onto something.
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109069 05/19/19 07:27 AM
H
Highline9 Offline
H
Do a search on tractor fluid. More grab than type f.
2010 challenger R\T
2014 mercedes glk350
2003 hyundai elantra
1992 dodge w250 cummins
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109090 05/19/19 07:57 AM
J
joegreen Offline
J
I have a Honda Accord with a pretty bad flare 1-2 and a bad flare 2-3. Everyone says to use Honda atf or the transmission will be ruined. Honda uses a highly friction modified fluid. One day I decided I'm not going to believe the only use Honda atf story. I started to experiment with different atf. First it was amsoil which actually worked surprisingly good. Then I tried Castrol transmax import. This did not work as good as amsoil. Then I tried Dex 6 which I think worked better than the Castrol. I did alot of reading about transmission additives. I read about the seal swelling capabilities but it seemed if you left the additive In it would eventually swell the seal to much and ruin the seals. I first tried lubegard red and it either had no effect or made the transmission worse. So I decided I would flush the trans with seafoam transtune. It says on the bottle not to leave it in to long I think for only 250 miles or something. When I poured it in the transmission immediately was so so much better. I left it in for the 250 miles and changed the fluid again and the transmission got worse again. At this point I decided if the transmission lived through all these different fluids I was going to really experiment. I currently have a mix of dexron 6, type f, and a bottle of seafoam in it. It has been using this fluid for 50,000 miles and the trans still doesn't shift perfect but it's much much better than it was and it has not gotten any worse. I say you should go for it. Unless a fluid has seal compatibility issues I don't see how it can immediately harm the transmission. You will be able to tell if the different fluid helped. Also my fluid is still pretty red atfer 50k even with the seafoam in it the whole time. By far the product that made the biggest difference was the seafoam transtune. It was an immediate fix.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109092 05/19/19 07:59 AM
R
ragtoplvr Offline
R
most newer transmissions are clutch to clutch. if the lower gear does not release in time, the transmission is in two gears at the same time, and it explodes. Often in a spectacular fashion.
I would not try it. Try lubeguard.
Rod
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109161 05/19/19 09:31 AM
doitmyself Offline
It's been many years since I used Lubeguard, but my memory tells me that the Red does not change frictional characteristics, but it might improve fluid longevity and maybe clean stuck mechanisms.
Have you done any diagnostics at all? Have you researched the many (15?) TSB's out on this transmission: TSB 08-AT-003 https://www.hyundaiforum.com/forum/hyundai-xg-350-35/transmission-sudden-downshift-5610/ and https://www.facebook.com/ATSGcompan...y-solid-topic-on-transm/788950187834594/
duhFinally, my anecdotal experience. A few months after having my Caravan tranny rebuilt years ago for catastrophic breakdown, it started having flaring/slipping symptoms. The tranny shop rebuilt the tranny again with no improvement. Then, they acquired, rebuilt, and installed a second tranny with the same dismal results (no charge to me). This time, the shop owner attached a scan tool to observe live data and drove around with me for an hour to duplicate the "flaring". It turned out to be a $29 speed sensor that was intermittently relaying erroneous info to one of the computers, causing a flaring symptom. No codes were ever thrown.
A clear case of not seeing the forest for the trees (expression used of someone who is too involved in the details of a problem to look at the situation as a whole) ....the bane of my existence, but improving in my 60's, LOL.
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109242 05/19/19 11:35 AM
M
Mainia Offline
M
I cocktail every ATF pumper I own inluding a 2013 Hyundai Elanda GT . Redline D6 with 2 Qt s of Redline low viscosity racing (type F) and 1 qt regular racing. I have the same setup in a towing Rav4 with zero issues. Same in my daughters old Civic that had a hint of slipping that this corrected 30,000 miles ago.
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109285 05/19/19 12:24 PM
H
H
im thinking that I will pump a quart out and put a quart in at a time w some type f and see what happens
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 95% sure terrible idea [Re: HyundaiAbuser] #5109287 05/19/19 12:25 PM
H
H
I have also cleared the adaptive shifting each time I flushed the fluid and that provided no help
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
